    Black screen on start up of Magic Mirror
    11 Posts 3 Posters 4.3k Views 3 Watching
      sdetweil @bkrand95
      @bkrand95 that looks like a bad config for compliments
      B 1 Reply Last reply
        bkrand95 @sdetweil
        @sdetweil What is telling you that it is the compliments module? Just trying to understand, thanks.
          sdetweil @bkrand95
          @bkrand95 I added code to the compliments module to support \n (newline) in the compliment text.
          Using the split function.
          The error is split can’t work on an empty string
          So, it sounds like no compliment for the time of day
            Or there is a problem with a config entry
              bkrand95 @sdetweil
              Below is my config file (put x’s in place of all the ID’s…). I actually have my compliments module commented out so I’m not sure how that can be an issue.
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	//address: "localhost", // Address to listen on, can be:
              	address: "0.0.0.0",
              	port: 8080,
              	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.10"], // Set [] to allow all IP addresses
              	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
              	ipWhitelist: [],                                                       // or add a specific IPv4 of 192.168.1.5 :
              	language: "en",
              	timeFormat: 12,
              	units: "imperial",
              			module: "alert",
              			//module: "updatenotification",
              			//position: "top_bar"
              			module: "clock",
              			position: "top_left"
              			header: "Calendar",
              				fade: false,
              				fetchInterval: 5000,
              				colored: true,
              				coloredSymbolOnly: false,
              				maximumNumberOfDays: 90,
              						symbol: "calendar-check",
              						color: "#c7ecff",
              						url: "https://calendar.google.com/calendar/xxxxxxxxxxxxxxxxxxxxxxx
              		//	module: "compliments",
              		//	position: "lower_third"
              			module: "currentweather",
              				locationID: "xxxxxxxxx",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
              				appid: "xxxxxxxxx",
              			module: "weatherforecast",
              			header: "Weather Forecast",
              				fade: false,
              				locationID: "xxxxxxxxx",  //ID from https://openweathermap.org/city
              				appid: "xxxxxxxxx"
                 			 module: "MMM-Cocktails",
                 			 position: "bottom_center", // Editable footprint - Fits anywhere.
                    				maxWidth: "400px",     // See provided .css file for full customization options
                      			header: "",
                      	//module: 'MMM-Remote-Control',
                      	//position: 'bottom_left'
                      		//config: {
                      		//    apiKey: ''
              			module: 'MMM-ModuleScheduler',
              				notification_schedule: [
              					// SHUTDOWN AT 07:04AM MON-FRI
              					{notification: 'REMOTE_ACTION', schedule: '04 7 * * 1-5', payload: {action: "SHUTDOWN"}},
              					// SHUTDOWN AT 11:30PM FRI & SAT
              					{notification: 'REMOTE_ACTION', schedule: '30 23 * * 5-6', payload: {action: "SHUTDOWN"}},
              					// SHUTDOWN AT 10:55PM SUN-THUR
              					{notification: 'REMOTE_ACTION', schedule: '50 22 * * SUN-THU', payload: {action: "SHUTDOWN"}}
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
              			disabled: true,
              			module: 'MMM-EARTH-Live',
              			position: 'bottom_center',
                			  height:"270px",
                 			 width:"480px",
                 			 useHeader: false,                // true if you want a header
                 			 header: "",                      // Change in config file. useHeader must be true
                 			 animationSpeed: 1000,            // fade speed
              		  module: "MMM-NowPlayingOnSpotify",
              		    clientID: "xxxxxxxxx",
              		    clientSecret: "xxxxxxxxx",
              		    accessToken: "xxxxxxxxx",
              		    refreshToken: "xxxxxxxxx"
                sdetweil @bkrand95
                @bkrand95 if u comment out a module, you must comment out the braces too,
                Not like this
                //  module : "compliments"'
                That leaves an empty entry in the modules array. Thus the problem
                You can also disable a module, by adding
                disabled: true,
                After the module: statement without commenting anything out
                Reply Quote 2
                  bkrand95 @sdetweil
                  @sdetweil Thanks for the advice, I went ahead and added the “disabled: true” line instead of commenting out the modules. I’ve seemed to have made some progress as I no longer get the black screen, but now I get the familiar message: “Please create a config file. See README for more information.” I have gotten this message before and it’s usual due to an error in my config file, although this time I really can’t find anything. Below is my current config… any errors pop out? Thanks again for all the help.
                   * MIT Licensed.
                  var config = {
                  	address: "0.0.0.0",
                  	port: 8080,
                  	language: "en",
                  	timeFormat: 12,
                  	units: "imperial",
                  			disabled: true,
                  			position: "top_bar"
                  			module: "clock",
                  			header: "Calendar",
                  				fade: false,
                  				colored: true,
                  						color: "#c7ecff",
                  						url: "xxxxx"
                  			disabled: true,
                  				locationID: "xxxxx",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                  				appid: "xxxxx",
                  				fade: false,
                  				locationID: "xxxxx",  //ID from https://openweathermap.org/city
                  				appid: "xxxxx"
                          			header: "",
                  			disabled: true,
                          		    apiKey: ''
                  			module: "newsfeed",
                  				feeds: [
                  			disabled: true,
                    			  height:"270px",
                     			 width:"480px",
                  		    clientID: "xxxxx",
                  		    clientSecret: "xxxxx",
                  		    accessToken: "xxxxx",
                  		    refreshToken: "xxxxx"
                  O 1 Reply Last reply
                  • O
                    OldSunGuy @bkrand95
                    @bkrand95 said in Black screen on start up of Magic Mirror:
                    module: ‘MMM-Remote-Control’,
                    position: ‘bottom_left’
                    The line after MMM-Remote-Control should be a comment,
                    and there should be a comma after the ‘bottom_left’.
                      And this line will need a trailing comma
                        bkrand95
                        Excellent, that was the fix! Thank you both so much for your help, marking as solved.
