    Adding Multiple Calendars
    3 Posts 3 Posters 629 Views 3 Watching
      reachforthestars
      Hello,
      I can’t seem to get 2 calendars working.
      I added my google calendars which works fine, but I want to add the default US-Holidays calendar back in and it won’t load it. I have tried searching online, and copying other’s code, but I don’t know what is wrong.
      Here is the code:
      			header: "Calendar",
      						symbol: "calendar-check",
      						url: "https://calendar.google.com/calendar/ical/XXXMYNAMEXXX%40gmail.com/private-XXXPRIVATEIDXXX/basic.ics",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
      Thanks for reading.
      ? S 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @reachforthestars
        @reachforthestars said in Adding Multiple Calendars:
        I don’t know it’s right solution, but,
        Worthy to try to change webcall:// to http://.
          sdetweil @reachforthestars
          @reachforthestars the default calendar has been generating errors lately cause the data changed
          to fix in the short term
          edit MagicMirror/node_modules/rrule/dist/es5/rrule.js
          insert the two lines shown below
                      case 'BYEASTER':
                          options.byeaster = Number(value);
                          break;
                      case '':                                        // add this
                          break;                                      // add this
                      default:
          also, the calendar file has duplicate entries so u will see 2 entries for all events
