    PIR motion works but screen ceeps alive
    5 Posts 3 Posters 3.4k Views 3 Watching
    • H
      hmoed
      this is my first post, so be gantle with me please… ;-)
      PIR motion works on test but my hdmi connected screen ceeps on, it will not going off.
      Some PIR Test info on Python Idle3:
      import RPi.GPIO as GPIO
      import time
      sensor = 4
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(sensor, GPIO.IN, GPIO.PUD_DOWN)
      previous_state = False
      current_state = False
      while True:
      time.sleep(0.1)
      previous_state = current_state
      current_state = GPIO.input(sensor)
      if current_state != previous_state:
      new_state = “HIGH” if current_state else “LOW”
      print(“GPIO pin %s is %s” % (sensor, new_state))
      OUTPUT on waving to PIR:
      GPIO pin 4 is HIGH
      GPIO pin 4 is LOW
      GPIO pin 4 is HIGH
      GPIO pin 4 is LOW
      GPIO pin 4 is HIGH
      GPIO pin 4 is LOW
      GPIO pin 4 is HIGH
      Config.js:
      module: ‘MMM-PIR-Sensor’,
      sensorPIN: 4,
      powerSaving: true
      ON NPM Start:
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: MMM-PIR-Sensor
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://p35-calendars.icloud.com/published/2/xxxxxxxxxxxxxxxxxx - Interval: 300000
      Create new news fetcher for url: http://feeds.nos.nl/nosjournaal - Interval: 300000
      Whoops! There was an uncaught exception…
      { Error: EBUSY: resource busy or locked, write
      at Error (native)
      at Object.fs.writeSync (fs.js:786:20)
      at Object.fs.writeFileSync (fs.js:1353:24)
      at new Gpio (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:88:8)
      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:54:18)
      at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:98:10)
      at emitTwo (events.js:106:13)
      at Socket.emit (events.js:191:7)
      at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:503:12
      at _combinedTickCallback (internal/process/next_tick.js:67:7) errno: -16, code: ‘EBUSY’, syscall: ‘write’ }
      Settings:
      Edit /boot/config.txt
      set hdmi_force_unplug=1
      sdtv_mo=2 // Normal PAL
      sudo su
      /var/spool/cron/crontabs
      @reboot python /home/pi/Documents/PIR/pir.py &
      Also done:
      sudo apt-get update
      sudo apt-get upgrade
      sudo reboot
      in MMM-PIR-Sensor folder
      npm install
      sudo reboot
      what O what can it be ?
        Steff
        I do remember that initially had some problems with my PIR sensor as well. It did not shut down the HDMI port properly. My personal problem was that I was not successful to disable the standard jessie screensaver.
        Once installing unclutter (sudo apt-get install x11-xserver-utils unclutter) and disabling the screensaver i got my PIR working perfectly.
        The error message in your log seems to indicate to me that is a resource conflict. Might it be possible that your are running your python script permanently and in parallel the PIR module ? And therefore causing the resource conflict ? Not sure whether this might be the case.
        One easy thing for debugging whether HDMI switching on/off is successful would be to install the remote control module. I did use this in my debugging phase to use the web interface of the remote control module to manually switch on/off the HDMI interface.
        Hope this helps, Steff
        • H
          hmoed
          thanks for the quick replay.
          I did instyall the unclutter for mouse pointer disable but not the way you discriped.
          I wil try what you typed above.
          1. sudo apt-get install x11-xserver-utils unclutter
          2. disabling the screensaver
          Afther that i take a look at the install of the remote control module.
          The Python script was only to show that the PIR is working outside MM2
          And i don’t run it the same time.
          i will inform back.
          • H
            hmoed
            back again,
            uncutter installed and is working
            remote controle module installed and is working from pc and my iPhone, top app.
            i can turn monitor off/on
            when i check the PIR on Python Idle3 it’s handeling motion correctly.
            BUT on the live mirror the PIR does nothing…
            HELP !
            • cowboysdudeC
              cowboysdude Module Developer @hmoed
              @hmoed said in PIR motion works but screen ceeps alive:
              i will inform back.
              The easiest way I find to disable the screen saver is to install xscreensaver and disable it! :) Quick and easy!
