    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 18.1k Views 7 Watching
      jthirasilpa
      Thanks Sam - I made that modification in node_helper.js in the module’s directory with my password.
      I get the following errors from the logs:
      0|mm  | [21:06:46.210] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: sudo.setPassword is not a function
        0|mm  | [21:06:46.216] [ERROR]
      0|mm  | TypeError: sudo.setPassword is not a function
      0|mm  |     at Object.<anonymous> (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:13:6)
      0|mm  |     at Module._compile (internal/modules/cjs/loader.js:778:30)
      0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      0|mm  |     at Module.load (internal/modules/cjs/loader.js:653:32)
      0|mm  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      0|mm  |     at Module.require (internal/modules/cjs/loader.js:692:17)
      0|mm  |     at require (internal/modules/cjs/helpers.js:25:18)
      0|mm  |     at loadModule (/home/jojo/MagicMirror/js/app.js:132:17)
      0|mm  |     at loadNextModule (/home/jojo/MagicMirror/js/app.js:166:5)
        jthirasilpa
        Maybe some progress?
        So I amended the insertion as follows:
        sudo.setPassword = ('your-password');      // add this line, edit to use your password
        Config loads, but NetworkScanner module still shows “loading…”
        Error logs as follows:
        0|mm       |     at Socket.emit (events.js:198:13)
        0|mm       |     at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
        0|mm       |     at process._tickCallback (internal/process/next_tick.js:61:11)
        0|mm       | [21:26:17.270] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit
        0|mm       | [21:26:17.271] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 end listeners added. Use emitter.setMaxListeners() to increase limit
        0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 drain listeners added. Use emitter.setMaxListeners() to increase limit
        0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added. Use emitter.setMaxListeners() to increase limit
        0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 data listeners added. Use emitter.setMaxListeners() to increase limit
        0|mm       | [21:26:26.569] [ERROR]  TypeError: Cannot read property 'network' of undefined
        0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
        0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
        0|mm       |     at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
        /home/jojo/.pm2/logs/mm-out.log last 15 lines:
        0|mm       | [21:26:18.772] [LOG]    Connecting socket for: MMM-UKNationalRail
        0|mm       | [21:26:18.772] [LOG]    MMM-UKNationalRail helper started ...
        0|mm       | [21:26:18.773] [LOG]    Connecting socket for: MMM-NetworkScanner
        0|mm       | [21:26:18.773] [LOG]    Starting module: MMM-NetworkScanner
        0|mm       | [21:26:18.773] [LOG]    Sockets connected & modules started ...
        0|mm       | [21:26:18.774] [LOG]
        0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
        0|mm       | [21:26:26.567] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
        0|mm       | [21:26:26.568] [LOG]    MMM-NetworkScanner is performing arp-scan
        0|mm       | [21:26:26.569] [LOG]    Whoops! There was an uncaught exception...
        0|mm       | [21:26:26.575] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm       | [21:26:26.576] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|mm       | [21:26:29.340] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        0|mm       | [21:26:29.375] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
        0|mm       | [21:26:29.441] [LOG]    MMM-NetworkScanner received CONFIG
          sdetweil @jthirasilpa
          @jthirasilpa ok, had to read the sudo module code to find out where it was… cause when I searched I ended up in the wrong place…
          remove the one line I had you add
          do this
          // add these 4 lines
          var options = {
              cachePassword: true,
              prompt: 'Password, ???? ';     // put your password where ???? are (notice the quotes around)
                  var arpHosts = this.config.network || '-l';
                  var arp = sudo(['arp-scan', '-q', arpHosts], options);   // change this line, to add ,options at the end
            jthirasilpa
            @sdetweil said in MMM-NetworkScanner-loading...indefinitely:
            var options = {
            prompt: 'Password, ??? '; // put your password where ??? are (notice the quotes around)
            Thanks - tried that. Got the following log:
            0|mm  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:43
            0|mm  |     prompt: 'Password, mypassword';     // put your password where ???? are (notice the quotes around)
            0|mm  |                               ^
            0|mm  | SyntaxError: Unexpected token ;
            0|mm  |     at Module._compile (internal/modules/cjs/loader.js:723:23)
            0|mm  |     at /home/jojo/MagicMirror/js/app.js:168:6
              @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
              sorry, take off the ‘;’ after the actual password
                jthirasilpa
                Thanks - see error log below
                [22:23:34.736] [ERROR] ReferenceError: options is not defined
                at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                at Socket. (/home/jojo/MagicMirror/js/node_helper.js:113:11)
                [22:24:03.590] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:45:36)
                [22:24:05.534] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                  but you added the 4 lines, right?
                  var options = {
                      prompt: 'Password, ???? '     // put your password where ???? are (notice the quotes around)
                  and then the updated line
                  • karsten13K Offline
                    karsten13
                    what is the result of sudo arp-scan -l running on your machine?
                      @jthirasilpa just do this… get my version of the module
                      cd ~/MagicMirror/modules
                      mv MMM-NetworkScanner MMM-NetworkScanner.original
                      git clone https://github.com/sdetweil/MMM-NetworkScanner
                      cd MMM-NetworkScanner
                      npm install
                      cd ~/MagicMirror/config
                      nano config.js
                      add the following line to the config section of the network scanner module
                      Password: '??????',    // where '?????' is you password in quotes, for example 'raspberry', note the trailing comma
                      ctrl-o at save the config.js
                      ctrl-x to exit nano
                      Restart your MM
                        jthirasilpa @sdetweil
                        Thanks Sam - tried your version of the module and modified the config.js accordingly. Still not quite working. Error logs as follows:
                        0|mm       | [09:41:25.508] [ERROR]  ReferenceError: options is not defined
                        0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                        0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                        0|mm       | [09:41:55.508] [ERROR]  ReferenceError: options is not defined
                        • 6
                        • 4 / 6
