    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 18.1k Views 7 Watching
      jthirasilpa
      Those devices are ethernet connected. Also, I was just checking the logs and there are a lot of ip addresses and:
      0|mm       | [20:52:38.389] [LOG]    MMM-NetworkScanner is performing arp-scan
      0|mm       | [20:52:38.419] [LOG]    MMM-NetworkScanner is performing ip address scan
      but no MAC addresses - which you seem to have in your logs.
        jthirasilpa
        After a complete reinstall of MM, I finally managed to resolve this. After reinstalling the original NetworkScanner module and using macaddresses to add to the config.js, I kept getting the “sudo requires your password” message. I went through node_helper.js and the only command that appears to require sudo is arp-scan. So I amended sudoers to allow sudo arp-scan without password using:
        sudo visudo
        and then adding:
         # Allow arp-scan without sudo
        username ALL=(ALL) NOPASSWD: /usr/sbin/arp-scan
        This allows sudo arp-scan to run without a password, while maintaining password requirements for other sudo commands.
        Many thanks to Sam et. al. for input on this issue.
          sdetweil @jthirasilpa
          @jthirasilpa cool. Thx for the update. Using the updated file w password support should have allowed without sudoers
            DarkZOne
            Hello,
            i want to use this Module, but i’ve a iphone that is after some time offline when the screen is off. I have a perl script that check into my fritzbox (router) if the iphone connected to the fritzbox.
            how can i add the perl script to mmm-networkscanner?
            var arp = sudo([‘arp-scan’, ‘-q’, arpHosts]);
            like var arp = sudo([‘perlscript.pl’]); ??
            Thanks!!
            • 6
            • 6 / 6
