    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 25.1k Views 7 Watching
      jthirasilpa
      That is how the config looks.
      Still getting the node_helper line 42 error. Will park this for now. Thank you for spending so much time on this Sam - much appreciated. Will come back to this later in the week.
        sdetweil @jthirasilpa
        @jthirasilpa update the current code
        cd ~MagicMirror/modules/MMM-NetworkScanner
        git pull
        then you can shutdown and restart the MM app
        there was a tiny timing gap where the config info is not yet set, when the helper is asked to scan the network…
        let me know
        J 1 Reply Last reply
        • O
          OldSunGuy
          Is it bad to have this?
          pi@raspberrypi ~ % sudo -l|grep NOPASS
              (ALL) NOPASSWD: ALL
          pi@raspberrypi ~ %
          Edit: To expand further, I have MMM-NetworkScanner running. I do not need to supply a password when I run sudo and I don’t have a password stored in a config file.
            jthirasilpa @sdetweil
            Hi Sam - thanks I tried the update. Still getting the same error - from the log:
            [19:00:49.868] [ERROR]  TypeError: Cannot read property 'network' of undefined
                at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
                at Socket.emit (events.js:198:13)
                at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                at process._tickCallback (internal/process/next_tick.js:61:11)
              @jthirasilpa do another git pull from my repo… and try again
                Thanks Sam
                Tried update. Error log below:
                [11:45:29.130] [ERROR]  TypeError: Cannot read property 'network' of undefined
                    at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:46:36)
                    at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:33:18)
                Node_helper code:
                        // Target hosts/network supplied in config or entire localnet
                 46         var arpHosts = self.config.network || '-l';
                 47                                 var options = {
                 48                                                 cachePassword: true,
                 49                                                 prompt: 'Password,' + self.config.Password     // put your password where ???? are (notice the quotes around)
                 50                                 }
                 51         var arp = sudo(['arp-scan', '-q', arpHosts]) //, options);
                Module entry in config.js:
                139                         module:                 "MMM-NetworkScanner",
                140                         position:               "bottom_center",
                141                         header:                 "Devices Online",
                142                         config: {
                143                                 devices: [
                144                                 { ipAddress: "192.168.1.11", name: "Champagne", icon: "server"},
                145                                 { ipAddress: "192.168.1.15", name: "Millie", icon: "server"},
                146                                 { ipAddress: "192.168.1.17", name:  "Marmite", icon:  "server"}
                147                                 ],
                148                                 showUnknown: false,
                149                                 showOffline:  true,
                150                                 keepAlive:  600,
                151                                 showLastSeen:  true,
                152                                 updateInterval:  30,
                153                                 Password:  'xxxx'
                154                                 }
                155                 },
                  @jthirasilpa weird…
                  the trace shows, on a timer tick (in the modulename.js) the node+helper received a socket message (sendSocketNotification from modulename.js), and received in node_helper)
                  the notification is correct, and it starts to rescan the network…
                  but, it has lost the config pointer for some reason…
                  weird…
                  please do another git pull
                  also add debug:true,
                  to the module config section
                  let me know
                  thanks
                    jthirasilpa
                    Thanks. Scan seems to find some devices, but does not display them on Mirror.
                    Here is output log:
                    [20:41:24.611] [LOG]    MMM-NetworkScanner is performing arp-scan
                    [20:41:24.650] [LOG]    MMM-NetworkScanner is performing ip address scan
                    [20:41:24.651] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                    [20:41:24.651] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                    [20:41:24.666] [LOG]    MMM-NetworkScanner is checking device:  Millie
                    [20:41:24.667] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                    [20:41:24.667] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                    [20:41:24.690] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                    [20:41:24.691] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                    [20:41:24.705] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                    [20:41:24.707] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                    [20:41:26.741] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                    [20:41:26.743] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                    [20:41:54.605] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                    [20:41:54.605] [LOG]    MMM-NetworkScanner is performing arp-scan
                    [20:41:54.630] [LOG]    MMM-NetworkScanner is performing ip address scan
                    [20:41:54.631] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                    [20:41:54.631] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                    [20:41:54.644] [LOG]    MMM-NetworkScanner is checking device:  Millie
                    [20:41:54.645] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                    [20:41:54.645] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                    [20:41:54.658] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                    [20:41:54.659] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                    [20:41:54.672] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                    [20:41:54.675] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                    [20:41:56.706] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                    [20:41:56.707] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                    Error log:
                    [20:35:38.953] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 error listeners added. Use emitter.setMaxListen        ers() to increase limit
                    [20:35:38.953] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 end listeners added. Use emitter.setMaxListener        s() to increase limit
                    [20:35:38.954] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 drain listeners added. Use emitter.setMaxListen        ers() to increase limit
                    [20:35:38.954] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 close listeners added. Use emitter.setMaxListen        ers() to increase limit
                    [20:35:38.955] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 data listeners added. Use emitter.setMaxListene        rs() to increase limit
                      @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
                      [20:41:24.707] [LOG] MMM-NetworkScanner ping result: [ ‘Champagne’, true ]
                      [20:41:26.741] [LOG] MMM-NetworkScanner ping result: [ ‘Marmite’, false ]
                      [20:41:26.743] [LOG] MMM-NetworkScanner ping result: [ ‘JoJo’, false ]
                      jojo isn’t in the configured list above… so, did u change the config?
                      and it says it will scan all the addresses in the devices list, but millie isn’t pinged…
                      what else do you have in bottom_center? it can get pushed off screen pretty easily…
                        jthirasilpa
                        Thanks - I did change the config to add one device “JoJo” with an IpAddress and I changed “Millie” from IpAddress to MacAddress (I am guessing that is why it is not showing in the ping result - but am not sure). I did not make any other changes to the config (apart from adding the debug line). There is no other bottom_center module and it clearly displays Devices Online “Loading…”, so I don’t think it’s the case that entries are being pushed off the page.
                        142                         config: {
                        143                                 devices: [
                        145                                 { macAddress: "xxxx", name: "Millie", icon: "server"},
                        146                                 { ipAddress: "192.168.1.17", name:  "Marmite", icon:  "server"},
                        147                                 { ipAddress: "192.168.1.70", name: "JoJo", icon: "male"}
                        148                                 ],
                        149                                 showUnknown: false,
                        150                                 showOffline:  true,
                        151                                 keepAlive:  600,
                        152                                 showLastSeen:  true,
                        153                                 updateInterval:  30,
                        154                                 debug: true,
                        155                                 Password:  'xxxx'
                        156                                 }
                        157                 },
                          @jthirasilpa do you have arp-scan installed?
                          Open a terminal window and type
                          sudo arp-scan
                          If not install it. Not part of module.
                          sudo apt-get install arp-scan
                          T J 2 Replies Last reply
                          • T
                            todro @sdetweil
                            Problem is the fact that the CONFIG message is sent from the frontend only at the loading of the page (subclassing START). If the page is still open in the browser it will send SCAN_NETWORK requests periodically which will lead to the situation where the config object is empty when the scan is to be executed, if the service has been restarted meanwhile.
                            Furthermore, if a reload of the page is executed, a CONFIG request is sent to NODE_HELPER which might be busy scanning and it seems as if there is no escape unless the correct sequential order for CONFIG and SCAN_NETWORK is used.
                            To verify:
                            1.) Stop loading of the page in browser or navigate to an other page so no SCAN_NETWORK will be created for the device status updates
                            2.) Stop + restart MM
                            3.) Reload page / enter start URL
                            This will lead to the correct order and the programmatic solution is to check if the config object is filled before executing the scan. If not, it has to be reloaded, the CONFIG request in NODE_HELPER can not be used as it uses the payload from the frontend.
                              sdetweil @todro
                              @todro oh yeh that will be a mess. Hadn’t thought of that, electron will shutdown, but remote page wont
                              That will be a problem for many modules!
                                Hi Sam - yes it is already installed.
                                I treid the steps posted by todro (a couple of times).
                                Here is log output, but MM still shows Devices Online “Loading…”:
                                [19:46:01.569] [LOG]    Use existing news fetcher for url: http://rss.cnn.com/rss/edition.rss
                                [19:46:01.623] [LOG]    MMM-NetworkScanner received CONFIG
                                [19:46:01.623] [LOG]    MMM-NetworkScanner completed CONFIG
                                [19:46:01.625] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:46:01.625] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:46:01.645] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:46:01.646] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:46:01.646] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:46:01.656] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:46:01.657] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:46:01.657] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:46:01.671] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:46:01.672] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:46:01.681] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                [19:46:01.838] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                [19:46:03.674] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                                [19:46:03.685] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                                [19:46:30.817] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:46:30.818] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:46:30.840] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:46:30.841] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:46:30.842] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:46:30.853] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:46:30.855] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:46:30.856] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:46:30.872] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:46:30.873] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:46:30.882] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                [19:46:30.895] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                [19:46:32.875] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                                [19:46:32.901] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                                [19:47:10.155] [LOG]    [SIGINT] Received. Shutting down server...
                                [19:47:10.156] [LOG]    Stopping module helper: updatenotification
                                [19:47:10.156] [LOG]    Stopping module helper: newsfeed
                                [19:47:10.156] [LOG]    Stopping module helper: MMM-UKNationalRail
                                [19:47:10.157] [LOG]    Stopping module helper: MMM-NetworkScanner
                                [19:47:20.881] [LOG]    Starting MagicMirror: v2.10.1
                                [19:47:20.890] [LOG]    Loading config ...
                                [19:47:20.895] [LOG]    Loading module helpers ...
                                [19:47:20.896] [LOG]    No helper found for module: alert.
                                [19:47:20.930] [LOG]    Initializing new module helper ...
                                [19:47:20.931] [LOG]    Module helper loaded: updatenotification
                                [19:47:20.932] [LOG]    No helper found for module: clock.
                                [19:47:20.932] [LOG]    No helper found for module: currentweather.
                                [19:47:21.243] [LOG]    Initializing new module helper ...
                                [19:47:21.243] [LOG]    Module helper loaded: newsfeed
                                [19:47:21.526] [LOG]    Initializing new module helper ...
                                [19:47:21.526] [LOG]    Module helper loaded: MMM-UKNationalRail
                                [19:47:21.526] [LOG]    No helper found for module: MMM-TFL.
                                [19:47:21.555] [LOG]    Initializing new module helper ...
                                [19:47:21.555] [LOG]    Module helper loaded: MMM-NetworkScanner
                                [19:47:21.556] [LOG]    All module helpers loaded.
                                [19:47:21.556] [LOG]    Starting server on port 8080 ...
                                [19:47:21.562] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [19:47:21.569] [LOG]    Server started ...
                                [19:47:21.570] [LOG]    Connecting socket for: updatenotification
                                [19:47:21.571] [LOG]    Connecting socket for: newsfeed
                                [19:47:21.571] [LOG]    Starting module: newsfeed
                                [19:47:21.572] [LOG]    Connecting socket for: MMM-UKNationalRail
                                [19:47:21.572] [LOG]    MMM-UKNationalRail helper started ...
                                [19:47:21.572] [LOG]    Connecting socket for: MMM-NetworkScanner
                                [19:47:21.573] [LOG]    Starting module in node_helper: MMM-NetworkScanner
                                [19:47:21.573] [LOG]    Sockets connected & modules started ...
                                Ready to go! Please point your browser to: http://0.0.0.0:8080
                                [19:47:30.001] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                [19:47:30.035] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
                                [19:47:30.459] [LOG]    MMM-NetworkScanner received CONFIG
                                [19:47:30.460] [LOG]    MMM-NetworkScanner completed CONFIG
                                [19:47:30.473] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:47:30.473] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:47:30.501] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:47:30.502] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:47:30.503] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:47:30.515] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:47:30.515] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:47:30.516] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:47:30.532] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:47:30.533] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:47:30.544] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                sudo requires your password: [19:47:30.558] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                [19:47:32.535] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                                [19:47:32.547] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                                [19:47:59.468] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:47:59.469] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:47:59.489] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:47:59.492] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:47:59.494] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:47:59.504] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:47:59.505] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:47:59.506] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:47:59.514] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:47:59.514] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:47:59.522] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                [19:47:59.525] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                [19:48:01.516] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                                [19:48:01.529] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                                [19:48:26.714] [LOG]    [SIGINT] Received. Shutting down server...
                                [19:48:26.715] [LOG]    Stopping module helper: updatenotification
                                [19:48:26.716] [LOG]    Stopping module helper: newsfeed
                                [19:48:26.716] [LOG]    Stopping module helper: MMM-UKNationalRail
                                [19:48:26.716] [LOG]    Stopping module helper: MMM-NetworkScanner
                                [19:48:33.169] [LOG]    Starting MagicMirror: v2.10.1
                                [19:48:33.179] [LOG]    Loading config ...
                                [19:48:33.183] [LOG]    Loading module helpers ...
                                [19:48:33.185] [LOG]    No helper found for module: alert.
                                [19:48:33.220] [LOG]    Initializing new module helper ...
                                [19:48:33.221] [LOG]    Module helper loaded: updatenotification
                                [19:48:33.221] [LOG]    No helper found for module: clock.
                                [19:48:33.222] [LOG]    No helper found for module: currentweather.
                                [19:48:33.526] [LOG]    Initializing new module helper ...
                                [19:48:33.527] [LOG]    Module helper loaded: newsfeed
                                [19:48:33.809] [LOG]    Initializing new module helper ...
                                [19:48:33.810] [LOG]    Module helper loaded: MMM-UKNationalRail
                                [19:48:33.810] [LOG]    No helper found for module: MMM-TFL.
                                [19:48:33.840] [LOG]    Initializing new module helper ...
                                [19:48:33.840] [LOG]    Module helper loaded: MMM-NetworkScanner
                                [19:48:33.840] [LOG]    All module helpers loaded.
                                [19:48:33.841] [LOG]    Starting server on port 8080 ...
                                [19:48:33.847] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [19:48:33.854] [LOG]    Server started ...
                                [19:48:33.855] [LOG]    Connecting socket for: updatenotification
                                [19:48:33.855] [LOG]    Connecting socket for: newsfeed
                                [19:48:33.856] [LOG]    Starting module: newsfeed
                                [19:48:33.856] [LOG]    Connecting socket for: MMM-UKNationalRail
                                [19:48:33.857] [LOG]    MMM-UKNationalRail helper started ...
                                [19:48:33.857] [LOG]    Connecting socket for: MMM-NetworkScanner
                                [19:48:33.857] [LOG]    Starting module in node_helper: MMM-NetworkScanner
                                [19:48:33.858] [LOG]    Sockets connected & modules started ...
                                [19:48:47.214] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                [19:48:47.247] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
                                [19:48:47.312] [LOG]    MMM-NetworkScanner received CONFIG
                                [19:48:47.313] [LOG]    MMM-NetworkScanner completed CONFIG
                                [19:48:47.314] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:48:47.315] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:48:47.341] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:48:47.342] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:48:47.342] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:48:47.353] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:48:47.353] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:48:47.354] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:48:47.363] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:48:47.364] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:48:47.372] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                sudo requires your password: [19:48:47.686] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                [19:48:49.367] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                                [19:48:49.381] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                                [19:49:16.634] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:49:16.635] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:49:16.657] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:49:16.658] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:49:16.658] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:49:16.669] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:49:16.669] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:49:16.670] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:49:16.679] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:49:16.681] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:49:16.690] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                [19:49:16.702] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                [19:49:18.693] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                                [19:49:18.695] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                                [19:49:46.639] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                [19:49:46.640] [LOG]    MMM-NetworkScanner is performing arp-scan
                                [19:49:46.670] [LOG]    MMM-NetworkScanner is performing ip address scan
                                [19:49:46.670] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                                [19:49:46.670] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                                [19:49:46.680] [LOG]    MMM-NetworkScanner is checking device:  Millie
                                [19:49:46.681] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                                [19:49:46.681] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                                [19:49:46.703] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                                [19:49:46.705] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                                [19:49:46.716] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                                [19:49:46.740] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                                  @jthirasilpa ok. Need to open the developers console, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                  U can also filter by module, by putting part of the module name in the filter field. Network, for example.
                                  The code should be sending messages to the module name.js
                                    This is what is showing in the console…
                                    Load script: modules/MMM-NetworkScanner//MMM-NetworkScanner.js loader.js:179:8
                                    Module registered: MMM-NetworkScanner module.js:476:6
                                    Bootstrapping module: MMM-NetworkScanner loader.js:150:7
                                    Scripts loaded for: MMM-NetworkScanner loader.js:155:8
                                    Load stylesheet: modules/MMM-NetworkScanner/MMM-NetworkScanner.css loader.js:194:8
                                    Styles loaded for: MMM-NetworkScanner loader.js:157:9
                                    Translations loaded for: MMM-NetworkScanner loader.js:159:10
                                    Starting module: MMM-NetworkScanner MMM-NetworkScanner.js:37:7
                                    MMM-NetworkScanner config:
                                    Object { devices: (4) […], network: “-l”, showUnknown: false, showOffline: true, showLastSeen: true, keepAlive: 600, updateInterval: 30, sort: true, residents: [], occupiedCMD: null, … }
                                    MMM-NetworkScanner.js:38:30
                                    MMM-NetworkScanner is initiating network scan MMM-NetworkScanner.js:273:30
                                    MMM-NetworkScanner received a notification: IP_ADDRESS
                                    Object { ipAddress: “192.168.1.11”, name: “Champagne”, icon: “server”, color: “#ffffff”, showOffline: true, online: true }
                                    MMM-NetworkScanner.js:70:30
                                    MMM-NetworkScanner IP_ADDRESS device:
                                    Array [ “Champagne”, true ]
                                    MMM-NetworkScanner.js:80:31
                                    MMM-NetworkScanner is updating device status.
                                    MMM-NetworkScanner.js:284:31
                                    MMM-NetworkScanner Champagne is online MMM-NetworkScanner.js:295:31
                                    Object { ipAddress: “192.168.1.17”, name: “Marmite”, icon: “server”, color: “#ffffff”, showOffline: true, online: false }
                                    Array [ “Marmite”, false ]
                                    MMM-NetworkScanner Marmite is offline MMM-NetworkScanner.js:295:31
                                    Object { ipAddress: “192.168.1.70”, name: “JoJo”, icon: “male”, color: “#ffffff”, showOffline: true, online: false }
                                    Array [ “JoJo”, false ]
                                    MMM-NetworkScanner JoJo is offline MMM-NetworkScanner.js:295:31
                                    color: “#ffffff”
                                    icon: “male”
                                    online: false
                                    showOffline: true
                                    : Object { … }
                                      color: “#ffffff”
                                      icon: “male”
                                      online: false
                                      showOffline: true
                                      : Object { … }
                                      Ok, so the data is making it there…
                                      Can u change the module position to top_left for a test?
                                        jthirasilpa
                                        Hi Sam - yes - changed to top_left. Still “Loading…” If I go into the developers console, and search in the text field for “error” it only brings up the following (although the top of the console indicates that there are 3 errors)
                                        loader.js:203 Error on loading stylesheet: css/custom.css
                                          @jthirasilpa ok, after looking thru the code, I dont see the mac addresses in the modulename.js…
                                          so, can u open a terminal window on the pi and do
                                          sudo arp-scan -l
                                            @sdetweil Here is the scan result:
                                            Interface: enp1s0, datalink type: EN10MB (Ethernet)
                                            Starting arp-scan 1.9 with 256 hosts (http://www.nta-monitor.com/tools/arp-scan/        )
                                            192.168.1.1     f4:f2:6d:9f:72:89       TP-LINK TECHNOLOGIES CO.,LTD.
                                            192.168.1.15    c0:3f:d5:65:06:6f       Elitegroup Computer Systems Co.,Ltd.
                                            192.168.1.50    e0:2f:6d:62:b6:d5       Cisco Systems, Inc
                                            192.168.1.52    00:15:65:70:6b:f9       XIAMEN YEALINK NETWORK TECHNOLOGY CO.,LT        D
                                            192.168.1.53    00:15:65:bb:a0:8d       XIAMEN YEALINK NETWORK TECHNOLOGY CO.,LT        D
                                            192.168.1.101   7c:2f:80:6e:56:ff       Gigaset Communications GmbH
                                            192.168.1.103   78:3e:53:40:9b:97       BSkyB Ltd
                                            192.168.1.105   d8:cb:8a:71:a5:f5       Micro-Star INTL CO., LTD.
                                            192.168.1.108   08:05:81:f5:8c:2e       Roku, Inc.
                                            192.168.1.109   10:62:e5:ac:b9:f7       Hewlett Packard
                                            192.168.1.111   f0:1d:bc:8e:da:fa       Microsoft Corporation
                                            13 packets received by filter, 0 packets dropped by kernel
                                            Ending arp-scan 1.9: 256 hosts scanned in 4.391 seconds (58.30 hosts/sec). 11 re        sponded
                                            • 2 / 3
