    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 25.1k Views 7 Watching
      sdetweil @jthirasilpa
      @jthirasilpa do you have arp-scan installed?
      Open a terminal window and type
      sudo arp-scan
      If not install it. Not part of module.
      sudo apt-get install arp-scan
      T J 2 Replies Last reply
      • T
        todro @sdetweil
        Problem is the fact that the CONFIG message is sent from the frontend only at the loading of the page (subclassing START). If the page is still open in the browser it will send SCAN_NETWORK requests periodically which will lead to the situation where the config object is empty when the scan is to be executed, if the service has been restarted meanwhile.
        Furthermore, if a reload of the page is executed, a CONFIG request is sent to NODE_HELPER which might be busy scanning and it seems as if there is no escape unless the correct sequential order for CONFIG and SCAN_NETWORK is used.
        To verify:
        1.) Stop loading of the page in browser or navigate to an other page so no SCAN_NETWORK will be created for the device status updates
        2.) Stop + restart MM
        3.) Reload page / enter start URL
        This will lead to the correct order and the programmatic solution is to check if the config object is filled before executing the scan. If not, it has to be reloaded, the CONFIG request in NODE_HELPER can not be used as it uses the payload from the frontend.
          sdetweil @todro
          @todro oh yeh that will be a mess. Hadn’t thought of that, electron will shutdown, but remote page wont
          That will be a problem for many modules!
            jthirasilpa @sdetweil
            Hi Sam - yes it is already installed.
            I treid the steps posted by todro (a couple of times).
            Here is log output, but MM still shows Devices Online “Loading…”:
            [19:46:01.569] [LOG]    Use existing news fetcher for url: http://rss.cnn.com/rss/edition.rss
            [19:46:01.623] [LOG]    MMM-NetworkScanner received CONFIG
            [19:46:01.623] [LOG]    MMM-NetworkScanner completed CONFIG
            [19:46:01.625] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:46:01.625] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:46:01.645] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:46:01.646] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:46:01.646] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:46:01.656] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:46:01.657] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:46:01.657] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:46:01.671] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:46:01.672] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:46:01.681] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            [19:46:01.838] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
            [19:46:03.674] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
            [19:46:03.685] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
            [19:46:30.817] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:46:30.818] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:46:30.840] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:46:30.841] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:46:30.842] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:46:30.853] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:46:30.855] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:46:30.856] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:46:30.872] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:46:30.873] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:46:30.882] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            [19:46:30.895] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
            [19:46:32.875] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
            [19:46:32.901] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
            [19:47:10.155] [LOG]    [SIGINT] Received. Shutting down server...
            [19:47:10.156] [LOG]    Stopping module helper: updatenotification
            [19:47:10.156] [LOG]    Stopping module helper: newsfeed
            [19:47:10.156] [LOG]    Stopping module helper: MMM-UKNationalRail
            [19:47:10.157] [LOG]    Stopping module helper: MMM-NetworkScanner
            [19:47:20.881] [LOG]    Starting MagicMirror: v2.10.1
            [19:47:20.890] [LOG]    Loading config ...
            [19:47:20.895] [LOG]    Loading module helpers ...
            [19:47:20.896] [LOG]    No helper found for module: alert.
            [19:47:20.930] [LOG]    Initializing new module helper ...
            [19:47:20.931] [LOG]    Module helper loaded: updatenotification
            [19:47:20.932] [LOG]    No helper found for module: clock.
            [19:47:20.932] [LOG]    No helper found for module: currentweather.
            [19:47:21.243] [LOG]    Initializing new module helper ...
            [19:47:21.243] [LOG]    Module helper loaded: newsfeed
            [19:47:21.526] [LOG]    Initializing new module helper ...
            [19:47:21.526] [LOG]    Module helper loaded: MMM-UKNationalRail
            [19:47:21.526] [LOG]    No helper found for module: MMM-TFL.
            [19:47:21.555] [LOG]    Initializing new module helper ...
            [19:47:21.555] [LOG]    Module helper loaded: MMM-NetworkScanner
            [19:47:21.556] [LOG]    All module helpers loaded.
            [19:47:21.556] [LOG]    Starting server on port 8080 ...
            [19:47:21.562] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [19:47:21.569] [LOG]    Server started ...
            [19:47:21.570] [LOG]    Connecting socket for: updatenotification
            [19:47:21.571] [LOG]    Connecting socket for: newsfeed
            [19:47:21.571] [LOG]    Starting module: newsfeed
            [19:47:21.572] [LOG]    Connecting socket for: MMM-UKNationalRail
            [19:47:21.572] [LOG]    MMM-UKNationalRail helper started ...
            [19:47:21.572] [LOG]    Connecting socket for: MMM-NetworkScanner
            [19:47:21.573] [LOG]    Starting module in node_helper: MMM-NetworkScanner
            [19:47:21.573] [LOG]    Sockets connected & modules started ...
            Ready to go! Please point your browser to: http://0.0.0.0:8080
            [19:47:30.001] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [19:47:30.035] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
            [19:47:30.459] [LOG]    MMM-NetworkScanner received CONFIG
            [19:47:30.460] [LOG]    MMM-NetworkScanner completed CONFIG
            [19:47:30.473] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:47:30.473] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:47:30.501] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:47:30.502] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:47:30.503] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:47:30.515] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:47:30.515] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:47:30.516] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:47:30.532] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:47:30.533] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:47:30.544] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            sudo requires your password: [19:47:30.558] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
            [19:47:32.535] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
            [19:47:32.547] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
            [19:47:59.468] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:47:59.469] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:47:59.489] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:47:59.492] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:47:59.494] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:47:59.504] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:47:59.505] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:47:59.506] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:47:59.514] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:47:59.514] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:47:59.522] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            [19:47:59.525] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
            [19:48:01.516] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
            [19:48:01.529] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
            [19:48:26.714] [LOG]    [SIGINT] Received. Shutting down server...
            [19:48:26.715] [LOG]    Stopping module helper: updatenotification
            [19:48:26.716] [LOG]    Stopping module helper: newsfeed
            [19:48:26.716] [LOG]    Stopping module helper: MMM-UKNationalRail
            [19:48:26.716] [LOG]    Stopping module helper: MMM-NetworkScanner
            [19:48:33.169] [LOG]    Starting MagicMirror: v2.10.1
            [19:48:33.179] [LOG]    Loading config ...
            [19:48:33.183] [LOG]    Loading module helpers ...
            [19:48:33.185] [LOG]    No helper found for module: alert.
            [19:48:33.220] [LOG]    Initializing new module helper ...
            [19:48:33.221] [LOG]    Module helper loaded: updatenotification
            [19:48:33.221] [LOG]    No helper found for module: clock.
            [19:48:33.222] [LOG]    No helper found for module: currentweather.
            [19:48:33.526] [LOG]    Initializing new module helper ...
            [19:48:33.527] [LOG]    Module helper loaded: newsfeed
            [19:48:33.809] [LOG]    Initializing new module helper ...
            [19:48:33.810] [LOG]    Module helper loaded: MMM-UKNationalRail
            [19:48:33.810] [LOG]    No helper found for module: MMM-TFL.
            [19:48:33.840] [LOG]    Initializing new module helper ...
            [19:48:33.840] [LOG]    Module helper loaded: MMM-NetworkScanner
            [19:48:33.840] [LOG]    All module helpers loaded.
            [19:48:33.841] [LOG]    Starting server on port 8080 ...
            [19:48:33.847] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [19:48:33.854] [LOG]    Server started ...
            [19:48:33.855] [LOG]    Connecting socket for: updatenotification
            [19:48:33.855] [LOG]    Connecting socket for: newsfeed
            [19:48:33.856] [LOG]    Starting module: newsfeed
            [19:48:33.856] [LOG]    Connecting socket for: MMM-UKNationalRail
            [19:48:33.857] [LOG]    MMM-UKNationalRail helper started ...
            [19:48:33.857] [LOG]    Connecting socket for: MMM-NetworkScanner
            [19:48:33.857] [LOG]    Starting module in node_helper: MMM-NetworkScanner
            [19:48:33.858] [LOG]    Sockets connected & modules started ...
            [19:48:47.214] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [19:48:47.247] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
            [19:48:47.312] [LOG]    MMM-NetworkScanner received CONFIG
            [19:48:47.313] [LOG]    MMM-NetworkScanner completed CONFIG
            [19:48:47.314] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:48:47.315] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:48:47.341] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:48:47.342] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:48:47.342] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:48:47.353] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:48:47.353] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:48:47.354] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:48:47.363] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:48:47.364] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:48:47.372] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            sudo requires your password: [19:48:47.686] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
            [19:48:49.367] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
            [19:48:49.381] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
            [19:49:16.634] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:49:16.635] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:49:16.657] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:49:16.658] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:49:16.658] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:49:16.669] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:49:16.669] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:49:16.670] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:49:16.679] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:49:16.681] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:49:16.690] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            [19:49:16.702] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
            [19:49:18.693] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
            [19:49:18.695] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
            [19:49:46.639] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            [19:49:46.640] [LOG]    MMM-NetworkScanner is performing arp-scan
            [19:49:46.670] [LOG]    MMM-NetworkScanner is performing ip address scan
            [19:49:46.670] [LOG]    MMM-NetworkScanner is checking device:  Champagne
            [19:49:46.670] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
            [19:49:46.680] [LOG]    MMM-NetworkScanner is checking device:  Millie
            [19:49:46.681] [LOG]    MMM-NetworkScanner is checking device:  Marmite
            [19:49:46.681] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
            [19:49:46.703] [LOG]    MMM-NetworkScanner is checking device:  JoJo
            [19:49:46.705] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
            [19:49:46.716] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
            [19:49:46.740] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
              @jthirasilpa ok. Need to open the developers console, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
              U can also filter by module, by putting part of the module name in the filter field. Network, for example.
              The code should be sending messages to the module name.js
              J 1 Reply Last reply
                This is what is showing in the console…
                Load script: modules/MMM-NetworkScanner//MMM-NetworkScanner.js loader.js:179:8
                Module registered: MMM-NetworkScanner module.js:476:6
                Bootstrapping module: MMM-NetworkScanner loader.js:150:7
                Scripts loaded for: MMM-NetworkScanner loader.js:155:8
                Load stylesheet: modules/MMM-NetworkScanner/MMM-NetworkScanner.css loader.js:194:8
                Styles loaded for: MMM-NetworkScanner loader.js:157:9
                Translations loaded for: MMM-NetworkScanner loader.js:159:10
                Starting module: MMM-NetworkScanner MMM-NetworkScanner.js:37:7
                MMM-NetworkScanner config:
                Object { devices: (4) […], network: “-l”, showUnknown: false, showOffline: true, showLastSeen: true, keepAlive: 600, updateInterval: 30, sort: true, residents: [], occupiedCMD: null, … }
                MMM-NetworkScanner.js:38:30
                MMM-NetworkScanner is initiating network scan MMM-NetworkScanner.js:273:30
                MMM-NetworkScanner received a notification: IP_ADDRESS
                Object { ipAddress: “192.168.1.11”, name: “Champagne”, icon: “server”, color: “#ffffff”, showOffline: true, online: true }
                MMM-NetworkScanner.js:70:30
                MMM-NetworkScanner IP_ADDRESS device:
                Array [ “Champagne”, true ]
                MMM-NetworkScanner.js:80:31
                MMM-NetworkScanner is updating device status.
                MMM-NetworkScanner.js:284:31
                MMM-NetworkScanner Champagne is online MMM-NetworkScanner.js:295:31
                Object { ipAddress: “192.168.1.17”, name: “Marmite”, icon: “server”, color: “#ffffff”, showOffline: true, online: false }
                Array [ “Marmite”, false ]
                MMM-NetworkScanner Marmite is offline MMM-NetworkScanner.js:295:31
                Object { ipAddress: “192.168.1.70”, name: “JoJo”, icon: “male”, color: “#ffffff”, showOffline: true, online: false }
                Array [ “JoJo”, false ]
                MMM-NetworkScanner JoJo is offline MMM-NetworkScanner.js:295:31
                color: “#ffffff”
                icon: “male”
                online: false
                showOffline: true
                : Object { … }
                  @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
                  color: “#ffffff”
                  icon: “male”
                  online: false
                  showOffline: true
                  : Object { … }
                  Ok, so the data is making it there…
                  Can u change the module position to top_left for a test?
                    jthirasilpa
                    Hi Sam - yes - changed to top_left. Still “Loading…” If I go into the developers console, and search in the text field for “error” it only brings up the following (although the top of the console indicates that there are 3 errors)
                    loader.js:203 Error on loading stylesheet: css/custom.css
                      @jthirasilpa ok, after looking thru the code, I dont see the mac addresses in the modulename.js…
                      so, can u open a terminal window on the pi and do
                      sudo arp-scan -l
                        @sdetweil Here is the scan result:
                        Interface: enp1s0, datalink type: EN10MB (Ethernet)
                        Starting arp-scan 1.9 with 256 hosts (http://www.nta-monitor.com/tools/arp-scan/        )
                        192.168.1.1     f4:f2:6d:9f:72:89       TP-LINK TECHNOLOGIES CO.,LTD.
                        192.168.1.15    c0:3f:d5:65:06:6f       Elitegroup Computer Systems Co.,Ltd.
                        192.168.1.50    e0:2f:6d:62:b6:d5       Cisco Systems, Inc
                        192.168.1.52    00:15:65:70:6b:f9       XIAMEN YEALINK NETWORK TECHNOLOGY CO.,LT        D
                        192.168.1.53    00:15:65:bb:a0:8d       XIAMEN YEALINK NETWORK TECHNOLOGY CO.,LT        D
                        192.168.1.101   7c:2f:80:6e:56:ff       Gigaset Communications GmbH
                        192.168.1.103   78:3e:53:40:9b:97       BSkyB Ltd
                        192.168.1.105   d8:cb:8a:71:a5:f5       Micro-Star INTL CO., LTD.
                        192.168.1.108   08:05:81:f5:8c:2e       Roku, Inc.
                        192.168.1.109   10:62:e5:ac:b9:f7       Hewlett Packard
                        192.168.1.111   f0:1d:bc:8e:da:fa       Microsoft Corporation
                        13 packets received by filter, 0 packets dropped by kernel
                        Ending arp-scan 1.9: 256 hosts scanned in 4.391 seconds (58.30 hosts/sec). 11 re        sponded
                          @jthirasilpa change showUnknown: to true in config.js…
                          ip addresses 11, 17, and 70 are not known according to the arp scan
                            jthirasilpa
                            Hi Sam - they were not at the time of the scan, but they have been picked up in console messages previously. For example:
                            Shouldn’t that then show up on the Mirror?
                              @jthirasilpa not my module. Trying to help
                                @sdetweil Hi Sam - I appreciate your assistance. I am actually asking that question legitimately out of ignorance. I assume that if it appears in the console as follows:
                                then it would be show up in the Mirror, but maybe there are several steps in between…
                                In any case - thanks for your help.
                                  @jthirasilpa it matches the IP address with the scanned Mac addresses.
                                  If not in the Mac addresses it is not shown.
                                  In debug mode I get a big blast of the Mac address info displayed every time there is a scan
                                    @sdetweil OK - do not have access to machine now, but will have a look later. Thanks.
                                      This is one of the devices from the config.js
                                      { ipAddress: "192.168.1.11", name: "Champagne", icon: "server"}
                                      Object { ipAddress: "192.168.1.11", name: "Champagne", icon: "server", color: "#ffffff", showOffline: true, online: true }
                                      This is from the console:
                                      Array [ "Champagne", true ]
                                      Strangely when I run sudo arp -scan -l, this device doesn’t appear. But doesn’t the information from the console suggest that it should be displayed?
                                      Conversely, the arp scan does find 192.168.1.15, but console displays this:
                                      Object { ipAddress: "192.168.1.15", name: "Millie", icon: "server", color: "#ffffff", showOffline: true, online: false }
                                      Array [ "Millie", false ]
                                      I would think that one of these would be displayed on the MM.
                                      Any further thoughts? Thanks.
                                        @jthirasilpa are those wireless? The arp scan only did Ethernet connected devices
                                          jthirasilpa
                                          Those devices are ethernet connected. Also, I was just checking the logs and there are a lot of ip addresses and:
                                          0|mm       | [20:52:38.389] [LOG]    MMM-NetworkScanner is performing arp-scan
                                          0|mm       | [20:52:38.419] [LOG]    MMM-NetworkScanner is performing ip address scan
                                          but no MAC addresses - which you seem to have in your logs.
                                            jthirasilpa
                                            After a complete reinstall of MM, I finally managed to resolve this. After reinstalling the original NetworkScanner module and using macaddresses to add to the config.js, I kept getting the “sudo requires your password” message. I went through node_helper.js and the only command that appears to require sudo is arp-scan. So I amended sudoers to allow sudo arp-scan without password using:
                                            sudo visudo
                                            and then adding:
                                             # Allow arp-scan without sudo
                                            username ALL=(ALL) NOPASSWD: /usr/sbin/arp-scan
                                            This allows sudo arp-scan to run without a password, while maintaining password requirements for other sudo commands.
                                            Many thanks to Sam et. al. for input on this issue.
                                            • 3 / 3
