    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 24.7k Views 7 Watching
      jthirasilpa
      Hi Sam - yes - changed to top_left. Still “Loading…” If I go into the developers console, and search in the text field for “error” it only brings up the following (although the top of the console indicates that there are 3 errors)
      loader.js:203 Error on loading stylesheet: css/custom.css
        sdetweil @jthirasilpa
        @jthirasilpa ok, after looking thru the code, I dont see the mac addresses in the modulename.js…
        so, can u open a terminal window on the pi and do
        sudo arp-scan -l
          jthirasilpa @sdetweil
          @sdetweil Here is the scan result:
          Interface: enp1s0, datalink type: EN10MB (Ethernet)
          Starting arp-scan 1.9 with 256 hosts (http://www.nta-monitor.com/tools/arp-scan/        )
          192.168.1.1     f4:f2:6d:9f:72:89       TP-LINK TECHNOLOGIES CO.,LTD.
          192.168.1.15    c0:3f:d5:65:06:6f       Elitegroup Computer Systems Co.,Ltd.
          192.168.1.50    e0:2f:6d:62:b6:d5       Cisco Systems, Inc
          192.168.1.52    00:15:65:70:6b:f9       XIAMEN YEALINK NETWORK TECHNOLOGY CO.,LT        D
          192.168.1.53    00:15:65:bb:a0:8d       XIAMEN YEALINK NETWORK TECHNOLOGY CO.,LT        D
          192.168.1.101   7c:2f:80:6e:56:ff       Gigaset Communications GmbH
          192.168.1.103   78:3e:53:40:9b:97       BSkyB Ltd
          192.168.1.105   d8:cb:8a:71:a5:f5       Micro-Star INTL CO., LTD.
          192.168.1.108   08:05:81:f5:8c:2e       Roku, Inc.
          192.168.1.109   10:62:e5:ac:b9:f7       Hewlett Packard
          192.168.1.111   f0:1d:bc:8e:da:fa       Microsoft Corporation
          13 packets received by filter, 0 packets dropped by kernel
          Ending arp-scan 1.9: 256 hosts scanned in 4.391 seconds (58.30 hosts/sec). 11 re        sponded
            @jthirasilpa change showUnknown: to true in config.js…
            ip addresses 11, 17, and 70 are not known according to the arp scan
              jthirasilpa
              Hi Sam - they were not at the time of the scan, but they have been picked up in console messages previously. For example:
              Shouldn’t that then show up on the Mirror?
                @jthirasilpa not my module. Trying to help
                  @sdetweil Hi Sam - I appreciate your assistance. I am actually asking that question legitimately out of ignorance. I assume that if it appears in the console as follows:
                  Object { ipAddress: “192.168.1.11”, name: “Champagne”, icon: “server”, color: “#ffffff”, showOffline: true, online: true }
                  then it would be show up in the Mirror, but maybe there are several steps in between…
                  In any case - thanks for your help.
                    @jthirasilpa it matches the IP address with the scanned Mac addresses.
                    If not in the Mac addresses it is not shown.
                    In debug mode I get a big blast of the Mac address info displayed every time there is a scan
                      @sdetweil OK - do not have access to machine now, but will have a look later. Thanks.
                        This is one of the devices from the config.js
                        { ipAddress: "192.168.1.11", name: "Champagne", icon: "server"}
                        MMM-NetworkScanner received a notification: IP_ADDRESS
                        Object { ipAddress: "192.168.1.11", name: "Champagne", icon: "server", color: "#ffffff", showOffline: true, online: true }
                        This is from the console:
                        MMM-NetworkScanner.js:70:30
                        MMM-NetworkScanner IP_ADDRESS device:
                        Array [ "Champagne", true ]
                        MMM-NetworkScanner.js:80:31
                        MMM-NetworkScanner is updating device status.
                        MMM-NetworkScanner.js:284:31
                        MMM-NetworkScanner Champagne is online
                        Strangely when I run sudo arp -scan -l, this device doesn’t appear. But doesn’t the information from the console suggest that it should be displayed?
                        Conversely, the arp scan does find 192.168.1.15, but console displays this:
                        Object { ipAddress: "192.168.1.15", name: "Millie", icon: "server", color: "#ffffff", showOffline: true, online: false }
                        Array [ "Millie", false ]
                        I would think that one of these would be displayed on the MM.
                        Any further thoughts? Thanks.
                          @jthirasilpa are those wireless? The arp scan only did Ethernet connected devices
                            jthirasilpa
                            Those devices are ethernet connected. Also, I was just checking the logs and there are a lot of ip addresses and:
                            0|mm       | [20:52:38.389] [LOG]    MMM-NetworkScanner is performing arp-scan
                            0|mm       | [20:52:38.419] [LOG]    MMM-NetworkScanner is performing ip address scan
                            but no MAC addresses - which you seem to have in your logs.
                              jthirasilpa
                              After a complete reinstall of MM, I finally managed to resolve this. After reinstalling the original NetworkScanner module and using macaddresses to add to the config.js, I kept getting the “sudo requires your password” message. I went through node_helper.js and the only command that appears to require sudo is arp-scan. So I amended sudoers to allow sudo arp-scan without password using:
                              sudo visudo
                              and then adding:
                               # Allow arp-scan without sudo
                              username ALL=(ALL) NOPASSWD: /usr/sbin/arp-scan
                              This allows sudo arp-scan to run without a password, while maintaining password requirements for other sudo commands.
                              Many thanks to Sam et. al. for input on this issue.
                                @jthirasilpa cool. Thx for the update. Using the updated file w password support should have allowed without sudoers
                                  DarkZOne
                                  i want to use this Module, but i’ve a iphone that is after some time offline when the screen is off. I have a perl script that check into my fritzbox (router) if the iphone connected to the fritzbox.
                                  how can i add the perl script to mmm-networkscanner?
                                  var arp = sudo([‘arp-scan’, ‘-q’, arpHosts]);
                                  like var arp = sudo([‘perlscript.pl’]); ??
                                  Thanks!!
                                  • 3 / 3
