    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 22.0k Views 7 Watching
      sdetweil @jthirasilpa
      @jthirasilpa change showUnknown: to true in config.js…
      ip addresses 11, 17, and 70 are not known according to the arp scan
        jthirasilpa
        Hi Sam - they were not at the time of the scan, but they have been picked up in console messages previously. For example:
        Shouldn’t that then show up on the Mirror?
          @jthirasilpa not my module. Trying to help
            jthirasilpa @sdetweil
            @sdetweil Hi Sam - I appreciate your assistance. I am actually asking that question legitimately out of ignorance. I assume that if it appears in the console as follows:
            Object { ipAddress: “192.168.1.11”, name: “Champagne”, icon: “server”, color: “#ffffff”, showOffline: true, online: true }
            then it would be show up in the Mirror, but maybe there are several steps in between…
            In any case - thanks for your help.
              @jthirasilpa it matches the IP address with the scanned Mac addresses.
              If not in the Mac addresses it is not shown.
              In debug mode I get a big blast of the Mac address info displayed every time there is a scan
                @sdetweil OK - do not have access to machine now, but will have a look later. Thanks.
                  This is one of the devices from the config.js
                  { ipAddress: "192.168.1.11", name: "Champagne", icon: "server"}
                  MMM-NetworkScanner received a notification: IP_ADDRESS
                  Object { ipAddress: "192.168.1.11", name: "Champagne", icon: "server", color: "#ffffff", showOffline: true, online: true }
                  This is from the console:
                  MMM-NetworkScanner.js:70:30
                  MMM-NetworkScanner IP_ADDRESS device:
                  Array [ "Champagne", true ]
                  MMM-NetworkScanner.js:80:31
                  MMM-NetworkScanner is updating device status.
                  MMM-NetworkScanner.js:284:31
                  MMM-NetworkScanner Champagne is online
                  Strangely when I run sudo arp -scan -l, this device doesn’t appear. But doesn’t the information from the console suggest that it should be displayed?
                  Conversely, the arp scan does find 192.168.1.15, but console displays this:
                  Object { ipAddress: "192.168.1.15", name: "Millie", icon: "server", color: "#ffffff", showOffline: true, online: false }
                  Array [ "Millie", false ]
                  I would think that one of these would be displayed on the MM.
                  Any further thoughts? Thanks.
                    @jthirasilpa are those wireless? The arp scan only did Ethernet connected devices
                      jthirasilpa
                      Those devices are ethernet connected. Also, I was just checking the logs and there are a lot of ip addresses and:
                      0|mm       | [20:52:38.389] [LOG]    MMM-NetworkScanner is performing arp-scan
                      0|mm       | [20:52:38.419] [LOG]    MMM-NetworkScanner is performing ip address scan
                      but no MAC addresses - which you seem to have in your logs.
                        jthirasilpa
                        After a complete reinstall of MM, I finally managed to resolve this. After reinstalling the original NetworkScanner module and using macaddresses to add to the config.js, I kept getting the “sudo requires your password” message. I went through node_helper.js and the only command that appears to require sudo is arp-scan. So I amended sudoers to allow sudo arp-scan without password using:
                        sudo visudo
                        and then adding:
                         # Allow arp-scan without sudo
                        username ALL=(ALL) NOPASSWD: /usr/sbin/arp-scan
                        This allows sudo arp-scan to run without a password, while maintaining password requirements for other sudo commands.
                        Many thanks to Sam et. al. for input on this issue.
                          @jthirasilpa cool. Thx for the update. Using the updated file w password support should have allowed without sudoers
                            DarkZOne
                            i want to use this Module, but i’ve a iphone that is after some time offline when the screen is off. I have a perl script that check into my fritzbox (router) if the iphone connected to the fritzbox.
                            how can i add the perl script to mmm-networkscanner?
                            var arp = sudo([‘arp-scan’, ‘-q’, arpHosts]);
                            like var arp = sudo([‘perlscript.pl’]); ??
                            Thanks!!
                            • 3 / 3
