    MMM-BackgroundSlideshow just shows black screen
    7 Posts 2 Posters 1.7k Views 2 Watching
    • C Offline
      CliffordW
      To start, I just copy/pasted the code directly from the page. I have checked and I have the sample images in the folder. Any ideas what I’m doing wrong?
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: 'MMM-BackgroundSlideshow',
      			position: 'fullscreen-below',
      				imagePaths: ['modules/MMM-BackgroundSlideshow/exampleImages/'],
      				transitionImages: true,
      				slideshowSpeed: 1000, // 1000 is 10 seconds
      				randomizeImageOrder: true
        sdetweil @CliffordW
        @CliffordW said in MMM-BackgroundSlideshow just shows black screen:
        did u do the npm install in the module folder? it has required dependencies…
        usually black screen means something missing
        • C Offline
          CliffordW
          I thought I had, but I did it again. Does the message mean something is ‘wrong’?
          https://imgur.com/ERqHlS6
            sdetweil @CliffordW
            @CliffordW no. That’s ok.
            If you do, npm start dev
            Select the console tab and scroll up to see any errors
            Do u see anything in red?
            C 2 Replies Last reply Reply Quote 0
            • C Offline
              CliffordW @sdetweil
              @sdetweil Considering how early on I am, I’m just going to wipe it clean and start again. Thanks for your help, I’ll be back to let you know either way.
              • C Offline
                CliffordW @sdetweil
                @sdetweil As I suspected. I rebuilt it, and it’s working now. Obviously some kind of newbie error. Thanks again!
                  sdetweil @CliffordW
                  @CliffordW glad u got it working!!
