    ARTICLE_NEXT use Extern
    6 Posts 2 Posters 1.4k Views 2 Watching
    • DerBärD Offline
      DerBär
      How can I use “ARTICLE_NEXT” for next feeds f. e. from bash or ssh terminal?
        sdetweil @DerBär
        @DerBär please explain. Never heard this term
        DerBärD 1 Reply Last reply Reply Quote 0
        • DerBärD Offline
          DerBär @sdetweil
          @sdetweil said in ARTICLE_NEXT use Extern:
          I would like to know about this “command” --> https://docs.magicmirror.builders/modules/newsfeed.html#using-the-module
          I would like to push from terminal a message or command to turn next newsfeed, I think I can use “ARTICLE_NEXT” for that. but how?
            sdetweil @DerBär
            @DerBär ok… got it… you will have to use another module… like MMM-RemoteControl or MMM-Notifications to capture and externally sourced message and turn it into a notification… (ARTICLE_NEXT is a notification the newsreader module is looking for)
            • DerBärD Offline
              DerBär @sdetweil
              you mean I have to use MMM-RemoteControl to push “ARTICLE_NEXT”?
                sdetweil @DerBär
                @DerBär yes
