    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 39.6k Views 16 Watching
    • ? Offline
      A Former User @siggmur
      @siggmur
      Possible to add some sort of scaling?
      What kind of scaling are you meaning? Sorry, I’m not good at English, So more detailed explanation or example be needed.
      • ? Offline
        A Former User @mrdenmark
        @mrdenmark
        Hmmmm… will consider, but for that, You have to describe all regions to be displayed. I’m not sure it’s really useful or convenience or not. (At this moment, total regions might be over 300s. and not regulated in origianl source)
        • ? Offline
          A Former User @luxiouronimo
          @luxiouronimo
          thousands separator is added. comma or period or any characters you can use.
          At this moment, I’m fixing US total bug. Unfortunately, Original Data of Johns Hopkins Univ might have some invalid format data, (It might be fixed sometimes by who discover it), so I will change to handle data more gracefully or safely.
          • ? Offline
            @luxiouronimo
            https://github.com/CSSEGISandData/COVID-19/blob/master/csse_covid_19_data/csse_covid_19_time_series/time_series_19-covid-Recovered.csv#L100
            Hmmm I found what was wrong.
            US and France doesn’t provide recovered data since Mar 17 any more. That’s why current accumulated recovered is 0, and why negative number is shown. I’m not sure it will be fixed or not.
            Have you any good source about this data?
            • L Offline
              luxiouronimo
              that’s awesome; hooraay to thousandsSeparator! thank u thank u!
              sorry i don’t kno of any better sources for stats, this is a huge improvement over the web page i had been refreshing that only had stats for my state…
              thanks for your work =)
                siggmur @Guest
                @Sean no problem, thanks for replying!
                What I mean is a way to make the module smaller in size. As of now, it takes up a lot of screen space. I would love to have to have it smaller in size
                  sdetweil
                  see another tracker with line charts
                  https://forum.magicmirror.builders/topic/12387/covid-bell-curve-line-graph-tracker
                    sdetweil @Guest
                    @Sean if one doesn’t specify the separator, then the module crashes… I changed the source to default to “,”,
                    and then it worked ok
                      sdetweil
                      suddenly getting error
                      [23:33:05.828] [ERROR]  (node:27400) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'trim' of undefined
                          at Covid19.extractRegionKey (/home/pi/MagicMirror/modules/MMM-COVID-19/COVID-19.js:24:34)
                          at gc.files (/home/pi/MagicMirror/modules/MMM-COVID-19/COVID-19.js:69:24)
                      • ? Offline
                        A Former User @sdetweil
                        Maybe original source changed format again.
                        How unstable and irregular… I’m regretting.
                        • ? Offline
                          A Former User @Guest
                          NOTICE FOR NOT SUPPORTING ANYMORE
                          • When I created this module, there was no COVID-19 related modules, so I made it by myself. This module consumes data from the FIRST original root source from Johns Hopkins University Center for Systems Science and Engineering (JHU CCSE) But JHU CCSE changes its data format too often and without notice, so this module is not stable. (I’m very disappointed about JHU CCSS data management)
                          And at this moment, there are at least two working COVID-19 related modules in MagicMirror. So I’ll quit supporting this module. Use alternatives.
                          • MyCovid19
                          • MMM-COVID19
                          Sorry, and thank you for things.
                          • 4 / 4
