    covid bell curve line graph tracker
    89 Posts 6 Posters 75.6k Views 8 Watching
    • H
      humdinger44
      I’m looking for a covid19 module that displays data in a line graph, hopefully representing a bell curve at some point. Bonus points if it lets you pick different countries to show on the same graph in different colors or something.
      before you grab your pitchforks and lock the thread, to my knowledge this does NOT yet exist. If it does please show me where.
      Be good y’all.
        sdetweil @humdinger44
        @humdinger44 here u go
        https://github.com/sdetweil/MyCovid19
        two charts… cumulative cases and cumulative deaths, currently can display only 1 chart at a time
        US is about 7 weeks behind China, Italy about 5 weeks behind
        alt text
        Reply Quote 3
          @humdinger44 nobody is producing line charts currently.
            sdetweil
            I am trying to build such a tool now… (cause I want it too)
              @humdinger44
              first pass
              China, Italy, US cases since 1/1/2020
              (can also do deaths, and cumulative)
              would update daily
              have lots of config work to do yet
              alt text
              H 1 Reply Last reply
              • H
                humdinger44 @sdetweil
                @sdetweil love it! thanks for your efforts
                  alt text
                  Reply Quote 3
                    @humdinger44 you can now run two instances to get both charts
                    git pull in the module folder if already installed
                    alt text
                    • H
                      @sdetweil I got it working this morning after your latest update. Thanks for making this, its exactly what i was hoping for.
                        @humdinger44 cool… some country names with spaces (or popular abbreviations) need special handling… so if u find one that doesn’t display, let me know
                        the US data is reported under ‘United_States_of_America’, which no one would ever use…
                        so I have handling for US, USA, and “United States”
                        this will refresh about 2am next day… (if u keep your system running all day)
                        • H
                          @sdetweil one thing i did do on my system is switch your background color from ‘black’ to ‘transparent’ because that works a little better with my setup.
                          Thanks again
                          S 3 Replies Last reply
                            @humdinger44 yeh, I have images displayed and the chart washes out in transparent mode, but thats why I added the setting
                            oops… didn’t add that to the doc
                            in config
                            backgroundColor: ‘???’ color name/id/value
                              @humdinger44 also, if u have a mouse on the system , you should be able to hover over the line and see the raw numbers used
                              Reply Quote 1
                                @humdinger44 I just posted fixes for resume from sleep when multiple module instances are running (and multiple browsers watching screen)
                                git pull in module folder to update, no config changes
                                added backgroundColor config to doc
                                  @sdetweil @humdinger44 another set of fixes for handling names with spaces and not found names (no crash)
                                  added abbrev for UK (instead of ‘United_Kingdom’)
                                  ‘United Kingdom’ works (notice space vs underscore)
                                    sdetweil
                                    another fix to erase the downloaded file,
                                    u can cleanup by erasing the xlsx files
                                    rm ~/MagicMirror/*.xlsx
                                      sdetweil
                                      another update, NOW refresh will work! sorry
                                      Reply Quote 1
                                      • H
                                        @sdetweil This really is great. If you can easily add a individual states (US) I would like to see how my state is doing compared to the national numbers. Its obviously not realistic to display 50 states at once but one or two would be nice. If its a whole big thing don’t worry about it
                                          @humdinger44 the data source I have doesn’t have areas inside countries, so I cannot add that
                                          refresh is broken(I guessed new data would be available at 2am, wasn’t until 7am! oops)… testing fix now
                                          Reply Quote 1
                                            sdetweil
                                            update for refresh when no data available, keep trying!
                                              sdetweil
                                              another fix for refresh (starting after midnight , but no data available yet left a blank display)…
                                              also fixed to add two more charts
                                              new cases and new deaths by day
                                              new cases for the US ‘may’ show effect of distancing… need more days
                                              (or maybe not, one day drop)
                                              todays data, 2020-03-26, is still not yet posted…(as of 8:40 am central time us)
                                              2020-03-26 data has arrived, 08:56 us central time, (and update worked!)
                                              alt text
                                              A 1 Reply Last reply
                                              Reply Quote 1
                                              • 1 / 5
