    covid bell curve line graph tracker
    89 Posts 6 Posters 72.7k Views 8 Watching
    • H Offline
      humdinger44 @sdetweil
      @sdetweil one thing i did do on my system is switch your background color from ‘black’ to ‘transparent’ because that works a little better with my setup.
      Thanks again
      S 3 Replies Last reply Reply Quote 0
        sdetweil @humdinger44
        @humdinger44 yeh, I have images displayed and the chart washes out in transparent mode, but thats why I added the setting
        oops… didn’t add that to the doc
        in config
        backgroundColor: ‘???’ color name/id/value
          @humdinger44 also, if u have a mouse on the system , you should be able to hover over the line and see the raw numbers used
            @humdinger44 I just posted fixes for resume from sleep when multiple module instances are running (and multiple browsers watching screen)
            git pull in module folder to update, no config changes
            added backgroundColor config to doc
              @sdetweil @humdinger44 another set of fixes for handling names with spaces and not found names (no crash)
              added abbrev for UK (instead of ‘United_Kingdom’)
              ‘United Kingdom’ works (notice space vs underscore)
                another fix to erase the downloaded file,
                u can cleanup by erasing the xlsx files
                rm ~/MagicMirror/*.xlsx
                  another update, NOW refresh will work! sorry
                  H 1 Reply Last reply Reply Quote 1
                  • H Offline
                    @sdetweil This really is great. If you can easily add a individual states (US) I would like to see how my state is doing compared to the national numbers. Its obviously not realistic to display 50 states at once but one or two would be nice. If its a whole big thing don’t worry about it
                      @humdinger44 the data source I have doesn’t have areas inside countries, so I cannot add that
                      refresh is broken(I guessed new data would be available at 2am, wasn’t until 7am! oops)… testing fix now
                        update for refresh when no data available, keep trying!
                          another fix for refresh (starting after midnight , but no data available yet left a blank display)…
                          also fixed to add two more charts
                          new cases and new deaths by day
                          new cases for the US ‘may’ show effect of distancing… need more days
                          (or maybe not, one day drop)
                          todays data, 2020-03-26, is still not yet posted…(as of 8:40 am central time us)
                          2020-03-26 data has arrived, 08:56 us central time, (and update worked!)
                          alt text
                          A 1 Reply Last reply Reply Quote 1
                            almostgithub @sdetweil
                            @sdetweil kind of a simple question, but i cannot for the life of me figure out how to change the color of the dates, and the countries names to white?? I looked everywhere and tried my custom css file to no avail…
                              sdetweil @almostgithub
                              @almostgithub >change the color of the dates, and the countries names to white??
                              sorry, don’t understand… they are white already (not bright white)
                              I currently don’t provide access to those settings…
                              this is all controlled by the charting library I am using…
                              I would have to add settings to enable access
                                @almostgithub Ok I’ve added some.
                                git pull in the module folder,
                                here are the things u can set… will get to the doc in the morning
                                    legendTextColor:'white',
                                    chartTitleColor: 'white',
                                    chart_title: '',
                                    xAxisLabel:"by date",
                                    xAxisLabelColor:'white',
                                    xAxisTickLabelColor:'white',
                                    yAxisLabel:"Count",
                                    yAxisLabelColor:'white',
                                    yAxisTickLabelColor:'white',
                                  @sdetweil oh wow! Thanks so much, thats awesome!! They are grey on my mirror and makes it hard to read the legend and dates.
                                  edit: after a git pull and npm install, it seems to be stuck on MyCovid19 Loading data for chart “cumulative_deaths”
                                  edit: Saw this in the issues tab, will ask there
                                    new update, data source changed … after git pull, need to run npm install again to update the library used to read the data (csv instead of xlsx)
                                    • H Offline
                                      @sdetweil can you drop an example of the config for two graphs displayed at once?
                                      Edit: nevermind, I was overthinking it.
                                        grrr… data source not yet updated today… waiting, sent them a note…
                                        I switched to the csv file (available earlier)…
                                        now xlsx is right, csv, json and xml files not updated… and in the xlsx, they changed the column headings…
                                          @sdetweil after sending email, they have updated the csv file now…
                                          also, uploaded new version with lots of text formatting control, see the now long readme
                                          also added ability to change the start date for the chart, see startDate in the readme
                                            now supports states charts too
                                            git pull,
                                            in config states:[] vs countries:[]
                                            alt text
                                            • 1 / 5
