    covid bell curve line graph tracker
    89 Posts 6 Posters 73.8k Views 8 Watching
      @humdinger44
      first pass
      China, Italy, US cases since 1/1/2020
      (can also do deaths, and cumulative)
      would update daily
      have lots of config work to do yet
      alt text
      • H Offline
        humdinger44 @sdetweil
        @sdetweil love it! thanks for your efforts
          sdetweil @humdinger44
          @humdinger44 here u go
          https://github.com/sdetweil/MyCovid19
          two charts… cumulative cases and cumulative deaths, currently can display only 1 chart at a time
          US is about 7 weeks behind China, Italy about 5 weeks behind
          alt text
          S 1 Reply Last reply Reply Quote 3
            @humdinger44 you can now run two instances to get both charts
            git pull in the module folder if already installed
            alt text
            • H Offline
              @sdetweil I got it working this morning after your latest update. Thanks for making this, its exactly what i was hoping for.
                @humdinger44 cool… some country names with spaces (or popular abbreviations) need special handling… so if u find one that doesn’t display, let me know
                the US data is reported under ‘United_States_of_America’, which no one would ever use…
                so I have handling for US, USA, and “United States”
                this will refresh about 2am next day… (if u keep your system running all day)
                • H Offline
                  @sdetweil one thing i did do on my system is switch your background color from ‘black’ to ‘transparent’ because that works a little better with my setup.
                  Thanks again
                  S 3 Replies Last reply Reply Quote 0
                    @humdinger44 yeh, I have images displayed and the chart washes out in transparent mode, but thats why I added the setting
                    oops… didn’t add that to the doc
                    in config
                    backgroundColor: ‘???’ color name/id/value
                      @humdinger44 also, if u have a mouse on the system , you should be able to hover over the line and see the raw numbers used
                        @humdinger44 I just posted fixes for resume from sleep when multiple module instances are running (and multiple browsers watching screen)
                        git pull in module folder to update, no config changes
                        added backgroundColor config to doc
                          @sdetweil @humdinger44 another set of fixes for handling names with spaces and not found names (no crash)
                          added abbrev for UK (instead of ‘United_Kingdom’)
                          ‘United Kingdom’ works (notice space vs underscore)
                            another fix to erase the downloaded file,
                            u can cleanup by erasing the xlsx files
                            rm ~/MagicMirror/*.xlsx
                              another update, NOW refresh will work! sorry
                              H 1 Reply Last reply Reply Quote 1
                              • H Offline
                                @sdetweil This really is great. If you can easily add a individual states (US) I would like to see how my state is doing compared to the national numbers. Its obviously not realistic to display 50 states at once but one or two would be nice. If its a whole big thing don’t worry about it
                                  @humdinger44 the data source I have doesn’t have areas inside countries, so I cannot add that
                                  refresh is broken(I guessed new data would be available at 2am, wasn’t until 7am! oops)… testing fix now
                                    update for refresh when no data available, keep trying!
                                      another fix for refresh (starting after midnight , but no data available yet left a blank display)…
                                      also fixed to add two more charts
                                      new cases and new deaths by day
                                      new cases for the US ‘may’ show effect of distancing… need more days
                                      (or maybe not, one day drop)
                                      todays data, 2020-03-26, is still not yet posted…(as of 8:40 am central time us)
                                      2020-03-26 data has arrived, 08:56 us central time, (and update worked!)
                                      alt text
                                      A 1 Reply Last reply Reply Quote 1
                                        almostgithub @sdetweil
                                        @sdetweil kind of a simple question, but i cannot for the life of me figure out how to change the color of the dates, and the countries names to white?? I looked everywhere and tried my custom css file to no avail…
                                          sdetweil @almostgithub
                                          @almostgithub >change the color of the dates, and the countries names to white??
                                          sorry, don’t understand… they are white already (not bright white)
                                          I currently don’t provide access to those settings…
                                          this is all controlled by the charting library I am using…
                                          I would have to add settings to enable access
                                            @almostgithub Ok I’ve added some.
                                            git pull in the module folder,
                                            here are the things u can set… will get to the doc in the morning
                                                legendTextColor:'white',
                                                chartTitleColor: 'white',
                                                chart_title: '',
                                                xAxisLabel:"by date",
                                                xAxisLabelColor:'white',
                                                xAxisTickLabelColor:'white',
                                                yAxisLabel:"Count",
                                                yAxisLabelColor:'white',
                                                yAxisTickLabelColor:'white',
                                            • 1 / 5
