    covid bell curve line graph tracker
    89 Posts 6 Posters 62.2k Views 8 Watching
    • H Offline
      humdinger44 @sdetweil
      @sdetweil love it! thanks for your efforts
        sdetweil @humdinger44
        @humdinger44 here u go
        https://github.com/sdetweil/MyCovid19
        two charts… cumulative cases and cumulative deaths, currently can display only 1 chart at a time
        US is about 7 weeks behind China, Italy about 5 weeks behind
        alt text
        S 1 Reply Last reply Reply Quote 3
          @humdinger44 you can now run two instances to get both charts
          git pull in the module folder if already installed
          alt text
          • H Offline
            @sdetweil I got it working this morning after your latest update. Thanks for making this, its exactly what i was hoping for.
              @humdinger44 cool… some country names with spaces (or popular abbreviations) need special handling… so if u find one that doesn’t display, let me know
              the US data is reported under ‘United_States_of_America’, which no one would ever use…
              so I have handling for US, USA, and “United States”
              this will refresh about 2am next day… (if u keep your system running all day)
              • H Offline
                @sdetweil one thing i did do on my system is switch your background color from ‘black’ to ‘transparent’ because that works a little better with my setup.
                Thanks again
                S 3 Replies Last reply Reply Quote 0
                  @humdinger44 yeh, I have images displayed and the chart washes out in transparent mode, but thats why I added the setting
                  oops… didn’t add that to the doc
                  in config
                  backgroundColor: ‘???’ color name/id/value
                    @humdinger44 also, if u have a mouse on the system , you should be able to hover over the line and see the raw numbers used
                      @humdinger44 I just posted fixes for resume from sleep when multiple module instances are running (and multiple browsers watching screen)
                      git pull in module folder to update, no config changes
                      added backgroundColor config to doc
                        @sdetweil @humdinger44 another set of fixes for handling names with spaces and not found names (no crash)
                        added abbrev for UK (instead of ‘United_Kingdom’)
                        ‘United Kingdom’ works (notice space vs underscore)
                        • 1 / 9
