    Turn HDMI on/off problem
    5 Posts 4 Posters 1.4k Views 4 Watching
      MilkShake
      I know I am going to be flamed for asking this, but here goes…
      I am trying to implement a PIR sensor on a Raspi 4b to turn on the HDMI output when activated. I have read page up and down of this issue and have seen different possible solutions, but nothing that works for me.
      I can use tvservice -o to turn off HDMI just fine. When I use tvservice -p again, the monitor turns on, but remains only with backlight.
      I have read something about adding a resistor on the powercable for the monitor, but have anyone found a solution to this? Is it because I am using a specific monitor or is this a general problem?
      Best regards
      Lars
      • BKeyportB Offline
        BKeyport Module Developer
        you may have to use one of the other methods - every device is a little odd.
          MilkShake
          I found a solution for my monitor SAMSUNG S24F354 using:
          DISPLAY=:0 xset dpms force on
          DISPLAY=:0 xset dpms force off
          This seems to work right now from the shell. Turns the monitor instantly off/on. Last night when trying with the PIR script, it didn’t work however, returning an error when calling shell scripts: the server was lacking dpms. This must be because DPMS was turned off as a part of the MagicMirror configuration.
          I have a fresh install right now and just verified that these commands actually works. Now to get the PIR sensor working with the shell scripts.
          • ? Offline
            A Former User
            If someone want to test, il will try to code it in my pir module
              sdetweil @MilkShake
              @MilkShake dpms is off because u asked to turn off screensaver.
