    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 11.5k Views 7 Watching
    • F
      ftap @TheRedhawk
      @TheRedhawk Post up the module portion of the config file. Might be an error in there.
      • T
        TheRedhawk @ftap
        @ftap
        Hi ftap,
        it is still the same. it is the only module im running now, even if i change the ’ into " it dont work. If i use any other module with API’s like “mmm-weatherforcast or mmm-fuel etc.” everything works fine. It’s only this module.
        Nodejs = v15.6.0.
        MagicMirror = v2.14.0
        npm = v7.4.0
        var config = {
        	address: "localhost",
        	port: 8080,
        	basePath: "/",
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
        	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
        	language: "de",
        	timeFormat: 24,
        	units: "metric",
        	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                	module: 'MMM-CoinMarketCap',
                    	header: "Crypto",
                        	apiKey: 'myapikey12345678980',
                        	currencies: ['bitcoin', 'ethereum', 'litecoin', 'stellar'],
                        	view: 'graphWithChanges',
                        	conversion: 'EUR',
        • F
          ftap @TheRedhawk
          @TheRedhawk Strange, I wonder why mine breaks with single quotes. If I change mine back to single quotes, it won’t load.
