    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 11.6k Views 7 Watching
    • L
      Linus68
      got it, after update module.
        DavidJ @AvatarED007
        @AvatarED007 Thank you.
        • E
          enjoynering
          Have you solve the problem?
          In my case it is loading… all the time.
          • F
            ftap
            For anyone that finds this topic while trying to trouble shoot constant loading:
            Where it says: ‘your api key here’
            Change it to double quotes: “your api key here”
            Doing this made the module work for me.
            • T
              TheRedhawk
              Hey guxy,
              could someone please post how it works? I updated all, got a new APIkey but it still dont work.
              My code in config.js:
              module: ‘MMM-CoinMarketCap’,
              position: “top_left”,
              header: “Crypto”,
              apiKey: ‘APIKEY APIKEY’,
              currencies: [‘bitcoin’, ‘ethereum’, ‘litecoin’, ‘stellar’],
              view: ‘graphWithChanges’,
              conversion: ‘EUR’,
              F 1 Reply Last reply
              • F
                ftap @TheRedhawk
                @TheRedhawk
                Replace ‘APIKEY’, with “APIKEY”,
                  sdetweil @ftap
                  @ftap which quote doesnt matter
                  careful , dont use quotes that are curved, which are word processing. mm requires text type
                  single or dual
                  • T
                    TheRedhawk
                    Hi there, thanks.
                    Got it, i did the edit in Greany… this dont work. User the text editor and it runs. :-)
                    • F
                      ftap @sdetweil
                      @sdetweil Ah, it didn’t work with single quotes for me. Double quotes fixed it.
                      shrug
                      • T
                        TheRedhawk
                        Hm, it only works once. After the next reboot/Refresh got the same “unable to get date”.
                        What is wrong? Could someone help me here? Mybe with a remot session… I really dont know what the problem is.
                        • F
                          ftap @TheRedhawk
                          @TheRedhawk Post up the module portion of the config file. Might be an error in there.
                          T 1 Reply Last reply
                          • T
                            TheRedhawk @ftap
                            @ftap
                            Hi ftap,
                            it is still the same. it is the only module im running now, even if i change the ’ into " it dont work. If i use any other module with API’s like “mmm-weatherforcast or mmm-fuel etc.” everything works fine. It’s only this module.
                            Nodejs = v15.6.0.
                            MagicMirror = v2.14.0
                            npm = v7.4.0
                            var config = {
                            	address: "localhost",
                            	port: 8080,
                            	basePath: "/",
                            	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
                            	language: "de",
                            	timeFormat: 24,
                            	units: "metric",
                            	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                                    	module: 'MMM-CoinMarketCap',
                                        	header: "Crypto",
                                            	apiKey: 'myapikey12345678980',
                                            	currencies: ['bitcoin', 'ethereum', 'litecoin', 'stellar'],
                                            	view: 'graphWithChanges',
                                            	conversion: 'EUR',
                            • F
                              ftap @TheRedhawk
                              @TheRedhawk Strange, I wonder why mine breaks with single quotes. If I change mine back to single quotes, it won’t load.
