    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 8.9k Views 7 Watching
    • H Offline
      hermlam
      Same problem here
        AvatarED007
        I have the same issue. Also multiple reboot did not help.
        Still message “Unable to get data from CoinMarketCap.com.”
          AvatarED007
          I updated to new version, and requested the API Key, Changed the config file and added the apiKey from CoinMarketCap.com. Also rebooted the MagicMirror.
          I still get the message : “Please provide an API key”
          • L Offline
            Linus68
            Does any one know a other Module to run.
            I need the coins with graph and the tendency in color (red, green).
              AvatarED007
              You have to change the Documentation an move the apiKey to the config part.
              In the java-script you check on self.config.apiKey
              H D 2 Replies Last reply Reply Quote 0
              • H Offline
                hermlam @AvatarED007
                @AvatarED007 Thanks!
                • L Offline
                  Linus68
                  @AvatarED007
                  ?? can you please explain more detailed.
                  • L Offline
                    Linus68
                    got it, after update module.
                      DavidJ @AvatarED007
                      @AvatarED007 Thank you.
                      • E Offline
                        enjoynering
                        Have you solve the problem?
                        In my case it is loading… all the time.
