    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 9.0k Views 7 Watching
    • L Offline
      Linus68
      Thanks for the feedback.
      Some days ago I had also the problem, but after some reboots it was working. But now still not working. Then lets wait and see.
      • H Offline
        hermlam
        Same problem here
          AvatarED007
          I have the same issue. Also multiple reboot did not help.
          Still message “Unable to get data from CoinMarketCap.com.”
            AvatarED007
            I updated to new version, and requested the API Key, Changed the config file and added the apiKey from CoinMarketCap.com. Also rebooted the MagicMirror.
            I still get the message : “Please provide an API key”
            • L Offline
              Linus68
              Does any one know a other Module to run.
              I need the coins with graph and the tendency in color (red, green).
                AvatarED007
                You have to change the Documentation an move the apiKey to the config part.
                In the java-script you check on self.config.apiKey
                H D 2 Replies Last reply Reply Quote 0
                • H Offline
                  hermlam @AvatarED007
                  @AvatarED007 Thanks!
                  • L Offline
                    Linus68
                    @AvatarED007
                    ?? can you please explain more detailed.
                    • L Offline
                      Linus68
                      got it, after update module.
                        DavidJ @AvatarED007
                        @AvatarED007 Thank you.
