    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 9.7k Views 7 Watching
      AvatarED007
      I updated to new version, and requested the API Key, Changed the config file and added the apiKey from CoinMarketCap.com. Also rebooted the MagicMirror.
      I still get the message : “Please provide an API key”
      • L Offline
        Linus68
        Does any one know a other Module to run.
        I need the coins with graph and the tendency in color (red, green).
          AvatarED007
          You have to change the Documentation an move the apiKey to the config part.
          In the java-script you check on self.config.apiKey
          H D 2 Replies Last reply Reply Quote 0
          • H Offline
            hermlam @AvatarED007
            @AvatarED007 Thanks!
            • L Offline
              Linus68
              @AvatarED007
              ?? can you please explain more detailed.
              • L Offline
                Linus68
                got it, after update module.
                  DavidJ @AvatarED007
                  @AvatarED007 Thank you.
                  • E Offline
                    enjoynering
                    Have you solve the problem?
                    In my case it is loading… all the time.
                    • F Offline
                      ftap
                      For anyone that finds this topic while trying to trouble shoot constant loading:
                      Where it says: ‘your api key here’
                      Change it to double quotes: “your api key here”
                      Doing this made the module work for me.
                      • T Offline
                        TheRedhawk
                        Hey guxy,
                        could someone please post how it works? I updated all, got a new APIkey but it still dont work.
                        My code in config.js:
                        module: ‘MMM-CoinMarketCap’,
                        position: “top_left”,
                        header: “Crypto”,
                        apiKey: ‘APIKEY APIKEY’,
                        currencies: [‘bitcoin’, ‘ethereum’, ‘litecoin’, ‘stellar’],
                        view: ‘graphWithChanges’,
                        conversion: ‘EUR’,
                        • F Offline
                          ftap @TheRedhawk
                          @TheRedhawk
                          Replace ‘APIKEY’, with “APIKEY”,
                            sdetweil @ftap
                            @ftap which quote doesnt matter
                            careful , dont use quotes that are curved, which are word processing. mm requires text type
                            single or dual
                            • T Offline
                              TheRedhawk
                              Hi there, thanks.
                              Got it, i did the edit in Greany… this dont work. User the text editor and it runs. :-)
                              • F Offline
                                ftap @sdetweil
                                @sdetweil Ah, it didn’t work with single quotes for me. Double quotes fixed it.
                                shrug
                                • T Offline
                                  TheRedhawk
                                  Hm, it only works once. After the next reboot/Refresh got the same “unable to get date”.
                                  What is wrong? Could someone help me here? Mybe with a remot session… I really dont know what the problem is.
                                  • F Offline
                                    ftap @TheRedhawk
                                    @TheRedhawk Post up the module portion of the config file. Might be an error in there.
                                    • T Offline
                                      TheRedhawk @ftap
                                      @ftap
                                      Hi ftap,
                                      it is still the same. it is the only module im running now, even if i change the ’ into " it dont work. If i use any other module with API’s like “mmm-weatherforcast or mmm-fuel etc.” everything works fine. It’s only this module.
                                      Nodejs = v15.6.0.
                                      MagicMirror = v2.14.0
                                      npm = v7.4.0
                                      var config = {
                                      	address: "localhost",
                                      	port: 8080,
                                      	basePath: "/",
                                      	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
                                      	language: "de",
                                      	timeFormat: 24,
                                      	units: "metric",
                                      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                                              	module: 'MMM-CoinMarketCap',
                                                  	header: "Crypto",
                                                      	apiKey: 'myapikey12345678980',
                                                      	currencies: ['bitcoin', 'ethereum', 'litecoin', 'stellar'],
                                                      	view: 'graphWithChanges',
                                                      	conversion: 'EUR',
                                      • F Offline
                                        ftap @TheRedhawk
                                        @TheRedhawk Strange, I wonder why mine breaks with single quotes. If I change mine back to single quotes, it won’t load.
