    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 11.7k Views 7 Watching
    • L
      Linus68
      Hello
      after reboot my MMM-CoinMarketCap module shows message "Unable to get data from CoinMarketCap.com.
      Several reboot, reduce to one coin, nothing helps.
      Someone any idea? Is it running by someone else?
        DavidJ
        Same. ‘git pull’ indicated that code was up to date. Hopefully a temporary issue at coinmarketcap?
        • L
          Linus68
          Thanks for the feedback.
          Some days ago I had also the problem, but after some reboots it was working. But now still not working. Then lets wait and see.
          • H
            hermlam
            Same problem here
            • A
              AvatarED007
              I have the same issue. Also multiple reboot did not help.
              Still message “Unable to get data from CoinMarketCap.com.”
              • A
                AvatarED007
                I updated to new version, and requested the API Key, Changed the config file and added the apiKey from CoinMarketCap.com. Also rebooted the MagicMirror.
                I still get the message : “Please provide an API key”
                • L
                  Linus68
                  Does any one know a other Module to run.
                  I need the coins with graph and the tendency in color (red, green).
                  • A
                    AvatarED007
                    You have to change the Documentation an move the apiKey to the config part.
                    In the java-script you check on self.config.apiKey
                    H D 2 Replies Last reply
                    • H
                      hermlam @AvatarED007
                      @AvatarED007 Thanks!
                      • L
                        Linus68
                        @AvatarED007
                        ?? can you please explain more detailed.
                        • L
                          Linus68
                          got it, after update module.
                            DavidJ @AvatarED007
                            @AvatarED007 Thank you.
                            • E
                              enjoynering
                              Have you solve the problem?
                              In my case it is loading… all the time.
                              • F
                                ftap
                                For anyone that finds this topic while trying to trouble shoot constant loading:
                                Where it says: ‘your api key here’
                                Change it to double quotes: “your api key here”
                                Doing this made the module work for me.
                                • T
                                  TheRedhawk
                                  Hey guxy,
                                  could someone please post how it works? I updated all, got a new APIkey but it still dont work.
                                  My code in config.js:
                                  module: ‘MMM-CoinMarketCap’,
                                  position: “top_left”,
                                  header: “Crypto”,
                                  apiKey: ‘APIKEY APIKEY’,
                                  currencies: [‘bitcoin’, ‘ethereum’, ‘litecoin’, ‘stellar’],
                                  view: ‘graphWithChanges’,
                                  conversion: ‘EUR’,
                                  F 1 Reply Last reply
                                  • F
                                    ftap @TheRedhawk
                                    @TheRedhawk
                                    Replace ‘APIKEY’, with “APIKEY”,
                                      sdetweil @ftap
                                      @ftap which quote doesnt matter
                                      careful , dont use quotes that are curved, which are word processing. mm requires text type
                                      single or dual
                                      • T
                                        TheRedhawk
                                        Hi there, thanks.
                                        Got it, i did the edit in Greany… this dont work. User the text editor and it runs. :-)
                                        • F
                                          ftap @sdetweil
                                          @sdetweil Ah, it didn’t work with single quotes for me. Double quotes fixed it.
                                          shrug
                                          • T
                                            TheRedhawk
                                            Hm, it only works once. After the next reboot/Refresh got the same “unable to get date”.
                                            What is wrong? Could someone help me here? Mybe with a remot session… I really dont know what the problem is.
