    MMM-CoinMarketCap unable to get data
    23 Posts 8 Posters 11.5k Views 7 Watching
    • A
      AvatarED007
      I have the same issue. Also multiple reboot did not help.
      Still message “Unable to get data from CoinMarketCap.com.”
      • A
        AvatarED007
        I updated to new version, and requested the API Key, Changed the config file and added the apiKey from CoinMarketCap.com. Also rebooted the MagicMirror.
        I still get the message : “Please provide an API key”
        • L
          Linus68
          Does any one know a other Module to run.
          I need the coins with graph and the tendency in color (red, green).
          • A
            AvatarED007
            You have to change the Documentation an move the apiKey to the config part.
            In the java-script you check on self.config.apiKey
            H D 2 Replies Last reply Reply Quote 0
            • H
              hermlam @AvatarED007
              @AvatarED007 Thanks!
              • L
                Linus68
                @AvatarED007
                ?? can you please explain more detailed.
                • L
                  Linus68
                  got it, after update module.
                    DavidJ @AvatarED007
                    @AvatarED007 Thank you.
                    • E
                      enjoynering
                      Have you solve the problem?
                      In my case it is loading… all the time.
                      • F
                        ftap
                        For anyone that finds this topic while trying to trouble shoot constant loading:
                        Where it says: ‘your api key here’
                        Change it to double quotes: “your api key here”
                        Doing this made the module work for me.
                        • T
                          TheRedhawk
                          Hey guxy,
                          could someone please post how it works? I updated all, got a new APIkey but it still dont work.
                          My code in config.js:
                          module: ‘MMM-CoinMarketCap’,
                          position: “top_left”,
                          header: “Crypto”,
                          apiKey: ‘APIKEY APIKEY’,
                          currencies: [‘bitcoin’, ‘ethereum’, ‘litecoin’, ‘stellar’],
                          view: ‘graphWithChanges’,
                          conversion: ‘EUR’,
                          • F
                            ftap @TheRedhawk
                            @TheRedhawk
                            Replace ‘APIKEY’, with “APIKEY”,
                              sdetweil @ftap
                              @ftap which quote doesnt matter
                              careful , dont use quotes that are curved, which are word processing. mm requires text type
                              single or dual
                              • T
                                TheRedhawk
                                Hi there, thanks.
                                Got it, i did the edit in Greany… this dont work. User the text editor and it runs. :-)
                                • F
                                  ftap @sdetweil
                                  @sdetweil Ah, it didn’t work with single quotes for me. Double quotes fixed it.
                                  shrug
                                  • T
                                    TheRedhawk
                                    Hm, it only works once. After the next reboot/Refresh got the same “unable to get date”.
                                    What is wrong? Could someone help me here? Mybe with a remot session… I really dont know what the problem is.
                                    • F
                                      ftap @TheRedhawk
                                      @TheRedhawk Post up the module portion of the config file. Might be an error in there.
                                      • T
                                        TheRedhawk @ftap
                                        @ftap
                                        Hi ftap,
                                        it is still the same. it is the only module im running now, even if i change the ’ into " it dont work. If i use any other module with API’s like “mmm-weatherforcast or mmm-fuel etc.” everything works fine. It’s only this module.
                                        Nodejs = v15.6.0.
                                        MagicMirror = v2.14.0
                                        npm = v7.4.0
                                        var config = {
                                        	address: "localhost",
                                        	port: 8080,
                                        	basePath: "/",
                                        	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
                                        	language: "de",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                                                	module: 'MMM-CoinMarketCap',
                                                    	header: "Crypto",
                                                        	apiKey: 'myapikey12345678980',
                                                        	currencies: ['bitcoin', 'ethereum', 'litecoin', 'stellar'],
                                                        	view: 'graphWithChanges',
                                                        	conversion: 'EUR',
                                        • F
                                          ftap @TheRedhawk
                                          @TheRedhawk Strange, I wonder why mine breaks with single quotes. If I change mine back to single quotes, it won’t load.
