    RasPi 4 installation issues - npm does not support Node.js v10.15.2
    3 Posts 2 Posters 1.1k Views 2 Watching
    • F Offline
      fyi2
      DISPLAY=:0 npm start
      npm WARN npm npm does not support Node.js v10.15.2
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      npm ERR! path /home/pi/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2020-03-16T19_00_45_685Z-debug.log
      pi@raspberrypi:~ $ sudo amixer cset numid=3 1
      numid=3,iface=MIXER,name='PCM Playback Route'
        ; type=INTEGER,access=rw------,values=1,min=0,max=3,step=0
        : values=1
      pi@raspberrypi:~ $
      I try to start MM with DISPLAY=:0 npm start but I get a complaint:npm does not support Node.js v10.15.2 However RasPi
      • F Offline
        fyi2
        However RasPi does not appear to support npm does not support Node.js v10.15.2 does antone know the work around?
          sdetweil @fyi2
          @fyi2 said in RasPi 4 installation issues - npm does not support Node.js v10.15.2:
          u need to be in the MagicMirror fold then do
          export DISPLAY=:0
          npm start
          the issue u see is a warning
