    MMM-GooglePhotos now says 'Loading...' in bottom right
    mmm-googlephotosloading
    7 Posts 3 Posters 2.7k Views 4 Watching
    • 0 Offline
      0YXmEQ
      2 things have changed since my Google Photos module stopped working.
      1. I change my Google Password
      2. I updated MMM-GooglePhotos
      For 1 deleted the token.json and went back through the authorization routine. Got a new token and authorized the app. Nothing out of the ordinary there
      For 2 did a normal update (git pull, npm install, …)
      Now I have no images and ‘Loading…’. It’s been this way for 24 hours.
      Ideas?
      • ? Offline
        A Former User @0YXmEQ
        @0YXmEQ
        Check your log what happened.
        • N Offline
          NathTheDude
          Hey @0YXmEQ , were you able to fix this?
          @Sean , where can I find the log? Thanks
          0 1 Reply Last reply Reply Quote 0
          • 0 Offline
            0YXmEQ @NathTheDude
            @NathTheDude
            MESA-LOADER: failed to retrieve device information
            in my /home/pi/.pm2/logs/mm-error.log
            Looking into that it’s a libGL error not sure if that’s it.
            edit:
            apt-get upgrade didn’t fix it digging deeper
            • 0 Offline
              0YXmEQ
              magicmirror@2.10.1 start /home/pi/MagicMirror
              ./run-start.sh “dev”
              [18:16:17.394] [LOG] Starting MagicMirror: v2.10.1
              [18:16:17.426] [LOG] Loading config …
              [18:16:17.447] [LOG] Loading module helpers …
              [18:16:17.453] [LOG] No helper found for module: internet-monitor.
              [18:16:17.456] [LOG] No helper found for module: alert.
              [18:16:17.639] [LOG] Initializing new module helper …
              [18:16:17.642] [LOG] Module helper loaded: updatenotification
              [18:16:17.645] [LOG] No helper found for module: clock.
              [18:16:18.582] [LOG] Initializing new module helper …
              [18:16:18.584] [LOG] Module helper loaded: MMM-GooglePhotos
              [18:16:18.587] [LOG] No helper found for module: MMM-forecast-io.
              [18:16:18.588] [LOG] All module helpers loaded.
              [18:16:18.591] [LOG] Starting server on port 8080 …
              [18:16:18.638] [LOG] Server started …
              [18:16:18.642] [LOG] Connecting socket for: updatenotification
              [18:16:18.646] [LOG] Connecting socket for: MMM-GooglePhotos
              [18:16:18.649] [LOG] Sockets connected & modules started …
              [18:16:19.103] [LOG] Launching application.
              Well that wasn’t helpful
              • 0 Offline
                0YXmEQ
                Had to use the new config format on the in the module readme. Now it’s working in the top_right working through how to use the custom.css to make it the background image.
                position: “fullscreen_below” //Still works good enough for now
                Is this how custom.css is done?
                #GPHOTO_CURRENT {
                background-size:cover;
                .clock {
                padding: 10px;
                background-color: rgba(0, 0, 0, 0.5);
                body {
                • ? Offline
                  @0YXmEQ
                  So, still have problem? Or tell me more details what you have done and what you have expected and what you get now. Screenshot will be also the help to understand the problem.
