    MM on Pi Zero fails after being off for a few days
    27 Posts 2 Posters 9.6k Views 2 Watching
      sdetweil @kellogg76
      @kellogg76 i have a system that is like that… power messes up everything…
      I have moved to boot from sd card, RUN from ssd…
      https://jamesachambers.com/raspberry-pi-4-usb-boot-config-guide-for-ssd-flash-drives/
      see starting here
      USB Boot Instructions
      • K Offline
        kellogg76 @sdetweil
        @sdetweil I renamed the old MM directory and ran your script
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        Everything went successfully, I can see the display from other computers but the pi just sits at a terminal prompt, is there something I need to do to start things off?
        $ pm2 list
        │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
        │ 1  │ MagicMirror             │ 2.10.1  │ fork    │ 568      │ 2m     │ 1    │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
          sdetweil @kellogg76
          @kellogg76 did u install chromium-browser
          the run-start.sh script depends on it
          • K Offline
            kellogg76 @sdetweil
            @sdetweil Yes, and then rebooted for good measure. Could it be anything to do with me running Raspbian Lite and not Desktop?
              sdetweil @kellogg76
              @kellogg76 you MUST run desktop for chromium to work…
              from the shell, do
              pgrep Xorg
              it should return a number
              • K Offline
                kellogg76 @sdetweil
                @sdetweil It seemed to work well without it in the past, has something changed?
                I always found the Desktop version really laggy on the Zero so try to avoid it when not necessary.
                  sdetweil @kellogg76
                  @kellogg76 no idea… never tried lite
                  you can certainly run serveronly… as u did and the run-start.sh executes…
                  if you try to run chromium-browser
                  what happens? on my pi0w desktop it comes up as expected
