    Update MMM
    75 Posts 8 Posters 53.9k Views 9 Watching
      mattx38
      This update broke a lot of things… What a pain !
        sdetweil @mattx38
        @mattx38 for hotword, from the hotword doc, try
        in the MMm_Hotword folder
        git clone https://github.com/Kitt-AI/snowboy.git
        cd snowboy
        rm -rf .git
        cp -r resources/models ..
        npm install -y nan node-pre-gyp
        ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
        npm install -y
        npm install -y electron-rebuild
        ./node_modules/.bin/electron-rebuild
        its because electron changed versions… some modules are compiled at certain node and electron versions
        if u change the versions (how would u know), then these modules break… Hotword and PIR are two such modules…
          mattx38
          Now it is the Jarvis Assitant :
          [2020-04-01 22:22:29.776] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
          Expected directory: electron-v6.1-linux-arm-glibc
          Found: [electron-v3.1-linux-arm-glibc, node-v64-linux-arm-glibc]
          This problem can often be fixed by running “npm rebuild” on the current system
          Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
          Require stack:
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/index.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/assistant.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js
          • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
          • /home/pi/MagicMirror/js/app.js
          • /home/pi/MagicMirror/js/electron.js
          • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            sdetweil @mattx38
            @mattx38 said in Update MMM:
            MMM-AssistantMk2
            yep assistant… same problem as hotword… incompatible binary versions
            assistant doc
            Then, you need to rebuild grpc module for electron of MagicMirror.
            npm install --save-dev electron-rebuild
              sdetweil
              for pir-sensor try
              cd ~/MagicMirror
              npm install electron-rebuild
                mattx38 @sdetweil
                @sdetweil said in Update MMM:
                MMM-AssistantMk2
                assistant doc
                For the last command, it is very long to achieve ; 5 minutes that it runs.
                It’s written : Building module : grpc, Completed: 0
                  sdetweil @mattx38
                  @mattx38 every machine is different… I ignore how long it takes…
                  did i work?
                    mattx38
                    Don’t know yet.
                    Did I do something wrong with the update ?
                    Everything seams to be broken…
                    Anyway, thank you very much for your precious help and sorry for my poor english (I’m from France)
                      sdetweil @mattx38
                      @mattx38 no issue… the ‘default’ instructions don’t consider all the other things that will break.
                      even my upgrade script does not handle these problems… as they are so module specific…
                      my french is a LOT worse than your english!..
                        mattx38
                        Ok I understand.
                        I saw a message on the Remote Control module github and it seams there is also a problem with it after the MMM update.
                        My MagicMirror was running as a charm till this update. I saw the alert on the MM screen so I did it… what a shame
                          mattx38
                          It is still running, but nothing changed into the terminal.
                          After the command “npm install --save-dev electron-rebuild” I had this message :
                          • electron-rebuild@1.10.1
                            updated 2 packages and audited 822 packages in 16.302s
                          3 packages are looking for funding
                          run npm fund for details
                          found 9 low severity vulnerabilities
                          run npm audit fix to fix them, or npm audit for details
                          Should I run “npm fund” and “npm audit fix” before launching the second command ?
                            sdetweil @mattx38
                            @mattx38 no, those won’t help anything
                              sdetweil @mattx38
                              @mattx38 did u disable pir-sensor?
                              are there still problems (dev window, terminal window?)
                                mattx38
                                Yes I disabled it.
                                Can I run a new Putty window while the rebuild of Assistant is running, to check ?
                                  sdetweil @mattx38
                                  @mattx38 sure
                                    mattx38
                                    [2020-04-01 23:02:44.155] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary modu le because it was not installed for the current system
                                    Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk 2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc _node.node’
                                    Require stack:
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_exten sion.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_int erceptors.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/co mponents/assistant.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/in dex.js
                                    • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai n.js
                                      sdetweil @mattx38
                                      @mattx38 i’m sorry, now out of my depth of solutions… you’ll have to get @Sean (MMM-AssistantMk2 author) involved…
                                        mattx38
                                        Ok, thanks for your help so far.
                                        The rebuilding is not done yet ; still running.
                                          mattx38
                                          Rebuild is done for the Assistant. The MM is launnching again. I didn’t try to activate it by saying “Jarvis” (everyone is sleeping at home).
                                          I put PIR module ON, black screen again, and still this error :
                                          [2020-04-01 23:30:25.054] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
                                          was compiled against a different Node.js version using
                                          NODE_MODULE_VERSION 64. This version of Node.js requires
                                          NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                                          the module (for instance, using npm rebuild or npm install).
                                          EDIT : So I did a “npm install” into the MMM-PIR-Sensor folder, and now it works again.
                                          A very big THANK YOU to YOU !!!
                                            sdetweil @mattx38
                                            @mattx38 cool. My update script would have fixed PIR problem. But not assistant or hotword
                                            • 2 / 4
