    sqlite - anyone use it?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    14 Posts 3 Posters 4.7k Views 3 Watching
      sdetweil @bobt
      @bobt i don’t know
      u might be able to put in in the base, and then change your require to include the path to the ~/MagicMirror/node_modules/sqlite version
      • PerlchampP Offline
        Perlchamp
        @bobt
        did u find a solution for your problem ?
        S B 2 Replies Last reply Reply Quote 0
          sdetweil @Perlchamp
          @Perlchamp you should create a package.json for the module
          by doing npm init in the module folder, and answering the setup questins.
          the questions only add text to the package.json, nothing else
          and then
          then install your dependencies
          npm install --save sqlite3
          –save means add this to the package.json dependencies section
          when u are done, you can send the package.json to another person,
          and they can run npm install in the module folder and get the same
          supporting code installed for this module
          and if you asked for a SPECIFIC version of some library,
          that would be recorded in the package.json too, so the other user would get
          the same level of the dependency
            bobt @Perlchamp
            @Perlchamp
            Thanks everyone for your help. What I was doing was using MMM-MarineWeather By Grena https://github.com/grenagit
            as a template to create a MarineTides version. In my simplicity I was loading the tide predictions from NOAA into a table and trying to use sqlite. The problems caused me to do a better job. Now I link to the NOAA website for the info. This allows the module to get the tide info from any (US) location. Works well. I’ll clean it up and try to add it to Git. May need help with that.
            Thanks again.
