    calendar stuck at loading
    11 Posts 3 Posters 3.9k Views 1 Watching
    • V Offline
      VinGroot
      I recently updated my MagicMirror. Since then my calendar isn’t working anymore.
      I don’t see any errors when I try pm2 logs mm.
      When I try node debug.js it stops after showing some appointments and a line.
      Create fetcher ...
      Create fetcher done!
      [ { title: '******',
          startDate: '1586880000000',
          endDate: '1586883600000',
          fullDayEvent: false,
          class: undefined,
          firstYear: 2020,
          geo: false,
          description: false },
        { title: '******',
          startDate: '1598590800000',
          endDate: '1598594400000',
          class: undefined,
          firstYear: 2020,
          geo: false,
          description: false } ]
      I also tried a complete a reinstall, same effect.
      I’m using a Raspberry Pi 3 A+.
      • O Offline
        Omeliel
        Hi . In the comand promp try to go in modules and there run again npm install . See if is workin. I dont have a clue but worth a try :) . Cheers
          sdetweil @VinGroot
          @VinGroot those are the only two events it finds in the calendar, i think they are in the past.
          • V Offline
            VinGroot @sdetweil
            @sdetweil These are not the only two appointments in the calendar. I only showed two appointments, so you get an idea what it looks like. And even if they were the only two and in the past, then I would get something like: “no future appointments” on my main screen.
            I forgot to mention that “node debug.js” gets stuck as well. I don’t get a prompt after the line.
            • V Offline
              VinGroot @Omeliel
              @Omeliel I gave it a try. Didn’t work.
              • V Offline
                VinGroot
                I cleared my entire calendar to be certain there were no appointments that would cause the problem, problem still occurs.
                I can download basic.ics without a problem.
                • V Offline
                  VinGroot
                  I’ve done some more testing and I figured out that must be some option in my config.js that causes my problem.
                  My calendar works when I load the config.js.sample and paste the url of my calendar in it.
                  Guess I’ll have to do troubleshooting to do…
                  (no worries about the calender link, I will change it after I’m done testing. It has some bogus appointments in it.)
                  header: "Agenda",
                  	broadcastEvents: false,
                  	calendars: [{
                  		url: "https://calendar.google.com/calendar/ical/gjv.de.groot%40gmail.com/private-5652f141b7d1dbb385f50a786a34827a/basic.ics"
                  	dateFormat: "D MMMM YYYY",
                  	fade: false,
                  	getRelative: 0,
                  	hidePrivate: true,
                  	maximumEntries: 8,
                  	maximumNumberOfDays: 7,
                  	maxTitleLength: 50,
                  	showEnd: true,
                  	showLocation: true,
                  	timeFormat: "absolute",
                  	urgency: 1,
                  	useRelativeDates: false
                    sdetweil @VinGroot
                    @VinGroot it looks forward only maximumNumberOfDays: 7, and only for urgency: 1, type one entries
                    • V Offline
                      VinGroot
                      This post is deleted!
                      • V Offline
                        VinGroot
                        I’ve copied all options and the calendar still works. Problem solved, but no clue what the problem was…
                        I’d like to thank everyone eho helped me figuring this out.
