    folder monitor/ file creation...
    10 Posts 2 Posters 1.7k Views 3 Watching
      banbutcher
      Hi folks,
      i was just wondering if its possible to have a module that monitors a folder for new files/downloads and prints the last say 5 or 10 results on the mirror?
      many thanks,
      Richie
        sdetweil @banbutcher
        @banbutcher sure in the node_helper you woudl use the fs.watch() function to watch for files in a directory
        and it will call the routine when files are added or deleted
        i use this i one of my modules
        	// watch for a file to appear in the folder
        					fs.watch(self.config.detectionDir, (eventType, filename) => {
        						if (filename) {
        then when the file arrives, you would sendsocketNotification up to the module.js to display it
        you could use my sample module
        https://github.com/sdetweil/SampleModule
        and use the code above instead of checking for the configured message and have your idea running a few minutes
          banbutcher
          @sdetweil thanks for the reply, unfortunately all that is a little bit above my head atm, any chance you’d have a link or some info on how to implement the code?
          Richie
            @banbutcher sorry, nothing more than what I have already given…
            look up fs.watch() (its just a google search away)
            and then u have to understand how modules work, read the doc and look at my sample.
            i could clarify the code from before
            fs.watch(folder_name,
                    callback_function(eventType, filename) {
            	    if (filename) {
              banbutcher
              i have it partly working… i have the contents displaying on my mirror but its all showing up on one line, how can i display it with each line break as in txt file?
              deluge.js:
              Module.register("deluge",{
              	defaults: {
              		updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
              	start: function(){
              		this.sendSocketNotification("START", this.config);
              		if(notification === "DATA"){
              			this.dataFile = payload;
              			this.updateDom();
              	getDom: function(){
              		if(this.dataFile){
              			wrapper.innerHTML = this.dataFile;
              		} else {
              			wrapper.innerHTML = "No data";
              		return wrapper;
              and my node helper.js
              const NodeHelper = require("node_helper");
              const fs= require("fs");
              //here comes the part of the nodehelper after the 3 dots as posted above
              		if(notification === "START"){
              			this.config = payload;
              			this.readData();
                  			setInterval(() => {
                      			this.readData();
                  			}, this.config.updateInterval);
              	readData: function(){
              		//to read a file to do the following
              		fs.readFile("new-tv-list.txt", "utf8", (err, data) => {
              			if (err) throw err;
              			this.sendSocketNotification("DATA", data);
              thanks
                @banbutcher said in folder monitor/ file creation...:
                  if(this.dataFile){
                  } else {
                if the content you are injecting in NOT html, then you should use innerText…
                it might recognize the line ends as such… they are not line ends in html
                if the innerText doesn’t work, then u will have to convert the line ends t html line breaks
                replace '\n\ with ‘
                note that html is NOT UTF 8
                  banbutcher
                  here is the script that im using to retreve file names…
                  #!/bin/bash
                  TARGET=/media/TheVault/UnWatched/
                  PROCESSED=/media/TheVault/Torrentopia/Torrent-Files/
                  inotifywait -m -e create -e moved_to -r --format "%f" $TARGET \
                          | while read FILENAME
                                  do
                                          echo Detected $FILENAME, Adding to list...
                                          echo $FILENAME | cat - $PROCESSED/new-tv-list.txt > temp && mv temp $PROCESSED/new-tv-list.txt
                  #                        echo $FILENAME `date` >> $PROCESSED/new-tv-list.txt
                  			cp $PROCESSED/new-tv-list.txt /home/pi/MagicMirror/new-tv-list.txt
                                  done
                  if i take out the utf8 part i get an [object array buffer] instead of my file names…
                  B S 2 Replies Last reply Reply Quote 0
                    banbutcher @banbutcher
                    @banbutcher
                    so i put back in the utf8 and then added <br> after i echo the filename and now its working fine now, i need to tweek it more to suit my needs but so far so good! thanks for your help @sdetweil im sure ill be asking more silly questions again soon! :)
                      no such thing… ask away…
                        @banbutcher you can also convert the buffer to a string
                        buffer_object.toString()
