    Send data from a local web page to a magic mirror module
    4 Posts 2 Posters 881 Views
      sergiozf
      Hi, I would like to send data (temperature, switch or PIR status) from a local web page installed in a computer to a magic mirror module which I am programming dedicated to process that information. So, pleasse how can I start?. Thanks in advance.
        sdetweil @sergiozf
        @sergiozf what do you mean from a web page?
        U mean some api? you entered data in the web page form, sent to a server, then on to mm?
          sergiozf @sdetweil
          @sdetweil I have a local web page runnig on a computer where I need to watch those data connected to several sensors which I want to send their data to a MM Module, using websocket to connect with module notification.
            sdetweil @sergiozf
            @sergiozf where is it getting the data from?
            Can it websocket send to mm module too?
            Use the node ws library
            https://www.npmjs.com/package/ws
            Listen and receive in the node helper. Send up to the module
