    Activating HTTPS causes black screen
    10 Posts 5 Posters 2.1k Views 5 Watching
    • nzrunnerN
      nzrunner
      I am running Magic Mirror 2.11.0 on a Pi 4. Runs beautifully. Really impressed.
      Now, I am trying to configure it so it uses HTTPS. I have obtained the required .key and .crt files, and dropped them into a folder that MagicMirror can access.
      When I change config.js to be as follows, I get a black screen: -
      useHttps: true,
      httpsPrivateKey: "ssl/mirror.key",
      httpsCertificate: "ssl/mirror.crt",
      By returning useHttps to false, MagicMirroir runs perfectly again, but obviously only using HTTP.
      Any ideas why activating HTTPS causes a black screen?
        sdetweil @nzrunner
        @nzrunner
        And dropped them into a folder that MagicMirror can access
        U mean the ~/MagicMirror/ssl folder?
        Cause that is what your config said
        • nzrunnerN
          nzrunner
          Yes. I created a folder under MagicMirror called ssl for the certs
          • karsten13K
            karsten13
            AFAIK this is not possible in the current release, but in the upcoming v2.12.0.
            So you
            • can wait until 1.7.2020 or
            • use the develop branch where this is already included or
            • patch the electron.js as described here
              sdetweil @karsten13
              @karsten13 the changelog says it should work
              nzrunnerN 1 Reply Last reply Reply Quote 0
              • nzrunnerN
                nzrunner @sdetweil
                @sdetweil said in Activating HTTPS causes black screen:
                I had read the Changelog as well, and noticed the following entry: -
                • Add HTTPS support and update config.js.sample
                @karsten13 I am happy to wait for the v2.12.0 release. 1st July isn’t that far away ;-)
                  sdetweil @nzrunner
                  @nzrunner July 1, every 3 months a new release
                  • R
                    rafhtl @sdetweil
                    Hi Sam
                    just wanted to tell you that I am using devel and https works fine
                    BUT
                    it took me some time to understand this:
                    in js/electron.js
                    in line
                    18
                    should be
                    app.commandLine.appendSwitch(“autoplay-policy”, ‘true’);
                    app.commandLine.appendSwitch(“no-user-gesture-required”, ‘true’);
                    app.commandLine.appendSwitch(“disable-site-isolation-trials”, ‘true’);
                    app.commandLine.appendSwitch(“ignore-certificate-errors”, ‘true’);
                    app.commandLine.appendSwitch(‘allow-insecure-localhost’, ‘true’);
                    and ofcourse in config also add tls: true
                    let me know if this turns out to be correct
                    as soon as I did this it started working
                    thanks
                    r
                    • B
                      br4tt3 @rafhtl
                      @rafhtl - could you elaborate on the part of the tls: true in the config file? I cant seem to find any reference to that specific config param. I added the changes that you mention in the electron.js file - with the same result as previously, pitch black screen as soon as i am running on https.
                      checking the “output” from a remote connection (e.g remote control module) it works over htpps - but for the physical screen its pitch black!
                      thanks!
                      • karsten13K
                        karsten13 @br4tt3
                        There are 2 use cases for which was https implemented:
                        • serveronly
                        • clientonly
                        This use case with output from the pi on the screen and accessing the mm url’s with https was never implemented.
                        The above hack from @rafhtl seems not to work with the current electron version.
                        You can get it working if you put the following lines under the line with mainWindow = new BrowserWindow(electronOptions); in js/electron.js:
                        mainWindow.webContents.session.setCertificateVerifyProc((request, callback) => {
                            callback(0); //this means trust this domain
                        And electron must use https so you have to change the prefix in the following lines to https in the else section or put tls: true, in the config.js.
                        I’m interested in this usecase because I see nothing what could be protected with https. Everybody who knows your url e.g. https://192.168.0.33:8080/ has full access to your config calling https://192.168.0.33:8080/config/ and can see all your secrets, so I would never run MM in public without protection.
