    Activating HTTPS causes black screen
    10 Posts 5 Posters 1.7k Views 5 Watching
      sdetweil @nzrunner
      @nzrunner
      And dropped them into a folder that MagicMirror can access
      U mean the ~/MagicMirror/ssl folder?
      Cause that is what your config said
      • nzrunnerN Offline
        nzrunner
        Yes. I created a folder under MagicMirror called ssl for the certs
        • karsten13K Offline
          karsten13
          AFAIK this is not possible in the current release, but in the upcoming v2.12.0.
          So you
          • can wait until 1.7.2020 or
          • use the develop branch where this is already included or
          • patch the electron.js as described here
            sdetweil @karsten13
            @karsten13 the changelog says it should work
            nzrunnerN 1 Reply Last reply Reply Quote 0
            • nzrunnerN Offline
              nzrunner @sdetweil
              @sdetweil said in Activating HTTPS causes black screen:
              I had read the Changelog as well, and noticed the following entry: -
              • Add HTTPS support and update config.js.sample
              @karsten13 I am happy to wait for the v2.12.0 release. 1st July isn’t that far away ;-)
                sdetweil @nzrunner
                @nzrunner July 1, every 3 months a new release
                  rafhtl @sdetweil
                  Hi Sam
                  just wanted to tell you that I am using devel and https works fine
                  BUT
                  it took me some time to understand this:
                  in js/electron.js
                  in line
                  18
                  should be
                  app.commandLine.appendSwitch(“autoplay-policy”, ‘true’);
                  app.commandLine.appendSwitch(“no-user-gesture-required”, ‘true’);
                  app.commandLine.appendSwitch(“disable-site-isolation-trials”, ‘true’);
                  app.commandLine.appendSwitch(“ignore-certificate-errors”, ‘true’);
                  app.commandLine.appendSwitch(‘allow-insecure-localhost’, ‘true’);
                  and ofcourse in config also add tls: true
                  let me know if this turns out to be correct
                  as soon as I did this it started working
                  thanks
                  r
                    br4tt3 @rafhtl
                    @rafhtl - could you elaborate on the part of the tls: true in the config file? I cant seem to find any reference to that specific config param. I added the changes that you mention in the electron.js file - with the same result as previously, pitch black screen as soon as i am running on https.
                    checking the “output” from a remote connection (e.g remote control module) it works over htpps - but for the physical screen its pitch black!
                    thanks!
                      karsten13 @br4tt3
                      There are 2 use cases for which was https implemented:
                      • serveronly
                      • clientonly
                      This use case with output from the pi on the screen and accessing the mm url’s with https was never implemented.
                      The above hack from @rafhtl seems not to work with the current electron version.
                      You can get it working if you put the following lines under the line with mainWindow = new BrowserWindow(electronOptions); in js/electron.js:
                      mainWindow.webContents.session.setCertificateVerifyProc((request, callback) => {
                          callback(0); //this means trust this domain
                      And electron must use https so you have to change the prefix in the following lines to https in the else section or put tls: true, in the config.js.
                      I’m interested in this usecase because I see nothing what could be protected with https. Everybody who knows your url e.g. https://192.168.0.33:8080/ has full access to your config calling https://192.168.0.33:8080/config/ and can see all your secrets, so I would never run MM in public without protection.
