    Update magic mirror error
    4 Posts 2 Posters 978 Views 2 Watching
      StewartBaird86
      Trying to run the update but get the following error:
      Your local changes to the following files would be overwritten by merge: package-lock.json
      Please commit your changes or stash them before you merge,
      Aborting
      I have only edited my config.js and cloned modules to module folder.
      Tried the following commands and got same error
      Git pull
      Git pull && npm install
        sdetweil @StewartBaird86
        @StewartBaird86 yeh, what a apin
        run my update script see
        read the readme for the 2 commands u will have to issue
        it will tell u you don’t need to save the package-lock.json files
          StewartBaird86 @sdetweil
          @sdetweil I am doing this remotely on a laptop. I am also a noob to all of this and don’t understand the bash portion.
          I have typed your script in using brackets, quotations etc and nothing happens in my terminal.
          what are the steps to execute the scripts
            @StewartBaird86 you just cut/paste the whole line… nothing to think about
            what do you mean ‘remotely’… via ssh??
            just paste the line into the ssh session window
            this is the test run command
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            if all looks good, then u would execute this command
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
