    mmm-Remote-Control issues
    4 Posts 2 Posters 875 Views 2 Watching
    • M
      mrlowndes
      Hello, I’m having difficulty getting access. I have changed the config.js file multiple times to no affect. All the things I have read talk about IP addresses in the 192 range, but all mine are 10.0.0.xxx. I have added the IPs of my phone and laptop to the config but it just doesn’t work. Here are the settings currently:
      var config = {
      	//address: "localhost", // Address to listen on, can be:
      address: "0.0.0.0",
      	                      // - "localhost", "0.0.0.0", "::1" to listen on loopback interface
      	port: 8080,
      	ipWhitelist: ["::fff:10.0.0.110", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
      and here is the module in my config.js file:
              module: 'MMM-Remote-Control',
              // uncomment the following line to show the URL of the remote control on the mirror
              position: 'bottom_left',
              // you can hide this module afterwards from the remote control itself
              //customCommand: {},  // Optional, See "Using Custom Commands" below
              //customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              //showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              apiKey: "",         // Optional, See API/README.md for details
        sdetweil @mrlowndes
        @mrlowndes remove everything from the ipWhitelist
        • M
          mrlowndes
          @sdetweil so the whitelist doesn’t work?
            sdetweil @mrlowndes
            @mrlowndes it does, but 1st thing is to get connected
