mmm-Remote-Control issues
4 Posts 2 Posters 456 Views 2 Watching
    mrlowndes
    Hello, I’m having difficulty getting access. I have changed the config.js file multiple times to no affect. All the things I have read talk about IP addresses in the 192 range, but all mine are 10.0.0.xxx. I have added the IPs of my phone and laptop to the config but it just doesn’t work. Here are the settings currently:
    var config = {
    	//address: "localhost", // Address to listen on, can be:
    address: "0.0.0.0",
    	                      // - "localhost", "0.0.0.0", "::1" to listen on loopback interface
    	port: 8080,
    	ipWhitelist: ["::fff:10.0.0.110", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
    and here is the module in my config.js file:
            module: 'MMM-Remote-Control',
            position: 'bottom_left',
            //customCommand: {},  // Optional, See "Using Custom Commands" below
            //customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
            //showModuleApiMenu: true, // Optional, Enable the Module Controls menu
            apiKey: "",         // Optional, See API/README.md for details
    S 1 Reply Last reply Apr 29, 2020, 12:57 AM Reply Quote 0
    • S Away
      sdetweil @mrlowndes
      @mrlowndes remove everything from the ipWhitelist
        mrlowndes
        @sdetweil so the whitelist doesn’t work?
        S 1 Reply Last reply Apr 29, 2020, 1:52 AM Reply Quote 0
        • S Away
          sdetweil @mrlowndes
          @mrlowndes it does, but 1st thing is to get connected
