    cannot install pm2
    46 Posts 2 Posters 12.9k Views 2 Watching
      mrlowndes
      @sdetweil still nothing:
      pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
      the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
      npm ERR! Unexpected end of JSON input while parsing near '...pes/node":"^12.7.5","'
      npm ERR!     /root/.npm/_logs/2020-04-29T21_00_10_606Z-debug.log
      bash: line 103: pm2: command not found
      bash: line 180: pm2: command not found
      bash: line 183: pm2: command not found
        sdetweil
        @mrlowndes said in cannot install pm2:
        npm ERR! Unexpected end of JSON input while parsing near '…pes/node":"^12.7.
        u are getting weird failures…
        every time we have seen this, it is the SD card failing.
          mrlowndes
          hmm good question.
            mrlowndes
            @sdetweil should be fine its a SanDisk Ultra Plus 64GB U1 SDXC
              mrlowndes
              @sdetweil if it is the SD card, is it the kind of thing a deep format and reinstall of Raspbian will fix, or is the SD just terminally bad? Wen I reinstalled Raspbian the last time, I did just do a quick format on this card before flashing the image.
                sdetweil @mrlowndes
                @mrlowndes when the sd card starts to fail, it is toast
                  mrlowndes
                  @sdetweil bummer - it’s brand new out of the box. Just managed to scrounge another from my GoPro. Ill format that, reflash Raspbian and see how I go. I’ll just use your script first off, rather than doing a manual install. I’ll let you know how I get on, on here but it will take me a long time with all the updates that Raspbian does. Thanks so much for your help.
                    sdetweil @mrlowndes
                    @mrlowndes ok, will be around…
                      sdetweil
                      someone else just reported a similar failure on a pi 0.
                      so, I reflashed my sd card with buster and ran the installer without any issues on a pi 0w
                        mrlowndes
                        I ran your script and it didn’t finish - Unable to install dependencies! Also, this website has locked me out of singing into my account from my pi…
                        • 3 / 5
