    MMM-MyTraffic not working anymore
    7 Posts 4 Posters 1.7k Views 4 Watching
      madradrakie
      Hello,
      I use the module MMM-MyTraffic to check the traffic information every morning but it is not working anymore. Because i also use dashticz i figured out that the ANWB feed changed. Is their anybody who has fixed the module or can help me? It is not simple change the RSS feed (i found out).
      Thanks in advanc
        Detto65
        looks like the ANWB doesnt provide the feed anymore
        and i couldnt find on their website if it was changed.
        my guess is that it is replaced for a payed version.
        Removed it from my mirror, its not a module problem.
          madradrakie
          in dashticz the same problem occurred. The new feed the dashticz module uses is:
          https://api.anwb.nl/v1/incidents?apikey=QYUEE3fEcFD7SGMJ6E7QBCMzdQGqRkAi.
          Maybe somebody has the skills the rebuild the module because it alwyas worked very good!
          T 1 Reply Last reply Reply Quote 1
          • T Offline
            thiske @madradrakie
            @madradrakie yes the module workt properly! I know that someone can change the code that the new anwb api works whitin this module!
            Maybe you can set this topic to unsolved?
              madradrakie @thiske
              @thiske how do i set the topic to unsolved?
                sdetweil @madradrakie
                @madradrakie this was not marked as a problem, so cannot be ‘closed’
                  Detto65
                  be carefull with posting api keys, they may be payed by someone
