    MMM-TelegramBot customCommands creation
    3 Posts 2 Posters 662 Views 2 Watching
      aurely89
      Hi everybody,
      I’ve been using MMM-TelegramBot for a while and it really works greatly.
      I need now to create a new custom command and reading the documentation I really don’t know where to start from.
      Should I create it in MMM-TelegramBOT/MMM-TelegramBOT.js or simply add it in the MM config.js? If extended documentation please report so I can study on that.
      A good alternative, if possible, would be to add a label to the favor shortcuts on Telegram app not to see the whole command.
      Thank you in advance for your support.
        aurely89
        If it can helps I found this guides:
        https://github.com/bugsounet/MMM-TelegramBot/wiki/Custom-Command
        https://github.com/bugsounet/MMM-TelegramBot/wiki/How-to-add-commands
        • ? Offline
          A Former User
          You have 2 possibilities:
          1. with your config module (config.js file) with customCommands: []
          2. directly in your own module. There is an real exemple code with MMM-Assistant2Display for TelegramBot
