    Magic Mirror turns to blank screen after 20 minutes
    4 Posts 2 Posters 792 Views 2 Watching
    • 6 Offline
      61metsj373
      Hello,
      I installed the magic mirror and have the program autostarting. Around 20 minutes, the screen goes to blank. If I plug in a keyboard, hit F11, it will minimize the magic mirror window and refresh it. If i it F11 again it will maximize the window and continue on until it goes blank after another 20 minutes. Does not seem like the Pi or Monitor is asleep or screensaving as hitting F11 causing a very fast automatic minimize and refresh. Any advice to stop this?
      Thank you,
      Craig
        sdetweil @61metsj373
        @61metsj373 how did u install? the automated script?
        if not probably screen saver is not turned off… the screensaveroff script here will correct that
        • 6 Offline
          61metsj373
          sudo apt-get install xscreensaver
          sudo reboot
          The above fixed my issue.
            @61metsj373 there was a screensaver already installed, all u had to do was turn it off…
