    websocket is already in closing or closed state
    4 Posts 3 Posters 1.3k Views 3 Watching
      aurely89
      Hi everybody, anyone faced this issue? It seems to happen randomly.
      I’ve opened the console and it should be a known issue related to the jitter.
      Anyone knows any workaround or fix I could apply?
      Thank you in advance!
        sdetweil @aurely89
        @aurely89 could you give a little more info please? MM version, modules installed, what the console messages look like…
          aurely89
          Hi Sam, thank you for replying.
          • MM installed version is the latest available: 2.11.0.
          • These are the installed modules:
            MMM-pages
            alert
            updatenotification
            clock
            calendar
            currentweather
            weatherforecast
            newsfeed
            MMM-WiFiPassword
            MMM-Trello
            MMM-xiaomi
            MMM-NowPlayingOnSpotify
            MMM-Screencast
            MMM-TelegramBot
            MMM-Bring
            MMM-MyScoreboard
            MMM-Tools
            MMM-GPIO-Notifications
            MMM-Screen-Powersave-Notification
          • This is the console message:
          main.js:456 Initializing MagicMirror.
          translator.js:202 Loading core translation file: translations/it.json
          translator.js:225 Loading core translation fallback file: translations/en.json
          loader.js:179 Load script: modules/MMM-pages//MMM-pages.js
          module.js:479 Module registered: MMM-pages
          loader.js:150 Bootstrapping module: MMM-pages
          loader.js:155 Scripts loaded for: MMM-pages
          loader.js:194 Load stylesheet: modules/MMM-pages/pages.css
          loader.js:157 Styles loaded for: MMM-pages
          loader.js:159 Translations loaded for: MMM-pages
          loader.js:179 Load script: modules/default/alert//alert.js
          module.js:479 Module registered: alert
          loader.js:150 Bootstrapping module: alert
          loader.js:179 Load script: modules/default/alert/classie.js
          loader.js:179 Load script: modules/default/alert/modernizr.custom.js
          loader.js:179 Load script: modules/default/alert/notificationFx.js
          loader.js:155 Scripts loaded for: alert
          loader.js:194 Load stylesheet: modules/default/alert/ns-default.css
          loader.js:194 Load stylesheet: vendor/css/font-awesome.css
          loader.js:157 Styles loaded for: alert
          translator.js:175 alert - Load translation fallback: translations/en.json
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
            protocols.This exposes users of this app to unnecessary security risks.
            Consider loading the following resources over HTTPS or FTPS.
           - http://0.0.0.0:8080/css/main.css
          - http://0.0.0.0:8080/fonts/roboto.css
          - http://0.0.0.0:8080/socket.io/socket.io.js
          - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          - http://0.0.0.0:8080/js/defaults.js
          - http://0.0.0.0:8080/config/config.js
          - http://0.0.0.0:8080/vendor/vendor.js
          - http://0.0.0.0:8080/modules/default/defaultmodules.js
          - http://0.0.0.0:8080/js/logger.js
          - http://0.0.0.0:8080/translations/translations.js
          - http://0.0.0.0:8080/js/translator.js
          - http://0.0.0.0:8080/js/class.js
          - http://0.0.0.0:8080/js/module.js
          - http://0.0.0.0:8080/js/loader.js
          - http://0.0.0.0:8080/js/socketclient.js
          - http://0.0.0.0:8080/js/main.js
          - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          - http://0.0.0.0:8080/translations/it.json
          - http://0.0.0.0:8080/translations/en.json
          - http://0.0.0.0:8080/modules/MMM-pages//MMM-pages.js
          - http://0.0.0.0:8080/modules/MMM-pages/pages.css
          - http://0.0.0.0:8080/modules/default/alert//alert.js
          - http://0.0.0.0:8080/modules/default/alert/classie.js
          - http://0.0.0.0:8080/modules/default/alert/modernizr.custom.js
          - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
          - http://0.0.0.0:8080/modules/default/alert/ns-default.css
          - http://0.0.0.0:8080/vendor/css/font-awesome.css
          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
          For more information and help, consult
          https://electronjs.org/docs/tutorial/security.
           This warning will not show up
          once the app is packaged.
          warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
              Policy set or a policy with "unsafe-eval" enabled. This exposes users of
          (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
          loader.js:159 Translations loaded for: alert
          loader.js:179 Load script: modules/default/updatenotification//updatenotification.js
          module.js:479 Module registered: updatenotification
          loader.js:150 Bootstrapping module: updatenotification
          loader.js:155 Scripts loaded for: updatenotification
          loader.js:157 Styles loaded for: updatenotification
          loader.js:159 Translations loaded for: updatenotification
          loader.js:179 Load script: modules/default/clock//clock.js
          module.js:479 Module registered: clock
          loader.js:150 Bootstrapping module: clock
          loader.js:179 Load script: vendor/node_modules/moment/min/moment-with-locales.js
          loader.js:179 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
          loader.js:179 Load script: vendor/node_modules/suncalc/suncalc.js
          loader.js:155 Scripts loaded for: clock
          loader.js:194 Load stylesheet: modules/default/clock/clock_styles.css
          loader.js:157 Styles loaded for: clock
          loader.js:159 Translations loaded for: clock
          loader.js:179 Load script: modules/default/calendar//calendar.js
          module.js:479 Module registered: calendar
          loader.js:150 Bootstrapping module: calendar
          loader.js:233 File already loaded: moment.js
          loader.js:155 Scripts loaded for: calendar
          loader.js:194 Load stylesheet: modules/default/calendar/calendar.css
          loader.js:233 File already loaded: font-awesome.css
          loader.js:157 Styles loaded for: calendar
          loader.js:159 Translations loaded for: calendar
          loader.js:179 Load script: modules/default/currentweather//currentweather.js
          module.js:479 Module registered: currentweather
          loader.js:150 Bootstrapping module: currentweather
          loader.js:155 Scripts loaded for: currentweather
          loader.js:194 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
          loader.js:194 Load stylesheet: modules/default/currentweather/currentweather.css
          loader.js:157 Styles loaded for: currentweather
          loader.js:159 Translations loaded for: currentweather
          loader.js:179 Load script: modules/default/weatherforecast//weatherforecast.js
          module.js:479 Module registered: weatherforecast
          loader.js:150 Bootstrapping module: weatherforecast
          loader.js:155 Scripts loaded for: weatherforecast
          loader.js:233 File already loaded: weather-icons.css
          loader.js:194 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
          loader.js:157 Styles loaded for: weatherforecast
          loader.js:159 Translations loaded for: weatherforecast
          loader.js:179 Load script: modules/default/newsfeed//newsfeed.js
          module.js:479 Module registered: newsfeed
          loader.js:150 Bootstrapping module: newsfeed
          loader.js:155 Scripts loaded for: newsfeed
          loader.js:157 Styles loaded for: newsfeed
          loader.js:159 Translations loaded for: newsfeed
          loader.js:179 Load script: modules/MMM-WiFiPassword//MMM-WiFiPassword.js
          module.js:479 Module registered: MMM-WiFiPassword
          loader.js:150 Bootstrapping module: MMM-WiFiPassword
          loader.js:179 Load script: modules/MMM-WiFiPassword/qrcode.min.js
          loader.js:194 Load stylesheet: modules/MMM-WiFiPassword/MMM-WiFiPassword.css
          loader.js:155 Scripts loaded for: MMM-WiFiPassword
          loader.js:157 Styles loaded for: MMM-WiFiPassword
          loader.js:159 Translations loaded for: MMM-WiFiPassword
          loader.js:179 Load script: modules/MMM-Trello//MMM-Trello.js
          module.js:479 Module registered: MMM-Trello
          loader.js:150 Bootstrapping module: MMM-Trello
          loader.js:155 Scripts loaded for: MMM-Trello
          loader.js:194 Load stylesheet: modules/MMM-Trello/MMM-Trello.css
          loader.js:157 Styles loaded for: MMM-Trello
          translator.js:175 MMM-Trello - Load translation fallback: translations/en.json
          loader.js:159 Translations loaded for: MMM-Trello
          loader.js:179 Load script: modules/MMM-xiaomi//MMM-xiaomi.js
          module.js:471 Check MagicMirror version for module 'MMM-xiaomi' - Minimum version:  2.0.0 - Current version: 2.11.0
          module.js:473 Version is ok!
          module.js:479 Module registered: MMM-xiaomi
          loader.js:150 Bootstrapping module: MMM-xiaomi
          loader.js:179 Load script: modules/MMM-xiaomi/String.format.js
          loader.js:179 Load script: https://code.jquery.com/jquery-2.2.3.min.js
          loader.js:155 Scripts loaded for: MMM-xiaomi
          loader.js:194 Load stylesheet: modules/MMM-xiaomi/MMM-xiaomi.css
          loader.js:157 Styles loaded for: MMM-xiaomi
          loader.js:159 Translations loaded for: MMM-xiaomi
          loader.js:179 Load script: modules/MMM-NowPlayingOnSpotify//MMM-NowPlayingOnSpotify.js
          module.js:479 Module registered: MMM-NowPlayingOnSpotify
          loader.js:150 Bootstrapping module: MMM-NowPlayingOnSpotify
          loader.js:179 Load script: modules/MMM-NowPlayingOnSpotify/core/NPOS_DomBuilder.js
          loader.js:155 Scripts loaded for: MMM-NowPlayingOnSpotify
          loader.js:194 Load stylesheet: modules/MMM-NowPlayingOnSpotify/css/styles.css
          loader.js:179 Load script: modules/MMM-NowPlayingOnSpotify/node_modules/moment-duration-format/lib/moment-duration-format.js
          loader.js:157 Styles loaded for: MMM-NowPlayingOnSpotify
          loader.js:159 Translations loaded for: MMM-NowPlayingOnSpotify
          loader.js:179 Load script: modules/MMM-Screencast//MMM-Screencast.js
          module.js:471 Check MagicMirror version for module 'MMM-Screencast' - Minimum version:  2.1.0 - Current version: 2.11.0
          module.js:479 Module registered: MMM-Screencast
          loader.js:150 Bootstrapping module: MMM-Screencast
          loader.js:155 Scripts loaded for: MMM-Screencast
          loader.js:157 Styles loaded for: MMM-Screencast
          loader.js:159 Translations loaded for: MMM-Screencast
          loader.js:179 Load script: modules/MMM-TelegramBot//MMM-TelegramBot.js
          module.js:479 Module registered: MMM-TelegramBot
          loader.js:150 Bootstrapping module: MMM-TelegramBot
          loader.js:179 Load script: modules/MMM-TelegramBot/TELBOT_lib.js
          loader.js:155 Scripts loaded for: MMM-TelegramBot
          loader.js:194 Load stylesheet: modules/MMM-TelegramBot/MMM-TelegramBot.css
          loader.js:157 Styles loaded for: MMM-TelegramBot
          translator.js:175 MMM-TelegramBot - Load translation fallback: translations/en.json
          loader.js:159 Translations loaded for: MMM-TelegramBot
          loader.js:179 Load script: modules/MMM-Bring//MMM-Bring.js
          module.js:479 Module registered: MMM-Bring
          loader.js:150 Bootstrapping module: MMM-Bring
          loader.js:155 Scripts loaded for: MMM-Bring
          loader.js:194 Load stylesheet: modules/MMM-Bring/css/styles.css
          loader.js:157 Styles loaded for: MMM-Bring
          loader.js:159 Translations loaded for: MMM-Bring
          loader.js:179 Load script: modules/MMM-MyScoreboard//MMM-MyScoreboard.js
          module.js:479 Module registered: MMM-MyScoreboard
          loader.js:150 Bootstrapping module: MMM-MyScoreboard
          loader.js:155 Scripts loaded for: MMM-MyScoreboard
          loader.js:194 Load stylesheet: modules/MMM-MyScoreboard/MMM-MyScoreboard.css
          loader.js:157 Styles loaded for: MMM-MyScoreboard
          loader.js:159 Translations loaded for: MMM-MyScoreboard
          loader.js:179 Load script: modules/MMM-Tools//MMM-Tools.js
          module.js:479 Module registered: MMM-Tools
          loader.js:150 Bootstrapping module: MMM-Tools
          loader.js:155 Scripts loaded for: MMM-Tools
          loader.js:194 Load stylesheet: modules/MMM-Tools/MMM-Tools.css
          loader.js:157 Styles loaded for: MMM-Tools
          translator.js:175 MMM-Tools - Load translation fallback: translations/en.json
          loader.js:159 Translations loaded for: MMM-Tools
          loader.js:179 Load script: modules/MMM-GPIO-Notifications//MMM-GPIO-Notifications.js
          module.js:479 Module registered: MMM-GPIO-Notifications
          loader.js:150 Bootstrapping module: MMM-GPIO-Notifications
          loader.js:155 Scripts loaded for: MMM-GPIO-Notifications
          loader.js:157 Styles loaded for: MMM-GPIO-Notifications
          loader.js:159 Translations loaded for: MMM-GPIO-Notifications
          loader.js:179 Load script: modules/MMM-Screen-Powersave-Notification//MMM-Screen-Powersave-Notification.js
          module.js:479 Module registered: MMM-Screen-Powersave-Notification
          loader.js:150 Bootstrapping module: MMM-Screen-Powersave-Notification
          loader.js:155 Scripts loaded for: MMM-Screen-Powersave-Notification
          loader.js:194 Load stylesheet: modules/MMM-Screen-Powersave-Notification/screen-powersave.css
          loader.js:157 Styles loaded for: MMM-Screen-Powersave-Notification
          loader.js:159 Translations loaded for: MMM-Screen-Powersave-Notification
          loader.js:194 Load stylesheet: css/custom.css
          alert.js:153 Starting module: alert
          updatenotification.js:14 Start updatenotification
          clock.js:45 Starting module: clock
          calendar.js:77 Starting module: calendar
          currentweather.js:99 Starting module: currentweather
          weatherforecast.js:91 Starting module: weatherforecast
          newsfeed.js:61 Starting module: newsfeed
          MMM-Trello.js:32 Starting module: MMM-Trello
          MMM-xiaomi.js:61 Starting module: MMM-xiaomi
          MMM-NowPlayingOnSpotify.js:18 Starting module: MMM-NowPlayingOnSpotify
          MMM-Screencast.js:15 Starting module: MMM-Screencast
          MMM-MyScoreboard.js:560 Starting module: MMM-MyScoreboard
          :8080/modules/MMM-GPIO-Notifications//MMM-GPIO-Notifications.js:15 Starting module: MMM-GPIO-Notifications
          :8080/modules/MMM-Screen-Powersave-Notification//MMM-Screen-Powersave-Notification.js:87 Starting module: MMM-Screen-Powersave-Notification
          main.js:474 All modules started!
          MMM-pages.js:89 [Pages]: received that all objects are created;will now hide things!
          module.js:198 MMM-pages is suspended.
          module.js:198 MMM-TelegramBot is suspended.
          module.js:198 MMM-GPIO-Notifications is suspended.
          module.js:198 MMM-Screen-Powersave-Notification is suspended.
          module.js:198 currentweather is suspended.
          module.js:198 weatherforecast is suspended.
          module.js:198 MMM-WiFiPassword is suspended.
          module.js:198 MMM-Bring is suspended.
          module.js:198 MMM-Tools is suspended.
          module.js:205 alert is resumed.
          main.js:280 Will not show currentweather. LockStrings active: module_5_currentweather
          main.js:280 Will not show weatherforecast. LockStrings active: module_6_weatherforecast
          module.js:205 clock is resumed.
          module.js:205 calendar is resumed.
          module.js:205 newsfeed is resumed.
          module.js:205 MMM-Trello is resumed.
          module.js:205 MMM-xiaomi is resumed.
          module.js:205 MMM-NowPlayingOnSpotify is resumed.
          module.js:205 MMM-Screencast is resumed.
          module.js:205 MMM-MyScoreboard is resumed.
          api.openweathermap.org/data/2.5/forecast/daily?id=6542122&units=metric&lang=it&APPID=034cd000fafa56ead6103d7308acb8af:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
          weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
          weatherRequest.onreadystatechange @ weatherforecast.js:266
          :8080/modules/MMM-Screen-Powersave-Notification//MMM-Screen-Powersave-Notification.js:78 UPDATING currentDelay
          index.js:83 WebSocket is already in CLOSING or CLOSED state.
          (anonymous) @ index.js:83
          • karsten13K Online
            karsten13
            don’t think that this error is related to an index.js from the MagicMirror core, so you can look which module has an index.js with >= 83 lines … or disable modules to catch the “bad” module …
