    Changing customcss for third party modules.
    4 Posts 2 Posters 994 Views 2 Watching
    • N
      nibov33070
      Hi. I’ve added boxes around modules using (for example):
      .module.newsfeed {
         background-color:rgba(255.255.255.05);
      and that works fine. When I try the same thing with the module Background slide show:
      .module.MMM-BackgroundSlideshow {
      It doesn’t take the settings. Does anyone know why?
      As a bonus question, is there a way to change the colour of the header text in the default calendar module?
      Thanks.
        sdetweil @nibov33070
        @nibov33070 cause backgroundSlideshow IS a background… so the image overlays the color
        • N
          nibov33070
          Thanks for the reply. I was a bit unclear, I was talking about the info option that shows the name of the image being shown. I’ve discovered that the settings are in the BackgroundSlideshow.css file under
          .MMM-BackgroundSlideshow .info {
          If I change the file directly, it works, but if I add
          to the customcss file, it still doesn’t take effect.
            @nibov33070 sorry, you are still unclear… there is an entry in the css.
            you looked at the code and it uses the info class
            but if u edit the info class (to be the same as the already existing class???) it doesn’t work?
            in the config for the module it says this is required
            showImageInfo: true,
            https://github.com/darickc/MMM-BackgroundSlideshow
