    MMM-DarkSkyForecast Loading...
    mmm-darkskyforecastloadingnot working
    19 Posts 4 Posters 7.8k Views 3 Watching
    • P
      P_Tmans
      MMM-DarkSkyForecast, https://github.com/jclarke0000/MMM-DarkSkyForecast just says Loading… i’ve given it an api and the lat and long, i’m not sure what i’ve done wrong for it to show nothing at all. Any sugestions would be welcome.
        sdetweil @P_Tmans
        @P_Tmans did u have a darksky apikey before today? they haven’t been giving out api keys for a while now
        • P
          P_Tmans @sdetweil
          @sdetweil yea i got the api key a long time ago, before they eneded new sign ups, it has not been working since then
          C BKeyportB 2 Replies Last reply Reply Quote 0
          • C
            chassain 0 @P_Tmans
            @P_Tmans no problem with me today. Check your config.js
            • BKeyportB
              BKeyport Module Developer @P_Tmans
              @P_Tmans have you been actively using it? Can you still log in at https://darksky.net/dev/login ?
              • P
                P_Tmans @chassain 0
                @chassain-0 i don’t know what i should be looking for in my config, that’s kind of my main issue
                • P
                  P_Tmans @BKeyport
                  @BKeyport yea i can still log in, it’s still active it just shows no usage, as the module isn’t working at the moment
                  • C
                    chassain 0 @P_Tmans
                    @P_Tmans edit your config here and i will check with my api key
                    • P
                      P_Tmans @chassain 0
                      @chassain-0 defaults: {
                      apikey: “”,
                      latitude: “52.448896”,
                      longitude: “-1.74335”,
                      updateInterval: 10, // minutes
                      requestDelay: 250,
                      units: “uk2”,
                      showCurrentConditions: true,
                      showExtraCurrentConditions: true,
                      showSummary: true,
                      forecastHeaderText: “”,
                      showForecastTableColumnHeaderIcons: true,
                      showHourlyForecast: true,
                      hourlyForecastInterval: 3,
                      maxHourliesToShow: 3,
                      showDailyForecast: true,
                      maxDailiesToShow: 3,
                      showPrecipitation: true,
                      concise: true,
                      showWind: true,
                      language: config.language,
                      iconset: “2c”,
                      useAnimatedIcons: true,
                      animateMainIconOnly: true,
                      colored: true,
                      forecastLayout: “tiled”,
                      showInlineIcons: true,
                      mainIconSize: 100,
                      forecastTiledIconSize: 70,
                      forecastTableIconSize: 30,
                      updateFadeSpeed: 500,
                      label_maximum: “max”,
                      label_high: “H”,
                      label_low: “L”,
                      label_timeFormat: “h a”,
                      label_days: [“Sun”, “Mon”, “Tue”, “Wed”, “Thur”, “Fri”, “Sat”],
                      label_ordinals: [“N”, “NNE”, “NE”, “ENE”, “E”, “ESE”, “SE”, “SSE”, “S”, “SSW”, “SW”, “WSW”, “W”, “WNW”, “NW”, “NNW”],
                      moduleTimestampIdPrefix: “DARK_SKY_TIMESTAMP_”
                      that’s the config i have for the MMM-DarkSky Forecast.js ^
                      	 	 module: "MMM-DarkSkyForecast",
                      	 	 header: "Weather",
                      	 	 classes: "default everyone",
                      	 	 disabled: false,
                      	 	   apikey: "",
                      	 	   latitude: "52.448896",
                      	 	   longitude: "-1.74335",
                      	 	   iconset: "2c",
                      	 	   concise: false,
                      	 	   forecastLayout: "tiled"
                      thats the config i have for the config.js file ^
                      C S 2 Replies Last reply Reply Quote 0
                      • C
                        chassain 0 @P_Tmans
                        @P_Tmans said in MMM-DarkSkyForecast Loading...:
                             iconset: "2c",
                             concise: false,
                        Only with the config.js it’s ok for me
                        • P
                          P_Tmans @chassain 0
                          @chassain-0 alright, thanks for checking, i guess i should reinstall the module and go from there?
                          • C
                            chassain 0 @P_Tmans
                            @P_Tmans i think…and add only parameters to the config.js and not darsky…js
                            • P
                              P_Tmans @chassain 0
                              @chassain-0 oh ok, i’ll give that a go then, thanks for the help
                              C 1 Reply Last reply Reply Quote 1
                              • C
                                chassain 0 @P_Tmans
                                @P_Tmans one by one to begin
                                • P
                                  P_Tmans @chassain 0
                                  @chassain-0 i’ve reinstalled it and it’s saying loading… again
                                  i only added in the lat and long and my api key
                                  • C
                                    chassain 0 @P_Tmans
                                    @P_Tmans try a sudo reboot after npm install
                                      sdetweil @P_Tmans
                                      @P_Tmans don’t edit the source code in the module folder.
                                      everything in the defaults section u can set/override via the config.js
                                      • P
                                        P_Tmans
                                        the sudo reboot got it working, thanks ever so much for the help!
                                        • C
                                          chassain 0 @P_Tmans
                                          @P_Tmans you re welcome
