    MMM-DarkSkyForecast Loading...
    mmm-darkskyforecastloadingnot working
    19 Posts 4 Posters 7.8k Views 3 Watching
      P_Tmans @chassain 0
      @chassain-0 defaults: {
      apikey: “”,
      latitude: “52.448896”,
      longitude: “-1.74335”,
      updateInterval: 10, // minutes
      requestDelay: 250,
      units: “uk2”,
      showCurrentConditions: true,
      showExtraCurrentConditions: true,
      showSummary: true,
      forecastHeaderText: “”,
      showForecastTableColumnHeaderIcons: true,
      showHourlyForecast: true,
      hourlyForecastInterval: 3,
      maxHourliesToShow: 3,
      showDailyForecast: true,
      maxDailiesToShow: 3,
      showPrecipitation: true,
      concise: true,
      showWind: true,
      language: config.language,
      iconset: “2c”,
      useAnimatedIcons: true,
      animateMainIconOnly: true,
      colored: true,
      forecastLayout: “tiled”,
      showInlineIcons: true,
      mainIconSize: 100,
      forecastTiledIconSize: 70,
      forecastTableIconSize: 30,
      updateFadeSpeed: 500,
      label_maximum: “max”,
      label_high: “H”,
      label_low: “L”,
      label_timeFormat: “h a”,
      label_days: [“Sun”, “Mon”, “Tue”, “Wed”, “Thur”, “Fri”, “Sat”],
      label_ordinals: [“N”, “NNE”, “NE”, “ENE”, “E”, “ESE”, “SE”, “SSE”, “S”, “SSW”, “SW”, “WSW”, “W”, “WNW”, “NW”, “NNW”],
      moduleTimestampIdPrefix: “DARK_SKY_TIMESTAMP_”
      that’s the config i have for the MMM-DarkSky Forecast.js ^
      	 	 module: "MMM-DarkSkyForecast",
      	 	 header: "Weather",
      	 	 classes: "default everyone",
      	 	 disabled: false,
      	 	   apikey: "",
      	 	   latitude: "52.448896",
      	 	   longitude: "-1.74335",
      	 	   iconset: "2c",
      	 	   concise: false,
      	 	   forecastLayout: "tiled"
      thats the config i have for the config.js file ^
      C S 2 Replies Last reply Reply Quote 0
        chassain 0 @P_Tmans
        @P_Tmans said in MMM-DarkSkyForecast Loading...:
             iconset: "2c",
             concise: false,
        Only with the config.js it’s ok for me
          P_Tmans @chassain 0
          @chassain-0 alright, thanks for checking, i guess i should reinstall the module and go from there?
            chassain 0 @P_Tmans
            @P_Tmans i think…and add only parameters to the config.js and not darsky…js
              P_Tmans @chassain 0
              @chassain-0 oh ok, i’ll give that a go then, thanks for the help
                chassain 0 @P_Tmans
                @P_Tmans one by one to begin
                  P_Tmans @chassain 0
                  @chassain-0 i’ve reinstalled it and it’s saying loading… again
                  i only added in the lat and long and my api key
                    chassain 0 @P_Tmans
                    @P_Tmans try a sudo reboot after npm install
                      sdetweil @P_Tmans
                      @P_Tmans don’t edit the source code in the module folder.
                      everything in the defaults section u can set/override via the config.js
                        P_Tmans
                        the sudo reboot got it working, thanks ever so much for the help!
                          chassain 0 @P_Tmans
                          @P_Tmans you re welcome
