    Need Help - Absolute Beginner - Code Posted!
    20 Posts 3 Posters 3.5k Views 3 Watching
      bumrocks @sdetweil
      @sdetweil Thank you for your response again. In my frustration I took a few days off and am now trying back at it…As far it not being a product and contributing, I understand very well and in what may be a feeble attempt did make remarks and suggestions for changes in a branch? off of the directions to include and/or remove certain information. On the Internet people can say or claim what they want whether truth or not but my intention is to not simply take what I can. I intend to contribute however I might, even if it is just monetarily. Unfortunately, I have not gotten very far and am still trying to figure out why.
      In trying to simplify my life, I did as you suggested, changed the MagicMirror directory name and then tried an install from your script. After running the primary command
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh
      I end up with a bunch of return code that ends with this (let me know if you need the full code it gives back)…
      t -dpms
      			else
      			  echo "lxsession screen saver already disabled" >> $logfile
      			fi
      		fi
      	fi
      fi
      echo " "
      if [ $pm2setup -eq $true ]; then
      	rmessage="pm2 start MagicMirror"
      else
        rmessage="DISPLAY=:0 npm start"
      fi
      echo -e "\e[92mWe're ready! Run \e[1m\e[97m$rmessage\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m" | tee -a $logfile
      echo " "
      echo " "
      date +"install completed - %a %b %e %H:%M:%S %Z %Y" >>$logfile
      pi@MagicMirror2:~ $
      It takes a matter of seconds to return all this and therefore is evident that nothing actually was installed. To confirm I have no new MagicMirror folder in my system, at least that I can find. Not within the /home/pi folder nor further back within the root directory. So I am at a loss as to what I now need to do. I tried running some other command but it also told me that Magic Mirror was not installed…
      echo
      			 echo or git stash pop to restore them all
      			 echo
      			 echo WARNING..
      			 echo WARNING.. either will overlay the file just installed by the update
      			 echo WARNING..
      			 if [ $set_username == $true ]; then
      			    git config --global --unset user.name >>/$logfile
      					git config --global --unset user.email >>/$logfile
      			 fi
      		 fi
      	fi
      	# return to original folder
      	cd - >/dev/null
      	date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
      else
      	echo It appears MagicMirror has not been installed on this system
      	echo please run the installer, "raspberry.sh" first
      fi
      Thank you for your time and assistance in the matter. I have no issue starting from scratch if needed. Please advise :exploding_head:
      @BKeyport Understood…Makes sense and thank you! I feel a bit better now!
        bumrocks
        Here is the full code as it is returned to me…
        pi@MagicMirror2:~ $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh
        #!/bin/bash
        # This is an installer script for MagicMirror2. It works well enough
        # that it can detect if you have Node installed, run a binary script
        # and then download and run MagicMirror2.
        if [ $USER == 'root' ]; then
        	 echo Please login as a user to execute the MagicMirror installation,  not root
        	 exit 1
        fi
        echo -e "\e[0m"
        echo '$$\      $$\                     $$\           $$\      $$\ $$\                                          $$$$$$\'
        echo '$$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\'
        echo '$$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |'
        echo '$$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |'
        echo '$$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/'
        echo '$$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |'
        echo '$$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\'
        echo '\__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|'
        echo '                       $$\   $$ |'
        echo '                       \$$$$$$  |'
        echo '                        \______/'
        echo -e "\e[0m"
        doInstall=1
        true=1
        false=0
        # Define the tested version of Node.js.
        NODE_TESTED="v10.1.0"
        NPM_TESTED="V6.0.0"
        USER=`whoami`
        PM2_FILE=pm2_MagicMirror.json
        forced_arch=
        pm2setup=$false
        trim() {
            local var="$*"
            # remove leading whitespace characters
            var="${var#"${var%%[![:space:]]*}"}"
            # remove trailing whitespace characters
            var="${var%"${var##*[![:space:]]}"}"
            echo -n "$var"
        cd $HOME
        mac=$(uname -s)
        if [ 0 -eq 1 ]; then
        	if [ "$0" == "bash" ]; then
        		logdir=.
        	else
        		if [ $mac == 'Darwin' ]; then
        			echo this is a mac >> $logfile
        			logdir=$(dirname "$0")
        		else
        			# put the log where the script is located
        				logdir=$(dirname $(readlink -f "$0"))
        		fi
        	fi
        	# if the script was execute from the web
        	if [[ $logdir != *"MagicMirror/installers"* ]]; then
        		# use the MagicMirror/installers folder, if setup
        		if [ -d MagicMirror ]; then
        			cd ~/MagicMirror/installers >/dev/null
        				logdir=$(pwd)
        			cd - >/dev/null
        		else
        			# use the users home folder if initial install
        			logdir=$HOME
        		fi
        	fi
        fi
        logfile=$HOME/install.log
        echo install log being saved to $logfile
        # Determine which Pi is running.
        date +"install starting  - %a %b %e %H:%M:%S %Z %Y" >>$logfile
        ARM=$(uname -m)
        echo installing on $ARM processor system >>$logfile
        echo the os is $(lsb_release -a 2>/dev/null) >> $logfile
        OS=$(lsb_release -a 2>/dev/null | grep name: | awk '{print $2}')
        # Check the Raspberry Pi version.
        if [ "$ARM" != "armv7l" ]; then
          read -p "this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?" choice
        	choice="${choice:-N}"
        	if [[ $choice =~ ^[Nn]$ ]]; then
        	  echo user stopped install on $ARM hardware  >>$logfile
        		echo -e "\e[91mSorry, your Raspberry Pi is not supported."
        		echo -e "\e[91mPlease run MagicMirror on a Raspberry Pi 2 or 3."
        		echo -e "\e[91mIf this is a Pi Zero, the setup will configure to run in server only mode wih a local browser."
        		exit;
        	fi
        fi
        # Define helper methods.
        function command_exists () { type "$1" &> /dev/null ;}
        function verlte() {  [ "$1" = "`echo -e "$1\n$2" | sort -V | head -n1`" ];}
        function verlt() { [ "$1" = "$2" ] && return 1 || verlte $1 $2 ;}
        # Update before first apt-get
        if [ $mac != 'Darwin' ]; then
        	echo -e "\e[96mUpdating packages ...\e[90m" | tee -a $logfile
        	upgrade=$false
        	update=$(sudo apt-get update 2>&1)
            # sudo apt-get update --allow-releaseinfo-change
        	echo $update >> $logfile
        	update_rc=$?
            if [ $(echo $update | grep -i "is not valid yet" | wc -l) -ne 0 ]; then
               echo -e "\e[91mSystem date/time is in the past, please correct ...\e[90m" | tee -a $logfile
               exit 1
            fi
        	if [ $update_rc -ne 0 ]; then
                echo -e "\e[91mUpdate failed, retrying installation ...\e[90m" | tee -a $logfile
                if [ $(echo $update | grep "apt-secure" | wc -l) -eq 1 ]; then
        	        update=$(sudo apt-get update --allow-releaseinfo-change 2>&1)
        	        update_rc=$?
        		        echo "second apt-get update failed" $update | tee -a $logfile
        		        exit 1
        	        else
        		        echo "second apt-get update completed ok" >> $logfile
        		        upgrade=$true
        	        fi
                fi
        	else
        		echo "apt-get update  completed ok" >> $logfile
        		upgrade=$true
        	fi
        	if [ $upgrade -eq $true ]; then
        	   echo "apt-get upgrade  started" >> $logfile
        	   upgrade_result=$(sudo apt-get --assume-yes upgrade  2>&1)
        		 upgrade_rc=$?
        		 echo apt upgrade result ="rc=$upgrade_rc $upgrade_result" >> $logfile
        	fi
        	# Installing helper tools
        	echo -e "\e[96mInstalling helper tools ...\e[90m" | tee -a $logfile
        	sudo apt-get --assume-yes install curl wget git build-essential unzip  >>$logfile
        fi
        # Check if we need to install or upgrade Node.js.
        echo -e "\e[96mCheck current Node installation ...\e[0m" | tee -a $logfile
        NODE_INSTALL=false
        if command_exists node; then
        	echo -e "\e[0mNode currently installed. Checking version number." | tee -a $logfile
        	NODE_CURRENT=$(node -v)
        	if [ "$NODE_CURRENT." == "." ]; then
        	   NODE_CURRENT="V1.0.0"
        		 echo forcing low Node version  >> $logfile
        	fi
        	echo -e "\e[0mMinimum Node version: \e[1m$NODE_TESTED\e[0m" | tee -a $logfile
        	echo -e "\e[0mInstalled Node version: \e[1m$NODE_CURRENT\e[0m" | tee -a $logfile
        	if verlte $NODE_CURRENT $NODE_TESTED; then
        		echo -e "\e[96mNode should be upgraded.\e[0m" | tee -a $logfile
        		NODE_INSTALL=true
        		# Check if a node process is currenlty running.
        		# If so abort installation.
        		if pgrep "node" > /dev/null; then
        			echo -e "\e[91mA Node process is currently running. Can't upgrade." | tee -a $logfile
        			echo "Please quit all Node processes and restart the installer." | tee -a $logfile
        			echo $(ps -ef | grep node | grep -v \-\-color) | tee -a $logfile
        			exit;
        		fi
        	else
        		echo -e "\e[92mNo Node.js upgrade necessary.\e[0m" | tee -a $logfile
        	fi
        else
        	echo -e "\e[93mNode.js is not installed.\e[0m" | tee -a $logfile
        	NODE_INSTALL=true
        fi
        # Install or upgrade node if necessary.
        if $NODE_INSTALL; then
        	echo -e "\e[96mInstalling Node.js ...\e[90m" | tee -a $logfile
        	# Fetch the latest version of Node.js from the selected branch
        	# The NODE_STABLE_BRANCH variable will need to be manually adjusted when a new branch is released. (e.g. 7.x)
        	# Only tested (stable) versions are recommended as newer versions could break MagicMirror.
        	  brew install node
        	else
        		NODE_STABLE_BRANCH="10.x"
        		# sudo apt-get install --only-upgrade libstdc++6
        		node_info=$(curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash - )
        		echo Node release info = $node_info >> $logfile
        		if [ "$(echo $node_info | grep "not currently supported")." == "." ]; then
        			sudo apt-get install -y nodejs
        		else
        			echo node $NODE_STABLE_BRANCH version installer not available, doing manually >>$logfile
        			# no longer supported install
        			sudo apt-get install -y --only-upgrade libstdc++6 >> $logfile
        			# have to do it manually
        			node_vnum=$(echo $NODE_STABLE_BRANCH | awk -F. '{print $1}')
        			# get the highest release number in the stable branch line for this processor architecture
        			node_ver=$(curl -sL https://unofficial-builds.nodejs.org/download/release/index.tab | grep $ARM | grep -m 1 v$node_vnum | awk '{print $1}')
        			echo "latest release in the $NODE_STABLE_BRANCH family for $ARM is $node_ver" >> $logfile
        			curl -sL https://unofficial-builds.nodejs.org/download/release/$node_ver/node-$node_ver-linux-$ARM.tar.gz >node_release-$node_ver.tar.gz
        			cd /usr/local
        			echo using release tar file = node_release-$node_ver.tar.gz >> $logfile
        			sudo tar --strip-components 1 -xzf  $HOME/node_release-$node_ver.tar.gz
        			cd - >/dev/null
        			rm ./node_release-$node_ver.tar.gz
        		fi
        		# get the new node version number
        		new_ver=$(node -v 2>&1)
        		# if there is a failure to get it due to a missing library
        		if [ $(echo $new_ver | grep "not found" | wc -l) -ne 0 ]; then
        		fi
        		echo node version is $(node -v 2>&1 >>$logfile)
        	fi
        	echo -e "\e[92mNode.js installation Done! version=$(node -v)\e[0m" | tee -a $logfile
        fi
        # Check if we need to install or upgrade npm.
        echo -e "\e[96mCheck current NPM installation ...\e[0m" | tee -a $logfile
        NPM_INSTALL=false
        if command_exists npm; then
        	echo -e "\e[0mNPM currently installed. Checking version number." | tee -a $logfile
        	NPM_CURRENT='V'$(npm -v)
        	echo -e "\e[0mMinimum npm version: \e[1m$NPM_TESTED\e[0m" | tee -a $logfile
        	echo -e "\e[0mInstalled npm version: \e[1m$NPM_CURRENT\e[0m" | tee -a $logfile
        	if verlte $NPM_CURRENT $NPM_TESTED; then
        		echo -e "\e[96mnpm should be upgraded.\e[0m" | tee -a $logfile
        		NPM_INSTALL=true
        		# Check if a node process is currently running.
        		if pgrep "npm" > /dev/null; then
        			echo -e "\e[91mA npm process is currently running. Can't upgrade." | tee -a $logfile
        			echo "Please quit all npm processes and restart the installer." | tee -a $logfile
        			exit;
        		fi
        	else
        		echo -e "\e[92mNo npm upgrade necessary.\e[0m" | tee -a $logfile
        	fi
        else
        	echo -e "\e[93mnpm is not installed.\e[0m" | tee -a $logfile
        	NPM_INSTALL=true
        fi
        if $NPM_INSTALL; then
        	echo -e "\e[96mInstalling npm ...\e[90m" | tee -a $logfile
        	# Fetch the latest version of npm from the selected branch
        	#NODE_STABLE_BRANCH="9.x"
        	#curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
        	# if this is a mac, npm was installed with node
        		sudo apt-get install -y npm >>$logfile
        	fi
        	# update to the latest.
        	echo upgrading npm to latest >> $logfile
        	sudo npm i -g npm  >>$logfile
        	echo -e "\e[92mnpm installation Done! version=V$(npm -v)\e[0m" | tee -a $logfile
        fi
        # Install MagicMirror
        cd ~
        if [ $doInstall == 1 ]; then
        	if [ -d "$HOME/MagicMirror" ] ; then
        		echo -e "\e[93mIt seems like MagicMirror is already installed." | tee -a $logfile
        		echo -e "To prevent overwriting, the installer will be aborted." | tee -a $logfile
        		echo -e "Please rename the \e[1m~/MagicMirror\e[0m\e[93m folder and try again.\e[0m" | tee -a $logfile
        		echo ""
        		echo -e "If you want to upgrade your installation run \e[1m\e[97mupgrade-script\e[0m from the ~/MagicMirror/installers directory." | tee -a $logfile
        		echo ""
        		exit;
        	fi
        	echo -e "\e[96mCloning MagicMirror ...\e[90m" | tee -a $logfile
        	if git clone --depth=1 https://github.com/MichMich/MagicMirror.git; then
        		echo -e "\e[92mCloning MagicMirror Done!\e[90m" | tee -a $logfile
        		# replace faulty run-start.sh
        		curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >MagicMirror/run-start.sh
        		chmod +x MagicMirror/run-start.sh
        	else
        		echo -e "\e[91mUnable to clone MagicMirror. \e[90m" | tee -a $logfile
        		exit;
        	fi
        	cd ~/MagicMirror  || exit
        	if [ $(grep version package.json | awk -F: '{print $2}') == '"2.9.0",' -a $ARM == 'armv6l' ]; then
        	    git fetch https://github.com/MichMich/MagicMirror.git develop >/dev/null 2>&1
        		git branch develop FETCH_HEAD > /dev/null 2>&1
        		git checkout develop > /dev/null 2>&1
        	fi
        	# if this is v 2.11 or higher
        	newver=$(grep -i version package.json | awk -F\" '{ print $4 }')
        	if verlte "2.11.0" $newver; then
        	  # if one of the older devices, fix the start script to execute in serveronly mode
        	  if [ "$ARM" == "armv6l" ]; then
        		  # fixup the start script
        		  sed '/start/ c \    "start\"\:\"./run-start.sh $1\",' < package.json 	>new_package.json
        		  if [ -s new_package.json ]; then
        		  	cp new_package.json package.json
        		  	rm new_package.json
        		  	echo "package.json update for armv6l completed ok" >>$logfile
        		  else
        		  	echo "package.json update for armv6l failed " >>$logfile
        		  fi
        		  curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
        		  chmod +x run-start.sh
        	  elif [ "$ARM" == "x86_64" -a "$OS" == 'buster' ]; then
        	  	cd fonts
        	  	   sed '/roboto-fontface/ c \    "roboto-fontface": "latest"' < package.json 	>new_package.json
        		  	rm new_package.json
        		  	echo "package.json update for x86 fontface completed ok" >>$logfile
        		  fi
        	  	cd -
        	  elif [ $mac == 'Darwin' ]; then
        	  	   rm vendor/package-lock.json
        	  	   echo "erase vendor package-lock.json to allow later nan/fsevents install on mac" >>$logfile
        	  fi
        	fi
            if [ ! -e css/custom.css ]; then
               touch css/custom.css
            fi
        	echo -e "\e[96mInstalling dependencies ...\e[90m" | tee -a $logfile
        	rm package-lock.json 2>/dev/null
        	npm_i_r=$(npm install $forced_arch --only=prod)
            npm_i_rc=$?
            if [ $newver == '2.11.0' ]; then
              # fixup missing eslint (in dev dependencies)
          	  npm install eslint >>$logfile
        	fi
            if [ $npm_i_rc -eq 0 ]; then
        		echo -e "\e[92mDependencies installation Done!\e[90m" | tee -a $logfile
        	else
                if [ $(echo $npm_i_r | grep "CERT_NOT_YET_VALID" | wc -l) -ne 0 ]; then
                    echo "\e[91mSystem date/time is in the past, please correct \e[90m" | tee -a $logfile
                fi
        		echo -e "\e[91mUnable to install dependencies! \e[90m" | tee -a $logfile
        		exit;
        	fi
        	# fixup permissions on sandbox file if it exists
        	if [ -f node_modules/electron/dist/chrome-sandbox ]; then
        		 echo "fixing sandbox permissions" >>$logfile
        		 sudo chown root node_modules/electron/dist/chrome-sandbox 2>/dev/null
        		 sudo chmod 4755 node_modules/electron/dist/chrome-sandbox 2>/dev/null
        	fi
        	# if this an armv6l device (pi 0/1)
        	# if [ $ARM == 'armv6l' ]; then
        	#	# if this is the updated release
        	#	if ! verlt $(grep -i version package.json | awk -F\" '{ print $4 }')  2.10; then
        	#		# replace the start command with the old one
        	#		grep -v start package.json  | sed '/"scripts": {/a \ \ \ \ "start":\ "bash run-start.sh",' >package.json
        	#	fi
        	# fi
        	# Use sample config for start MagicMirror
        	echo setting up initial config.js | tee -a $logfile
        	cp config/config.js.sample config/config.js
        fi
        # Check if plymouth is installed (default with PIXEL desktop environment), then install custom splashscreen.
        echo -e "\e[96mCheck plymouth installation ...\e[0m" | tee -a $logfile
        if command_exists plymouth; then
        	THEME_DIR="/usr/share/plymouth/themes"
        	echo -e "\e[90mSplashscreen: Checking themes directory.\e[0m" | tee -a $logfile
        	if [ -d $THEME_DIR ]; then
        		echo -e "\e[90mSplashscreen: Create theme directory if not exists.\e[0m" | tee -a $logfile
        		if [ ! -d $THEME_DIR/MagicMirror ]; then
        			sudo mkdir $THEME_DIR/MagicMirror
        		fi
        		if sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script; then
        			echo
        			if [ "$(which plymouth-set-default-theme)." != "." ]; then
        				if sudo plymouth-set-default-theme -R MagicMirror; then
        					echo -e "\e[92mSplashscreen: Changed theme to MagicMirror successfully.\e[0m" | tee -a $logfile
        				else
        					echo -e "\e[91mSplashscreen: Couldn't change theme to MagicMirror!\e[0m" | tee -a $logfile
        				fi
        			fi
        		else
        			echo -e "\e[91mSplashscreen: Copying theme failed!\e[0m" | tee -a $logfile
        		fi
        	else
        		echo -e "\e[91mSplashscreen: Themes folder doesn't exist!\e[0m" | tee -a $logfile
        	fi
        else
        	echo -e "\e[93mplymouth is not installed.\e[0m" | tee -a $logfile
        fi
        # Use pm2 control like a service MagicMirror
        read -p "Do you want use pm2 for auto starting of your MagicMirror (y/N)?" choice
        if [[ $choice =~ ^[Yy]$ ]]; then
              echo install and setup pm2 | tee -a $logfile
         			# assume pm2 will be found on the path
        			pm2cmd=pm2
        			# check to see if already installed
        			pm2_installed=$(which $pm2cmd)
        			up=""
        				 up="--unsafe-perm"
        				 launchctl=launchctl
        				 launchctl_path=$(which $launchctl)
        				 `export PATH=$PATH:${launchctl_path%/$launchctl}`
        			fi
        			if [  "$pm2_installed." != "." ]; then
        			    # does it work?
        					pm2_fails=$(pm2 list | grep -i -m 1 "uptime" | wc -l )
        					if [ $pm2_fails != 1 ]; then
        					   # uninstall it
        						 echo pm2 installed, but does not work, uninstalling >> $logfile
        					   sudo npm uninstall $up -g pm2 >> $logfile
        						 # force reinstall
        				     pm2_installed=
        					fi
        			fi
        			# if not installed
        			if [  "$pm2_installed." == "." ]; then
        				# install it.
        				echo pm2 not installed, installing >>$logfile
        				result=$(sudo npm install $up -g pm2 2>&1)
        				echo pm2 install result $result >>$logfile
        				# if this is a mac
        					echo "this is a mac, fixup for path" >>$logfile
        					# get the location of pm2 install
        					# parse the npm install output to get the command
        					pm2cmd=`echo $result | awk -F -  '{print $1}' | tr -d '[:space:]'`
        					c='/pm2'
        					# get the path only
        					echo ${pm2cmd%$c} >installers/pm2path
        				fi
        			fi
        			echo "get the pm2 platform specific startup command" >>$logfile
        			# get the platform specific pm2 startup command
        			v=$($pm2cmd startup | tail -n 1)
        				# check to see if we can get the OS package name (Ubuntu)
        				if [ $(which lsb_release| wc -l) >0 ]; then
        					# fix command
        					# if ubuntu 18.04, pm2 startup gets something wrong
        					if [ $(lsb_release  -r | grep -m1 18.04 | wc -l) > 0 ]; then
        						 v=$(echo $v | sed 's/\/bin/\/bin:\/bin/')
        					fi
        				fi
        			fi
        			echo "startup command = $v" >>$logfile
        			# execute the command returned
                    $v 2>&1 >>$logfile
        			echo "pm2 startup command done" >>$logfile
        			# is this is mac
        			# need to fix pm2 startup, only on catalina
                        if [ $(sw_vers -productVersion | head -c 6) == '10.15.' ]; then
        					# only do if the faulty tag is present (pm2 may fix this, before the script is fixed)
        					if [ $(grep -m 1 UserName /Users/$USER/Library/LaunchAgents/pm2.$USER.plist | wc -l) -eq 1 ]; then
        						# copy the pm2 startup file config
        						cp  /Users/$USER/Library/LaunchAgents/pm2.$USER.plist .
        						# edit out the UserName key/value strings
        						sed -e '/UserName/{N;d;}' pm2.$USER.plist > pm2.$USER.plist.new
        						# copy the file back
        						sudo cp pm2.$USER.plist.new /Users/$USER/Library/LaunchAgents/pm2.$USER.plist
        					fi
        				fi
        			fi
        		# if the user is no pi, we have to fixup the pm2 json file
        		echo "configure the pm2 config file for MagicMirror" >>$logfile
        		# if the files we need aren't here, get them
        		if [ ! -e installers/pm2_MagicMirror.json ]; then
        			curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/pm2_MagicMirror.json >installers/pm2_MagicMirror.json
        			curl -sl https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/mm.sh >installers/mm.sh
        			chmod +x installers/mm.sh
        		fi
        		if [ "$USER"  != "pi" ]; then
        			echo the user is not pi >>$logfile
        			# go to the installers folder
        			cd installers
        			# edit the startup script for the right user
        			echo change mm.sh >>$logfile
        			 if [ ! -e mm_temp.sh ]; then
        			   echo save copy of mm.sh >> $logfile
        			   cp mm.sh mm_temp.sh
        			 fi
        			 if [ $(grep pi mm_temp.sh | wc -l) -gt 0 ]; then
        			  echo change hard coded pi username  >> $logfile
        				sed 's/pi/'$USER'/g' mm_temp.sh >mm.sh
        			 else
        			  echo change relative home path to hard coded path >> $logfile
        			  hf=$(echo $HOME |sed 's/\//\\\//g')
        			  sed 's/\~/'$hf'/g' mm_temp.sh >mm.sh
        			 fi
        			# edit the pms config file for the right user
        			echo change $PM2_FILE >>$logfile
        			sed 's/pi/'$USER'/g' $PM2_FILE > pm2_MagicMirror_new.json
        			# make sure to use the updated file
        			PM2_FILE=pm2_MagicMirror_new.json
        			# if this is a mac
        				 # copy the path file to the system paths list
        				 sudo cp ./pm2path /etc/paths.d
        				 # change the name of the home path for mac
        				 sed 's/home/Users/g' $PM2_FILE > pm2_MagicMirror_new1.json
        				 PM2_FILE=pm2_MagicMirror_new1.json
        			fi
        			echo now using this config file $PM2_FILE >>$logfile
        			# go back one cd level
        			cd - >/dev/null
        		fi
        		echo start MagicMirror via pm2 now >>$logfile
        		# tell pm2 to start the app defined in the config file
        		$pm2cmd start $HOME/MagicMirror/installers/$PM2_FILE
        		# tell pm2 to save that configuration, for start at boot
        		echo save MagicMirror pm2 config now  >>$logfile
        		$pm2cmd save
        		echo stop MagicMirror via pm2 now >>$logfile
        		#$pm2cmd stop MagicMirror
        		pm2setup=$true
        fi
        # Disable Screensaver
        read -p "Do you want to disable the screen saver? (y/N)?" choice
        choice="${choice:-Y}"
          # if this is a mac
        	  # get the current setting
        	  setting=$(defaults -currentHost read com.apple.screensaver idleTime)
        		# if its on
        		if [ "$setting" != 0 ] ; then
        		  # turn it off
        			echo disable screensaver via mac profile >> $logfile
        			defaults -currentHost write com.apple.screensaver idleTime 0
        		else
        			echo mac profile screen saver already disabled >> $logfile
        		fi
        	else
        	  # find out if some screen saver running
        		# get just the running processes and args
        		# just want the program name (1st token)
        		# find the 1st with 'saver' in it (should only be one)
        		# parse with path char, get the last field ( the actual pgm name)
        	  screen_saver_running=$(ps -A -o args | awk '{print $1}' | grep -m1 [s]aver | awk -F\/ '{print $NF}');
        		# if we found something
        		if [ "$screen_saver_running." != "." ]; then
        		  # some screensaver running
        			case "$screen_saver_running" in
        			 mate-screensaver) echo 'mate screen saver' >>$logfile
        						gsettings set org.mate.screensaver lock-enabled false	 2>/dev/null
        						gsettings set org.mate.screensaver idle-activation-enabled false	 2>/dev/null
        						gsettings set org.mate.screensaver lock_delay 0	 2>/dev/null
        				 echo " $screen_saver_running disabled" >> $logfile
        				 DISPLAY=:0  mate-screensaver  >/dev/null 2>&1 &
        			 gnome-screensaver) echo 'gnome screen saver' >>$logfile
        			   gnome_screensaver-command -d >/dev/null 2>&1
        			 xscreensaver) echo 'xscreensaver running' | tee -a $logfile
        			   xsetting=$(grep -m1 'mode:' ~/.xscreensaver )
        				 if [ $(echo $xsetting | awk '{print $2}') != 'off' ]; then
        					 sed -i "s/$xsetting/mode: off/" "$HOME/.xscreensaver"
        					 echo " xscreensaver set to off" >> $logfile
        				 else
        				   echo " xscreensaver already disabled" >> $logfile
        				 fi
        			 gsd-screensaver | gsd-screensaver-proxy)
        					setting=$(gsettings get org.gnome.desktop.screensaver lock-enabled 2>/dev/null)
        					setting1=$(gsettings get org.gnome.desktop.session idle-delay 2>/dev/null)
        					if [ "$setting. $setting1." != '. .' ]; then
        						if [ "$setting $setting1" != 'false uint32 0' ]; then
        							echo "disable screensaver via gsettings was $setting and $setting1" >> $logfile
        							gsettings set org.gnome.desktop.screensaver lock-enabled false
        							gsettings set org.gnome.desktop.screensaver idle-activation-enabled false
        							gsettings set org.gnome.desktop.session idle-delay 0
        						else
        							echo "gsettings screen saver already disabled" >> $logfile
        						fi
        					fi
        			 *) echo "some other screensaver $screen_saver_running" found | tee -a $logfile
        			    echo "please configure it manually" | tee -a $logfile
        		  esac
        		fi
        		if [ $(which gsettings | wc -l) == 1 ]; then
        					echo "disable screensaver via gsettings was $setting and $setting1">> $logfile
        				else
        				fi
        			fi
        		fi
        		if [ -e "/etc/lightdm/lightdm.conf" ]; then
        		  # if screen saver NOT already disabled?
        			if [ $(grep 'xserver-command=X -s 0 -dpms' /etc/lightdm/lightdm.conf | wc -l) == 0 ]; then
        			  echo "disable screensaver via lightdm.conf" >> $logfile
        				sudo sed -i '/^\[Seat:/a xserver-command=X -s 0 -dpms' /etc/lightdm/lightdm.conf
        			else
        			  echo "screensaver via lightdm already disabled" >> $logfile
        			fi
        		fi
        		if [ -d "/etc/xdg/lxsession/LXDE-pi" ]; then
        		  currently_set=$(grep -m1 '\-dpms' /etc/xdg/lxsession/LXDE-pi/autostart)
        			if [ "$currently_set." == "." ]; then
        				echo "disable screensaver via lxsession" >> $logfile
        				# turn it off for the future
        				sudo su -c "echo -e '@xset s noblank\n@xset s off\n@xset -dpms' >> /etc/xdg/lxsession/LXDE-pi/autostart"
        				# turn it off now
        				export DISPLAY=:0; xset s noblank;xset s off;xset -dpms
        			else
        			fi
        		fi
        	fi
        fi
        echo " "
        else
        fi
        echo " "
        echo " "
        pi@MagicMirror2:~ $
          sdetweil @bumrocks
          @bumrocks yes, the script is hard coded to MagicMirror
          i ‘could’ allow a parm to change the folder name
            bumrocks @sdetweil
            @sdetweil, I have made more time again. Thank you again for helping. But your last comment has me slightly confused. Here is what i “think”…
            By changing the folder name as you suggested earlier, I sorta uninstalled it. At least made any script you directed me to, to not recognize it as already being there and therefore allowing the script to run as intended and install and check system as it normally would. But your last statement makes me think otherwise now. My confusion is why change a parameter? I really want to use your script as it is intended to do, install, check, etc as it is intended. I don’t want this to be any more difficult than it needs to be or for you to make special arrangements either as I am sure you have better things to do and you are opening yourself up for who knows what special requests in the future, lol.
            Next, I am confused when reading the full return code that I posted above…It says…
            I have a Rasberry Pi 4. There are other things it states as issues but those are almost irrelevant until the script can perform as normal with the install. I have even gone as far as to try and find magicmirror in the “add/remove” software but after browsing and trying specific searches for it, I have come up empty. More confusion upon confusion.
            I am at a loss as to what to do next outside of wiping this micro sdcard and starting over without the manual install…Please help! thank you!
              sdetweil @bumrocks
              @bumrocks >Here is the full code as it is returned to me…
              u are not supposed to SEE the code of the script… u just execute it
              bash -c "… " means execute whatever is downloaded…
              you just copy/paste that one line from my github repo and its all done
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
              technically, the project (MagicMirror) says that it is ONLY supported on armv7l devices (pi 3 and 4).
              my script allows you to install anyhow (if u want to try it anyhow)…
              (I haven’t found anything it won’t run on, so its safe bet)
              i didn’t update the message , but will correct it…
              | edit: I have pushed the change for the run on 2/3/4 and supported on 2/3/4)
                sdetweil @bumrocks
                @bumrocks the instructions on my repo say
                to execute the install script, cut/paste this line into the terminal window on your device (I can't say PI, cause it works in a lot of other places too)
                  bumrocks @sdetweil
                  @sdetweil , I am aware of your instructions. I promise I read them. I have not tried to guess or shortcut your help. If you go back to the 11th post here…
                  https://forum.magicmirror.builders/topic/12964/need-help-absolute-beginner-code-posted/11
                  …you can see where I stated what I did and what problems I ran into. Maybe those issues had something to do with something else I had done…Now that I have turned off and booted the Pi again things are different. I will try the script again here in a minute and report back if it went as it is supposed to…
                    sdetweil @bumrocks
                    @bumrocks said in Need Help - Absolute Beginner - Code Posted!:
                    yes, u are looking at the code for some reason, if you cut/paste the entire line, you will not see the installer code, but the results of it executing…
                    don’t retype it…
                      bumrocks @sdetweil
                      @sdetweil , oh crap…I was not typing anything. I was copying and pasting but being my noobness in terminal is shining through I was only copying and pasting from within the quotes. I think before that I had copied…
                      …without the “bash” and therefore got an error code…I then guessed that I should try the code within the quotes facepalm My bad!
                      I will come back and let you know if I have outsmarted myself again or succeded in progressing, lol!
                      • BKeyportB Offline
                        BKeyport Module Developer @bumrocks
                        @bumrocks Easy mistake…
