    Blackscreen after fresh reinstall of OS, Assistant and Hotword
    hotwordmagic mirror
    6 Posts 2 Posters 1.8k Views 2 Watching
    • M
      M4gicD00bz
      Been tickering w/ this on and off for an annoying couple of months now and haven’t had any luck getting hotword to work. I scrapped everything and started from scratch reinstalling everything after reformatting the SD card.
      Encountered blackscreen. Commented out different sections of config until narrowed it down to Hotword module config. Ran syntax config check utility and found no syntax errors.
      I’ve uploaded my config.js file. Please help.
      [0_1591151424422_config.js](Uploading 100%)
        sdetweil @M4gicD00bz
        @M4gicD00bz yes the code crashed. hotword, alexa and assistant are tough modules to get running
        you should see the errors in the window where u start mm.
        if w pm2, the look at the output of pm2 logs
        M 1 Reply Last reply
        • M
          M4gicD00bz @sdetweil
          @sdetweil thanks for pointing out pm2 error logs. Will have a look after some sleep. Uploading log here: [0_1591166110878_MagicMirror-error.log](Uploading 100%)
            @M4gicD00bz neither file attached
            • M
              This post is deleted!
                sdetweil
                looks like you didn’t run the npm install step of the module install
                I’d suggest getting the new module MMM-GoogleAssistant that came out just this week.
                it replaces both old modules and it much easier to install.
                https://forum.magicmirror.builders/topic/12324/mmm-googleassistant?_=1591203920585
