    Node.js Compile Version Mis-Matches?
    15 Posts 4 Posters 4.0k Views 4 Watching
    • P Offline
      pillbug22
      I’m trying to MMM-MP3Player up and running to play music locally.
      Following the install instructions on GitHub, I added the 3 dependencies listed, then cloned the MMM-MP3Player project down as instructed.
      Now when starting up the MagicMirror, I’m getting the following:
      [2020-06-03 09:44:27.792] [LOG]    Whoops! There was an uncaught exception...
      [2020-06-03 09:44:27.793] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-MP3Player/node_modules/usb/build/Release/usb_bindings.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
          at process.func (electron/js2c/asar.js:138:31)
          at process.func [as dlopen] (electron/js2c/asar.js:138:31)
          at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
          at Object.func (electron/js2c/asar.js:138:31)
          at Object.func [as .node] (electron/js2c/asar.js:138:31)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at bindings (/home/pi/MagicMirror/modules/MMM-MP3Player/node_modules/bindings/bindings.js:112:48)
      Based on a similar issue/troubleshooting I found, I have done:
      cd /MagicMirror/modules/MMM-MP3Player
      rm -rf node_modules/usb
      npm cache clear
      rm package-lock.json
      npm i
      It does some work to rebuild/install the MMM-MP3Player module again, but I still receive the same error when starting up the MagicMirror next time.
      I then tried the 2nd and 3rd highest proposed solutions on there (electron-rebuild and –update-binary, but wind up with same error each time when trying to launch the MagicMirror.
      I’m guessing there is a different file that needs to be rebuilt, or a way to force using a specific version of Node.js?
        sdetweil @pillbug22
        @pillbug22 do
        cd ~/MagicMirror
        npm install electron-rebuild
        node_modules/.bin/electron-rebuild
        • ? Offline
          A Former User
          @sdetweil : are you sure of this ?
          install and execute electron rebuild inside main MM core !?
            sdetweil @Guest
            @Bugsounet sure, it will find what it needs to rebuild
            • ? Offline
              A Former User
              and scan … ALL modules …
                sdetweil @Guest
                @Bugsounet so, it will do it quickly… go get some coffee… everything not done in 2 seconds! lol
                • ? Offline
                  A Former User
                  lol
                  so the better thing is that :
                  install electron rebuild inside the module desired (there MMM-MP3Player)
                  cd ~/MagicMirror/modules/MMM-MP3Player
                  and execute it
                  ./node_modules/.bin/electron-rebuild
                    sdetweil @Guest
                    @Bugsounet better not to install it 12 times , just one in MM, then maybe use in module folder…
                    too many modules need rebuild
                    • ? Offline
                      A Former User
                      I have already tried it but sometimes … it remakes the queue with the other modules and crashes … that’s why I abandoned this method. otherwise on principle i agree with you :)
                      after … like i say : “If it want to works like this … let’s go on !”
                      • ? Offline
                        A Former User
                        I think MM needs to escape from the dependency of Electron. (Frankly, it is needed only for fullscreen kiosk front, not using any advanced benefits of Electron itself)
                        or at least modules need to use worker-threading or spawning child process which would be independent from Electron process environment to work with node’s native-modules.
                          sdetweil @Guest
                          @Sean yeh… could have used my prior startup script to test it out with chrome… start serveronly and use chrome to access
                          • ? Offline
                            A Former User @sdetweil
                            I had used my owns for the same.
                            Currently, standalone MM executes server(backend) js inside of Electron. That makes the things complex.
                            It would have been better to execute server outside of MM then launch front Electron for a smooth fullscreen kiosk mode.
                            Or progressively using Electron’s features might have been better also. Electron can support more advanced features like accessing system resources directly.
                            Anyway, current structure is somewhat ambiguous. I was frightened.
                              sdetweil @Guest
                              @Sean yeh, just get my run-start.sh scripts from my repo (added to base in 2.10, yanked out in 2.11)
                              change the start to launch run-start.sh
                              then can add a config parm to config.js
                              serverOnly:‘local’,
                              will do split mode locally serverOnly+ chrome
                              • P Offline
                                pillbug22
                                I thought I’d already done an Electron-rebuild install from the previous troubleshooting listed, but of course I wanted to do it again to verify:
                                $ cd MagicMirror
                                $ cd modules
                                $ cd MMM-MP3Player
                                $ npm install electron-rebuild
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm WARN MMM-MP3Player@1.0.0 No repository field.
                                + electron-rebuild@1.11.0
                                updated 1 package and audited 204 packages in 17.328s
                                1 package is looking for funding
                                  run `npm fund` for details
                                found 0 vulnerabilities
                                $ node_modules/.bin/electron-rebuild
                                ✔ Rebuild Complete
                                then go back up some folders and run:
                                $ npm run start
                                …aaaaaand, it opens as expected. Absolutely no clue what was different this time around. I went back and looked, and looks like I did already do this as per previous troubleshooting I found, but there must have been something different about how you guys suggested I install and run the electron-rebuild than what I did previously.
                                Another one of those “just needed a different set of eyes on it” issues, but glad you all were here to be the ones to look :-) Thank you much!
                                Now to go play around some more and see if I can actually get it to work correctly…but at least the mirror is back up and running
                                • ? Offline
                                  A Former User
                                  @pillbug22 : happy to help you :)
