    MMM-JsonTable, keeps loading
    4 Posts 2 Posters 918 Views 2 Watching
    • I
      Impertus
      Hi. i am trying to get som bus times om my MM.
      Have install the Jsontable and using this config here.
      Hi.
      I am trying to get your module to work :)
      i have the json url: http://xmlopen.rejseplanen.dk/bin/rest.exe/departureBoard?id=731643902&format=json
      This i my config.
      module: 'MMM-JsonTable',
      position: 'bottom_right',
      header: 'Bus tider ',
      url: 'https://xmlopen.rejseplanen.dk/bin/rest.exe/departureBoard?id=731643902&format=json'
      arrayName: 'Departure',
      keepColumns: ["Name"] // Optional
      I have made the adding to line 61 in MMM-JsonTable.js [all]
      Saw an issue on the github page, (nested arrays)
      https://github.com/timdows/MMM-JsonTable/blob/master/MMM-JsonTable.js#L61
      if (this.config.arrayName) {
      	items = this.jsonData[this.config.arrayName]["all"];
      } else {
      	items = this.jsonData;
        sdetweil @Impertus
        @Impertus said in MMM-JsonTable, keeps loading:
        keepColumns: [“Name”] // Optional
        the named field is ‘name’, not ‘Name’
        one of the array elements
            "name":"Bus 211",                // <-
            "type":"BUS",
            "stop":"Randers Produktionshøjskole/Grenåvej",
            "time":"13:47",
            "date":"05.06.20",
            "id":"731643901",
            "line":"211",
            "messages":"0",
            "rtTime":"13:51",
            "rtDate":"05.06.20",
            "finalStop":"Ørsted (Norddjurs Kom)",
            "direction":"Ørsted",
        • I
          Impertus
          yeahh. it works now…
          Now is just the
          descriptiveRow:
          that wont show up :D
            sdetweil @Impertus
            @Impertus
            keepNames requires ALL the fields to show (of all the fields available) … u only said name
            keepColumns [] Columns on json will be showed
            and if u want it formatted a specific way
            from the module example
            	descriptiveRow: '<tr><td>Name</td><td>Today</td><td>ThisWeek</td><td>LastWeek</td><td>ThisMonth</td><td>LastMonth</td></tr>'
            you have to make a little table row type declaration
