    Authorization Code Generation
    3 Posts 2 Posters 787 Views 2 Watching
      shawnlane
      Re: Microsoft To-Do (wunderlist replacement?)
      I can’t seem to get past the point. I am receiving “Can’t Connect To The Server” in my web browser. I put in my client id like the instructions stated. Any suggestions?
        stacywebb
        Make sure you have something similar to this in your config.js:
        var config = {
              address: address,
              port: 8080,
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.0.1/24" , "::ffff:192.168.0.1/24"],
        the 192.168.0.0 part should match your local subnet. this will allow any device to connect to your MM.
        Also if to access it make sure you have the port number after the ip of the mirror.
        For example only:
        http://192.168.0.155:8080
        Hope this helps.
          shawnlane @stacywebb
          @stacywebb Thank you…I will give this a try.
